r3814
ZitatAlles anzeigenRevision 3814 - Directory Listing
Modified Mon Apr 11 14:05:03 2011 UTC (31 hours, 50 minutes ago) by clsid2Updated Libav
Revision 3813 - Directory Listing
Modified Fri Apr 8 20:44:26 2011 UTC (4 days, 1 hour ago) by clsid2Added LAVSplitter GUIDs
Revision 3812 - Directory Listing
Modified Fri Apr 8 20:41:42 2011 UTC (4 days, 1 hour ago) by clsid2Updated Libav
Revision 3811 - Directory Listing
Modified Wed Apr 6 12:04:28 2011 UTC (6 days, 9 hours ago) by clsid2Updated Libav
Revision 3810 - Directory Listing
Modified Tue Apr 5 16:29:12 2011 UTC (7 days, 5 hours ago) by clsid2Updated Libav
Revision 3809 - Directory Listing
Modified Tue Apr 5 16:07:57 2011 UTC (7 days, 5 hours ago) by clsid2Updated yadif
Revision 3808 - Directory Listing
Modified Tue Apr 5 11:39:08 2011 UTC (7 days, 10 hours ago) by clsid2Fix broken audio with libavcodec
Revision 3807 - Directory Listing
Modified Mon Apr 4 14:56:42 2011 UTC (8 days, 6 hours ago) by clsid2Updated Libav
Revision 3806 - Directory Listing
Modified Mon Apr 4 14:39:46 2011 UTC (8 days, 7 hours ago) by clsid2Fix crash in 3804
Revision 3805 - Directory Listing
Modified Mon Apr 4 12:28:38 2011 UTC (8 days, 9 hours ago) by clsid2Updated Libav
Revision 3804 - Directory Listing
Modified Mon Apr 4 09:12:32 2011 UTC (8 days, 12 hours ago) by clsid2Updated Libav
Revision 3803 - Directory Listing
Modified Sat Apr 2 08:31:42 2011 UTC (10 days, 13 hours ago) by tal_aloniGUI fix in audio output dialog page.
Added DTS-HD subtypes to filter registration (Thanks babgvant).Revision 3802 - Directory Listing
Modified Fri Apr 1 21:50:28 2011 UTC (11 days ago) by tal_alonifixed a bug preventing the bitstreaming of DTS core tracks of DTS-HD over S/PDIF.
Revision 3801 - Directory Listing
Modified Wed Mar 30 09:22:46 2011 UTC (13 days, 12 hours ago) by tal_aloniJapanese translation update
Revision 3800 - Directory Listing
Modified Mon Mar 28 19:59:58 2011 UTC (2 weeks, 1 day ago) by clsid2Fixed regression in 3765 that broke thumbnailing in Explorer
Revision 3799 - Directory Listing
Modified Mon Mar 28 18:15:47 2011 UTC (2 weeks, 1 day ago) by clsid2Updated Libav
Revision 3798 - Directory Listing
Modified Mon Mar 28 11:32:15 2011 UTC (2 weeks, 1 day ago) by tal_aloniUpdated Czech translation
Revision 3797 - Directory Listing
Modified Mon Mar 28 11:28:00 2011 UTC (2 weeks, 1 day ago) by tal_aloniUpdated Czech translation for installer
Revision 3796 - Directory Listing
Modified Mon Mar 28 11:17:23 2011 UTC (2 weeks, 1 day ago) by tal_aloniUpdated Japanese translations (credit goes to tnetsixenon)
Revision 3795 - Directory Listing
Modified Sun Mar 27 10:58:58 2011 UTC (2 weeks, 2 days ago) by tal_aloniRussian translation fix (credit goes to arestarh)
Revision 3794 - Directory Listing
Modified Sat Mar 26 19:58:37 2011 UTC (2 weeks, 3 days ago) by tal_aloniUpdated German language files (credit goes to fastplayer)
Revision 3793 - Directory Listing
Modified Sat Mar 26 15:00:22 2011 UTC (2 weeks, 3 days ago) by XhmikosRremove the workaround for ISPP, also IS is sufficient since ISPP is included in the normal package
Revision 3792 - Directory Listing
Modified Sat Mar 26 12:31:11 2011 UTC (2 weeks, 3 days ago) by tal_aloniGUI fix (subtitle placement configuration)
Bug fix: "on screen resolution match" preset autoload condition setting has not been savedRevision 3791 - Directory Listing
Modified Sat Mar 26 11:56:26 2011 UTC (2 weeks, 3 days ago) by tal_aloniGUI: several fixes (resize & aspect configuration)
Revision 3790 - Directory Listing
Modified Fri Mar 25 22:23:28 2011 UTC (2 weeks, 3 days ago) by tal_alonidisabled menu option to expand video output size for subtitles when configuring DXVA (we can't change output resolution when decoding using DXVA)
Revision 3789 - Directory Listing
Modified Fri Mar 25 21:38:32 2011 UTC (2 weeks, 4 days ago) by tal_aloniEnabling of Substation alpha subtitles is now a preset dependent setting.
Revision 3788 - Directory Listing
Modified Fri Mar 25 20:46:12 2011 UTC (2 weeks, 4 days ago) by tal_aloniGUI: several typos were fixed (credit goes to fastplayer)
Revision 3787 - Directory Listing
Modified Thu Mar 24 15:30:05 2011 UTC (2 weeks, 5 days ago) by clsid2Updated Russian translation by arestarh
Revision 3786 - Directory Listing
Modified Thu Mar 24 13:01:20 2011 UTC (2 weeks, 5 days ago) by tal_aloniDXVA video decoder is now an optional component
