DGDecNV: CUDA-basierter Multi-Decoder für AviSynth
  • DGDecNV 2037 [Dec 02, 2010]
  • DGDecNV 2038 [Jan 29, 2011]
    Bei mir Läuft zurzeit DGDecNV 2037 ohne Probleme.
    Diese neue DGDecNV 2038 startet kurz und beendet sich wider. (32Bit Version) Bug?
  • Build 2039
    * The info overlay DGSource(debug=true) was modified so that IDR and I frames are
    now properly distinguished.
    * The DGI file format was modified to add a frame number indication to the FRM lines.
    The file format version number was not bumped because 2039 is backward compatible with
    DGI files created with 2038.
    * Worked around a CUVID decoding bug for MPEG2 dual prime prediction. The workaround should
    also improve decoding performance for mid- and high-end graphics cards.
    * Added an error popup to notify users when successive IDR frames with the same idr_pic_id are
    encountered. This is an illegal stream condition and results in loss of IDR frames.
  • Build 2040
    * Fixed a problem with Info display of frame structure.
    * The code that suppresses nondisplayable frames at the end of an AVC stream was
    not robust, i.e., it failed if the first GOP contained only one frame. Fixed.
    * Added a workaround that fixes AVC streams that have successive IDRs with the
    same value of idr_pic_id. This fixes frame dropping for these streams.
    * Fixed incorrect picture display when navigating on the timeline with
    double-rate deinterlacing enabled.
    * The disabled state of the single-step button was solid instead of the correct hollow. Fixed
    * A rewind (to start of project) button and corresponding menu item were added.
    Support is via http://neuron2.net/board/viewforum.php?f=8
  • Build 2041
    Link: http://neuron2.net/dgdecnv/dgdecnv.html
  • Build 2042
    * Fix broken audio demuxing from interlaced VC1 streams.
    * Some streams were encountered that had all I frames but for which the
    GOPs were marked as open. This was fixed so that the GOPs are considered closed.
    * Added support for GTX680 (Kepler). This required moving to CUDA 4.2,
    so some notebook/OEM drivers may be impacted.
    Edited once, last by LigH: Changes.txt anstatt Readme.txt (July 25, 2012 at 8:47 AM).
  • Für Build 2047 testet Donald Graft eine neue Lizensierungsmethode. Bitte ausprobieren und eventuelle Probleme umgehend melden.
