Hybrid (Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
  • Hybrid rev 2018.10.07.1:
    *fixed*
    • Filtering: FFmpeg deinterlacer
    • Output: File name generation using chapter names
    • Subtitle: convertion from ass -> txt
    • Vapoursynth: Histogram in Preview
    • Windows: progress indication after minimize and restore
    *changed*
    • Adjusted to QSVEncC 3.09 (Windows only)
    • Analysis: subtitle analysis through MediaInfo, due to changes in MediaInfo
    • Analysis: ignore audio languages which are not ISO 3166-1 alpha-2/3 conform
    • Analysis: handling apcm_adx audio in mpeg container, since MediaInfo reports this wrong atm.
    • Avisynth: set output depth explicitly
    • General: Close Hybrid on Windows in case it's running with administrator rights.
    • General: monitoring and file input.
    • Misc: misc.ini got an 'runAsAdmin' option, if you use it don't complain in case Hybrid messes up your system
    • Tags: tags clearing on file change.
    • Video: Removed NVEnc MB check, since NVEncC doesn't read max MB and doesn't report it anymore (Windows only)
    *added*
    • Filtering: FFmpeg vidstab support
    • Vapoursynth: mClean
    • Video: NVEnc, key-frames on chapter start option (Windows only)
    • Video: QSVEnc HDR signaling support (Windows only)
    • Video: AV-1 support through aomenc and rav1e
    *removed*
    • Filtering: 'mcdeint' support since it was removed from mencoder/mplayer
    Ps.: Not releasing any Mac versions for the time being. (I don't have access to a mac anymore.)
  • Hybrid rev 2018.10.21.1:
    *fixed*
    • Analysis: mediainfo dts-hd detection
    • Input: Input par not properly reset when 'Input PAR' was manually changed for previous source
    • Audio: output created in temp folder in some cases with audio only output
    • Video: splitting an mkv with split chapter, deleting of temp file
    • Jobs: minimize job description for webm muxing
    • Filtering: crash when using ToneMap (No XSynth)
    • Video: crash when changing values in 'ffmpeg (NVEnc)'
    *changed*
    • Video: AV1, adjusted aomenc bit-depth and color sampling restrictions
    • Cosmetics: x265, finer control over qcomp
    • Input: disabling crop when loading a new single source and autocrop isn't enabled
    • Input: disabling 'convert output par to' when loading a new single source
    • Output: support mkv(av1), mp4(av1), mp4(vp9) (requires latest mkvmerge and mp4box)
    • Vapoursynth: updated to R45
    *added*
    • Video: NVEncC, trim used with cut (Windows only)
    • Video: NVEncC, only add VUI parameters when they are enabled (Windows only)
    • GUI: Added warning when drivers seem to be too old to work with NVEncC (Windows only)
    • Vapoursynth: HDRToSDR by DG support (Windows only)
