  • 2024.06.09.1:
    *aded*
    • Vapoursynth: torch, ProPainter
    *changed*
    • Vapoursynth: torch, adjusted to DeOldify 0.3.5.3
    • Filtering: remove 'none' as auto deinterlacer handling option
    • Video: NVEnc support --tflevel --lookahead-level
    *fixed*
    • Vapoursynth: another EEDI3/EEDI3CL handling
    • Vapoursynth: Masking for RGBH filters
    • QSVEnc: remove '--tier' during hevc encoding
    • QSVEnc: set '--output-csp' (this is broken for most choices)
    • Jobs: QSVEnc av1 encoding in webm
    • Vapoursynth: torch, DeOldify fix FP16
    • Vapoursynth: TFM/VFM, fps refresh
    • Avisynth: custom with dual view
    • Avisynth: interlaced output + cropView
    • x265: 3.0 and 4.0 vbv values not set
  • 2024.06.15.1:
    *added*
    • Vapoursynth: support CPreview from hello_hello
    *changed*
    • Vapoursynth: torch, adjust to DeOldify 4.0.0
    • Vapoursynth: torch, adjust to vsRealESRGAN 5.0.0
    • Vapoursynth: reworked FillDuplicateFrames, FillDrops, ReplaceSingle into one class for stability
    • Vapoursynth: vs-mlrt, RIFE scale support optional requires 'onnx' in Vapoursynth/Lib/site-packages, see: https://github.com/AmusementClub/vs-mlrt/issues/94
    *fixed*
    • Vapoursynth: do not change color matrix on RGB content
    • Vapoursynth: fixed some unnecessary, popups during startup
    Ps.: deinstall old version before installing this one.
  • *2024.09.29.1:
    *changed*
    • Vapoursynth: SoftLight require PC scale when mode != 8
    • Vapoursynth: updated RIFE, RIFE(mlrt)
    • Vapoursynth: use constants for Matrix, Primaries, Chroma, Luma
    • Video: NVEnc/QSVEnc support --vpy-mt
    • Jobs: add abort-option to size- and audio-warning onjo create&start
    • Jobs: added scripts to report file
    • Video: removed NVEnc input type checks
    • Filtering: hide deinterlace control on progressive input, since it confuses users
    • Avisynth: FFmpeg2Source use YUV422PX instead of YUY2
    • Avisynth: increased suported memory max to 65536MB
    • Avisynth: Hybrid now comes without Avisynth 32bit support, it is an addon now
    • Video: do not check for UT Video, assume its present
    • Vapoursynth: prefer BestSource as default for file input
    • Vapoursynth: torch - added 'Requires'-controls to VSGAN and VSGAN Filter
    • Input: Switch from Vapoursynth to Avisynth (when available) on .avs input
    • Vapoursynth: TemporalDegrain2: degrainTR default and crash with degrainTR=0
    • Video: x264, disable and deactivate 'auto' for color space on profile 'None'
    • Video: x264, x264 - added 'adjust gop max to output fps'
    • Ui: changed maximize handling
    • Ui: option to set debug output path
    • Vapoursynth: add masking for frame matching
    • Vapoursynth: added FTF to TIVTC
    • FFmpeg: don't set color signaling for pipes
    • Avisynth: added 'Never use AviSource'
    *fixed*
    • Avisynth: enable avsToon for 32bit
    • Video: x264 minimizeCL with 'superfast'
    • Vapoursynth: FileQueue and Masking issues
    • Vapoursynth: ReplaceSince
    • Vapoursynth: torch - remove unnecessary resize call after VSGAN
    • Extraction: use ffmpeg for ProRes from mkv extraction
    • Video: SVT-AV1 typo 'enableResotration' vs 'enableRestoration'
    • Vapoursynth: SMDegrain smdegrain.py script interlaced handling fixed
    • Vapoursynth: mlrt - DPIR FP16 inverted
    • Video: NVEnc - max bitrate initial value
    • Video: NVEnc - EdgeLevel not added to command line
    • Input: Zip format handling (ffmpeg and analysis)
    • Synh: fix typo in CustomSynthScript QQDFPlus and abcxyz YUVALLX -> ALLYUVX
    • Vapoursynth: QTGMC in CompareView with 'custom', use Preset='Fast' for original side.
    • Vapoursynth: torch, VSGAN (Filter), width/height mixup
    • Vapoursynth: torch, DeOldify 'render_vivid' and 'dark' passed as string instead of bool
    • Vapoursynth: SmoothGrad fix min value 1
    • Vapoursynth: Frame->Resize UI scaling
    • Vapoursynth: torch, ProPainter 'Inference'-CheckBox not working
    • Vapoursynth: cfhd handling
    • Vapoursynth: SSIMD: fix output color
    • Vapoursynth: letterboxing YUV422 mod2
    • Vapoursynth: vsRemoveDirt defaults
    • Video: FFmpegs zscale-call for PNG output
    • Video: x264 slow preset using b-adapt 2 instead of 1
    • FFmpeg: 2020 signaling
    • Extract: vp9 video
    • Model: loadfromJson respect skipList
    • Avisynth: TIVTC+QTGMC
    • Avisynth: fix histogram color restriction check, no YUY2 support
    • Avisynth: QTGMC+Custom+UltraFast missing YadifMod2 dependency
    • Avisynth: DeblockPP7 and aSharp were unnecessarily disabled for 64bit Avisynth
    • Video: ProRes encoding when mencoder is used as decoder
    • Vapoursynth: DecimateMode set output fps for mode 2, which is (still) broken
    • Vapoursynth: RainbowSmooth require mod16
    • Vapoursynth: don't try to set ColorMatrix on RGB content
    • Vapoursynth: DGSharpen requires mod16
    • Vapoursynth: rectangular mask for high bit depth
    • Decoder: changed Avisynth input handling
    • Muxing: mkv helper for ffmpeg color matrix and vfr
    • Jobs: fix cleanup job handling on raw audio only output
    • Jobs: fix warning handling
    *added*
    • Vapoursynth: GLSL Gamma, RGBAdjust filter ports(Levels broken&disabled)
    • Vapoursynth: proToon
    • Vapoursynth: vs_temporalfix
    • Vapoursynth: torch/vmlrt option to set (trt) 'engine path'
    • Avisynth: added CustomSynthScripts for 32bit and 64bit proToon-v0.75.1
    • Generate output name suffix added '%DATE%','%TIME%','%TIMEMS%' replacements
    • Vapoursynth: torch - add vs_colorfix for VSGAN and VSGANFilter
  • 2024.12.21.1:
    *changed*
    • Analysis: extended workaround for MakeMKV muxed content
    • Muxing: support FLAC in mp4
    • Vapoursynth: moved EdgeFixer and BalanceBorder to Frame->Edge
    • Vapoursynth: vs-mlrt/torch - removed mod restrictions for TensorRT when using RIFE
    • Vapoursynth: ColorFix add wavelet mode
    • Input: support dpx as image sequence
    • Vapoursynth: torch - DeOldify 4.5.0
    • UI: make Hybrid Window resizable
    • Video: svtav1 support quant matrices
    • Video: x264 - set '--slices 4'
    • Avisynth: amDCT 64bit support
    • Vapoursynth: changed filter specifc 'flip vertical' into generic gimmick option
    • Hardware: support more data server graphic cards
    *fixed*
    • Vapoursynth: torch - VSGAN(Filter) + ColorFix
    • Jobs: Chunked encoding crash with whitespace in file path
    • Decode: FFmpeg color matrix handling
    • Vapoursynth: torch - machine learning resizers and FilterQueue
    • Vapoursynth: don't use stepped resize when Vapoursynth->Frame->Resize->Resizer is disabled)
    • Decode: AutoCrop for DVD with spaces in the path; missing quotes
    • Video: FFVNEnc presets
    • Filtering: disable 'Filtering->FFmpeg' for 'Only use encoder'
    • Decoder: set vui params for input on FFmpeg
    • Avisynth: Separate Fields filtering
    • Avisynth: typo in ProToon 32bit custom addition
    *added*
    • Vapoursynth: torch - added ColorFix for SCUNet
    • Vapoursynth: torch - added vs-mfdin
    • Vapoursynth: vsmlrt - added ColorFix for SCUNetmlrt (requires torch addon)
    • Vapoursynth: vsmlrt - added ColorFix for VSMLRT (requires torch addon)
    • Vapoursynth: vsmlrt - fix 'Multi' for VSMLRT
    • Vapoursynth: torch - fix 'Multi' for VSGAN
    • Vapoursynth: support Bore, FillBorders
  • 2025.03.09.1:
    *changed*
    • Video: NVEncC - support tune uhq
    • Vapoursynth: torch updated RealESRGAN, RIFE
    • Vapoursynth: torch update DeOdify (old saved settings might not work as expected in new version)
    • Monitor: monitoring folder "-autoAdd addAndStart" case insensitive.
    • Vapoursynth: switch RemoveDirt port by pinterf
    • Vapoursynth: torch - disable DDD 'DfConvEkSA' due to dependency problems (openmim + newer Pytorch)
    • Vapoursynth: torch - renamed vsDeoldify to HAVC, removed 'custom' preset/speed option
    • Vapoursynth: added Rotate, PreColor to 'Gimmick'-controls
    • Vapoursynth: removed dependency to librife_r9_mod_v6
    *fixed*
    • Vapoursynth: torch - vsCodeFormer with FilterQueue set num_batches
    • Vapoursynth: reinterlace indention
    • Vapoursynth: make sure to adjust resolution for preview when custom section changed it
    • Vapoursynth: fixed BinarMask GrayMask bit depth calculation
    • Video: NVEncC - H.265&H.264 lossless support detection
    • Video: FFNVEnc - H.265 profile
    • Vapoursynth: mlrt resizers were not removed from the resizer list, even when vs-mlrt wasn't installed
    • Vapoursynth: output luma singaling updateing
    • Analysis: audio detection problems when reported order of streams were different in mediainfo and mplayer
    • Muxing: added workaround for mp4fpsmod issue
    • Avisynth: d2vSource can't use 'fieldop'
    *added*
    • Vapoursynth: torch - RealESRGAN 1x scale filter
    • Vapoursynth: vs-mlrt - vsMLRTFilter
  • Ich hätte da mal eine Frage aus dem Dunstkreis ffmpeg/libAV/LAV und "PAL Quelle" ... es gehört nicht wirklich in diesen Thread, aber hier gibt's vielleicht Leute die etwas wissen. :) - Beitrag darf gerne verschoben werden wenn's so besser sein sollte.
    Kennt jemand das Problem: es gibt so unzälig viele der sog. "One-Klick-Converter", die allesamt auf den ffmpeg/libAV Bibliotheken basieren. Hat man nun einen PAL 25/50Hz Input, lässt diesen ggf. noch deinerlacen und dann ein *.mp4 erstellen, dann bekommt man in den meisten Fällen kein 25 oder 50Hz Ergebnis, sondern entweder 29.97 oder 23.976 fps. Oder noch seltsamere Framerates die leicht von diesen abweichen, und das Ergebnis ruckelt mehr oder weniger schlimm.
    Ich hab' früher immer alles von Hand gemacht (DGsource > Avisynth > x264, Muxen mit MKVmerge). Dann hab ich's mal mit den One-Click-Dingern probiert, hab' graue Haare bekommen und den Glauben an die Welt verloren, und weiterhin alles von Hand gemacht. Ob's Hybrid richtig macht weiß ich gar nicht (aber ich hoffe doch mal schwer, dass!), es ist wohl auch schon >10 Jahre her dass ich Hybrid zuletzt benutzt habe ... :/
    Jedenfalls: ganz grundsätzlich, kennt jemand das Problem über das ich hier jammere? Mich hat das wie gesagt schon vor >10 Jahren vergrault, und wenn ich mich heute in anderen Foren umschaue in denen ganz viele Videos von TV-Aufnahmen gepostet werden, dann sind die immer noch fast alle genau so vermurkst.
  • Kann nicht sagen, dass ich das Problem wirklich kenne.
    Mögliche Quellen für das Problem:
    • vfr (Quelle eventuell wird als vfr gehandelt, weil sie von MakeMKV oder einem andern Tool merkwürdig geflagged wurde)
    • Probleme mit dem Source filter/decoder und der Quelle (manche Dateie gehen nicht ordentlich mit software decoding und andere gehen nicht ordentlich mit allen hardware decodern)
    • falsch geflaggte Quelle
    • falsche Bedienung des Users (sRestore oder vergleichbares wird pauschal angewendet)
  • 2025.11.08.1:
    *changed*
    • Vapoursynth: allow multiple in-/outputs in custom sections
    • Vapoursynth: adjusted to Anime4k v3
    • Vapoursynth: SCUNet FP16 support
    • Vapoursynth: luma scaling handling
    • Vapoursynth: FilterQueue + Deinterlace
    • Vapoursynth: filter support simplification
    • Vapoursynth: vsMLRTFilter/vsVSGANFilter: configure undo-resizer (torch/mlrt)
    • Vapoursynth: vsDPID: support RGBS
    • FFmpeg: speedChange set '-r' before and after input
    • Vapoursynth: adjust to HAVC update (torch)
    • Vapoursynth: support dynamic shapes (mlrt)
    • Vapoursynth: ResampleHQ HDR option
    • Vapoursynth: torch BasicVSR++ filter scene_aware
    • tons of code refactored
    *fixed*
    • Vapoursynth: FilterQueue + Interpolate or TDecimate filter
    • Vapoursynth: vs-mlrt. VSMLRT-Filter call
    • NVEnC: maxFALL not properly read from input
    • Monitoring: handling of monitored inputs
    • Vapoursynth: mclean tcanny dependency
    • Vapoursynth vsSantiagAA limit range 0-128
    • Vapoursynth: vsCCD typo temporal_radius
    • Audio: limitAudioAll lang/type controls
    • Vapoursynth: converting to RGB force pc scale
    • Vapoursynth: SSMD on HDR content
    Ps.: Dropped Ubuntu package release, created an AppImage which hopefully works.
  • Großteil liegt an:
    • den Vapoursynth Filtern (3,23GB) , insb.
      • RIFE mit 1,45GB.
      • DFTTest2 mit ca. 366MB
      • BilateralGPU ca. 93MB
      • TimeCube&Co ca. 465MB (da viele .cube files enthalten sind)
    • Encoder&Co ca. 1GB (da nicht gepackt; 200MB allein für NVEncC)
    • Avisynth 64bit ca. 324MB
    [Blocked Image: https://i.ibb.co/pr0XW1m6/grafik.png]
    Hybrid selber ist ca. 30MB groß und dazu kommen ca. 50MB an dlls.
    Und falls man dann die Add-ons noch installiert, wird es halt noch größer. :)
    Der Großteil geht halt vor allem für die GPU basierten Filter und ihre Abhängigkeiten drauf.
    => Problem ist halt zu entscheiden: Was sind 'die gänigsten tools' ?
    Ps.: Mein Hybrid-Ordner mit den AddOns und ein paar anderen Sachen (u.a. mehr modelle für vsgan&vsmlrt) ist entpackt ca. 80GB groß. :P
  • also ich persönlich verwende Hybrid als einfachen transcoder von filmen,
    und da nur primär die videospur.
    keine aufwänigen reperatur/optimierungsmaßnahmen.
    MP4(h264+aac/ac3) für hardware player. (h265 wenn jemand unbedigt UHD haben will)
    MKV(AV1+aac/opus) für android, bzw. zukünftige hardwareplayer.
    primär für PC optimierte videos codiere ich nicht mehr, seit NVEnc wahnsinnig schnell bei AV1 ist. :D
    Beispiele:
    Video:
    NVEnc, x264, x256, AV1: aomenc
    Audio:
    eigendlich alle Audiocodecs, primär aber: AAC, OPUS, AC3
    bei AAC, der FDK würde reichen?
    beim filtern bräuchte ich nur einen filter, in den diversen filtergruppen.
    z.b. in DeNoice: 'QTGMC' verwende ich, weil er presets hat,
    bei allen andern habe ich überhaupt keine ahnung was ich überhaupt einstellen soll...
    das sind nur so meine gedenken,
    falls du hybrid mal entschlacken willst.
    mir ist aufgefallen, das kein MPEG2 für DVD-Video dabei ist.
    wobei, seit ich HD-Videos für hardwareplayer codiere, ich keine DVD mehr erstellt habe... ;)
    der codecs wie der VVC codec, sind zwar vorhanden, aber nicht in der auswahl gelistet,
    hat das ein grund?
    Ja, mpeg-2 als Output wird nicht unterstützt.
    Da ich kaum Ahnung habe, was ein guter freier MPEG-2 encoder ist, wie man ihn ordentlich einstellt und den ContainerOverhead von Audio&Video berechnen würde in unterschiedlichen Containern.
    hat das ein grund?
    Hatte mal angefangen dafür Code zu schreiben, ihn aber bis dato nicht aktiviert.
  • Goldwingfahrer hatte vor ca. 15 Jahren schon einmal einen Bildtest von fast allen Encodern gemacht, die es auf dem Markt damals gab. Darunter war auch der Rozet (5000 €) von Grass Valley, und ist der große Bruder von ProCoder 3. Gegenüber dem ProCoder 3, hatte der Rozet keine bessere Bildqualität, bietet aber eine bessere Abarbeitung von Metadaten.
    Der Cinema Craft Encoder, der mehr für den Profi-Bereich gedacht war, hatte eine gute Bildqualität, hatte aber am schnellsten encodiert von allen Encodern. In der Bildqualität, waren aber der ProCoder 3 und der Sorenson Squeeze ab Version 6 besser.
    2008 war das letzte Jahr, bei dem die Algorithmen für SD-Material verbessert wurden. Seitdem werden im SD-Bereich keinen neuen Algorithmen für SD-Streams mehr aktuallisiert, da SD ausstirbt. Das gilt für alle Hersteller von Encodern.
    Der Encoder von Adobe, der den sehr guten Codec Main Concept verwendet, war in der Bildqualität ganz leicht schlechter und brauchte mehr Zeit zum encodieren, als der ProCoder oder der Squeeze. Das lag aber nicht am Codec.
    Laut Goldwingfahrer hatte aber der HC-Enc die beste Bildqualität. Damals war das die Version HC 021. Die Profi-Encoder Cambria und Telestream aus Hollywood wurden nicht geprüft, da diese viel zu teuer waren (ca. 30.000 €).
    Hybrid und XMedia Recode sind aber auch gute Encoder. Ich kann jetzt nur das schreiben, was ich aus der damaligen Zeit noch weiß.
    HQ-LQ, wenn du Interesse hast, einmal den Squeeze auszuprobieren, dann kann ich dir für die Version 8.5 eine legale Lizenz anbieten. Squeeze arbeitet auch Scripte, z. Bsp. mit QTGMC ab, wandelt auch 5.1 und 7.1 zu Stereo. Squeeze kostete damals 900 €.
  • Squeeze ist ein selbstständiger Encoder mit Benutzeroberfläche, ist schon eine GUI, kein Kommandozeilenprogramm. Die Algorithmen von ProCoder und Squeeze sind für den Studioeinsatz gedacht, darum haben diese beiden Encoder Codecs, die kompatibler sind, als die von anderen Encodern. Daher kosten diese Software-Encoder so viel Geld. Aber wenn du bei HC 028 bleiben willst, dann verstehe ich das.
    FFmpeg:
    Ich kann jetzt nur darüber schreiben, was ich noch weiß. FFmpeg verwendete ich auch einmal vor ca. 15 Jahren. Die Codecs bieten eine gute Bildqualität und viele Einstellungen. Die meisten Codecs stammen von Google. Das gilt auch für Linux. Als ich im Netz gelesen habe, dass das Programm sämtliche Daten von den eigenen Videostreams zu Google sendet, habe ich die Software sofort deinstalliert. Das geht gar nicht. Es muss jeder selber entscheiden, ob er das möchte.
