  • 2024.06.09.1:
    *aded*
    • Vapoursynth: torch, ProPainter
    *changed*
    • Vapoursynth: torch, adjusted to DeOldify 0.3.5.3
    • Filtering: remove 'none' as auto deinterlacer handling option
    • Video: NVEnc support --tflevel --lookahead-level
    *fixed*
    • Vapoursynth: another EEDI3/EEDI3CL handling
    • Vapoursynth: Masking for RGBH filters
    • QSVEnc: remove '--tier' during hevc encoding
    • QSVEnc: set '--output-csp' (this is broken for most choices)
    • Jobs: QSVEnc av1 encoding in webm
    • Vapoursynth: torch, DeOldify fix FP16
    • Vapoursynth: TFM/VFM, fps refresh
    • Avisynth: custom with dual view
    • Avisynth: interlaced output + cropView
    • x265: 3.0 and 4.0 vbv values not set
  • 2024.06.15.1:
    *added*
    • Vapoursynth: support CPreview from hello_hello
    *changed*
    • Vapoursynth: torch, adjust to DeOldify 4.0.0
    • Vapoursynth: torch, adjust to vsRealESRGAN 5.0.0
    • Vapoursynth: reworked FillDuplicateFrames, FillDrops, ReplaceSingle into one class for stability
    • Vapoursynth: vs-mlrt, RIFE scale support optional requires 'onnx' in Vapoursynth/Lib/site-packages, see: https://github.com/AmusementClub/vs-mlrt/issues/94
    *fixed*
    • Vapoursynth: do not change color matrix on RGB content
    • Vapoursynth: fixed some unnecessary, popups during startup
    Ps.: deinstall old version before installing this one.
  • *2024.09.29.1:
    *changed*
    • Vapoursynth: SoftLight require PC scale when mode != 8
    • Vapoursynth: updated RIFE, RIFE(mlrt)
    • Vapoursynth: use constants for Matrix, Primaries, Chroma, Luma
    • Video: NVEnc/QSVEnc support --vpy-mt
    • Jobs: add abort-option to size- and audio-warning onjo create&start
    • Jobs: added scripts to report file
    • Video: removed NVEnc input type checks
    • Filtering: hide deinterlace control on progressive input, since it confuses users
    • Avisynth: FFmpeg2Source use YUV422PX instead of YUY2
    • Avisynth: increased suported memory max to 65536MB
    • Avisynth: Hybrid now comes without Avisynth 32bit support, it is an addon now
    • Video: do not check for UT Video, assume its present
    • Vapoursynth: prefer BestSource as default for file input
    • Vapoursynth: torch - added 'Requires'-controls to VSGAN and VSGAN Filter
    • Input: Switch from Vapoursynth to Avisynth (when available) on .avs input
    • Vapoursynth: TemporalDegrain2: degrainTR default and crash with degrainTR=0
    • Video: x264, disable and deactivate 'auto' for color space on profile 'None'
    • Video: x264, x264 - added 'adjust gop max to output fps'
    • Ui: changed maximize handling
    • Ui: option to set debug output path
    • Vapoursynth: add masking for frame matching
    • Vapoursynth: added FTF to TIVTC
    • FFmpeg: don't set color signaling for pipes
    • Avisynth: added 'Never use AviSource'
    *fixed*
    • Avisynth: enable avsToon for 32bit
    • Video: x264 minimizeCL with 'superfast'
    • Vapoursynth: FileQueue and Masking issues
    • Vapoursynth: ReplaceSince
    • Vapoursynth: torch - remove unnecessary resize call after VSGAN
    • Extraction: use ffmpeg for ProRes from mkv extraction
    • Video: SVT-AV1 typo 'enableResotration' vs 'enableRestoration'
    • Vapoursynth: SMDegrain smdegrain.py script interlaced handling fixed
    • Vapoursynth: mlrt - DPIR FP16 inverted
    • Video: NVEnc - max bitrate initial value
    • Video: NVEnc - EdgeLevel not added to command line
    • Input: Zip format handling (ffmpeg and analysis)
    • Synh: fix typo in CustomSynthScript QQDFPlus and abcxyz YUVALLX -> ALLYUVX
    • Vapoursynth: QTGMC in CompareView with 'custom', use Preset='Fast' for original side.
    • Vapoursynth: torch, VSGAN (Filter), width/height mixup
    • Vapoursynth: torch, DeOldify 'render_vivid' and 'dark' passed as string instead of bool
    • Vapoursynth: SmoothGrad fix min value 1
    • Vapoursynth: Frame->Resize UI scaling
    • Vapoursynth: torch, ProPainter 'Inference'-CheckBox not working
    • Vapoursynth: cfhd handling
    • Vapoursynth: SSIMD: fix output color
    • Vapoursynth: letterboxing YUV422 mod2
    • Vapoursynth: vsRemoveDirt defaults
    • Video: FFmpegs zscale-call for PNG output
    • Video: x264 slow preset using b-adapt 2 instead of 1
    • FFmpeg: 2020 signaling
    • Extract: vp9 video
    • Model: loadfromJson respect skipList
    • Avisynth: TIVTC+QTGMC
    • Avisynth: fix histogram color restriction check, no YUY2 support
    • Avisynth: QTGMC+Custom+UltraFast missing YadifMod2 dependency
    • Avisynth: DeblockPP7 and aSharp were unnecessarily disabled for 64bit Avisynth
    • Video: ProRes encoding when mencoder is used as decoder
    • Vapoursynth: DecimateMode set output fps for mode 2, which is (still) broken
    • Vapoursynth: RainbowSmooth require mod16
    • Vapoursynth: don't try to set ColorMatrix on RGB content
    • Vapoursynth: DGSharpen requires mod16
    • Vapoursynth: rectangular mask for high bit depth
    • Decoder: changed Avisynth input handling
    • Muxing: mkv helper for ffmpeg color matrix and vfr
    • Jobs: fix cleanup job handling on raw audio only output
    • Jobs: fix warning handling
    *added*
    • Vapoursynth: GLSL Gamma, RGBAdjust filter ports(Levels broken&disabled)
    • Vapoursynth: proToon
    • Vapoursynth: vs_temporalfix
    • Vapoursynth: torch/vmlrt option to set (trt) 'engine path'
    • Avisynth: added CustomSynthScripts for 32bit and 64bit proToon-v0.75.1
    • Generate output name suffix added '%DATE%','%TIME%','%TIMEMS%' replacements
    • Vapoursynth: torch - add vs_colorfix for VSGAN and VSGANFilter
