Projekt-Homepage/Blog (1f0.de)
Projekt-Downloads und -Quellen (Google Code)
Changelog
Diskussionsthema (doom9-Forum)
Diskussionsthema (Gleitz-Forum)
Aktuelle Version: 0.54.1 - 2012/11/27
[size=8]LAV DirectShow Filters Changelog
0.54.1 - 2012/11/27
LAV Splitter
- Improved seeking in MP4 files created by Windows Live Movie Maker
LAV Video
- Improved H.264 DXVA on recent Intel GPUs (Sandy/Ivy Bridge and newer Atoms)
- Fixed corruption with high number of reference frames ( > 11 )
- Fixed corruption in MBAFF interlaced content
- Fixed an issue that caused DVD menus/subtitles to stop working in DXVA2 Native mode in some situations
0.54.0 - 2012/11/24
LAV Splitter
- Subtitle selection in "Default" mode now properly takes the "Default Track" flag into account
- Fixed an issue that could cause graph flush events to be send out of sync
LAV Video
- The DXVA2 Native decoder can now properly detect hardware support for video resolutions
- Allows 4K DXVA2 decoding on NVIDIA
- New options to control which resolutions are being handled by the hardware decoder (SD, HD and 4K/UHD)
- Added support for DVD menu overlays and DVD subtitles with DXVA2 Native
- Improved DXVA2 Native support with madVR
- Fixed a freeze when playing corrupted H.264 streams in DXVA2 Native
- Fixed a few rare DVD menu issues when using the QuickSync decoder
0.53.2 - 2012/11/11
LAV Video
- Fixed DVD menu still frames with DXVA2 Copy Back
- Fixed Live TV playback with QuickSync
0.53.1 - 2012/11/10
LAV Video
- Fixed initial media type when YADIF is active
- Fixed an image corruption issue with DVD playback
- Improved handling of DVD menus on some discs
- Reduced decode latency with CUVID/DXVA2-CB on DVDs for smoother playback in some situations
- Added an option to toggle HW decoding for DVDs
0.53.0 - 2012/11/05
LAV Splitter
- Added support for reading image files (tiff, png, jpeg, tga, bmp)
- Support for MPEG-4 ASP in MPEG-TS
- Support for reading metadata using the IAMMediaContent interface
- Fixed Aspect Ratio on some wmv/asf files
LAV Video
- Fixed a crash in the WMV9 DMO decoder on Windows 8
- DVD improvements
- Subtitles are properly cleared from the screen, and won't be shown forever on some discs
- Improved subtitle/menu positioning on some PAL discs
- Improved handling of still frame DVD menus
- Fixed a deadlock that caused the player to freeze in some DVD menus
- Improved quality of blending subtitles/menus
- QuickSync improvements
- Support using QuickSync in Fullscreen Exclusive mode (ie. in WMC)
- Improved fallback to software decoding if QuickSync is not available
- Support for DVD decoding
- Added support for Avid DV
- Properly indicate progressive video when YADIF deinterlacing is activated
LAV Audio
- Added proper DirectShow types and config options for AMR-NB, Nellymoser and various (AD)PCM variants
0.52.0 - 2012/10/20
LAV Splitter
- Improved IO performance on network sources
- Added an option to configure the maximum memory usage of the frame queues
- Support ALAC in MKV
- Support SRT subtitles in AVI
- Improved raw video support in combination with LAV Video
LAV Video
- Support for DVD Video decoding
- Slight GPU memory usage reduction with DXVA2 Native
- Fixed video corruption after seeks with VP3/Theora
- Fixed decoding of "old" H.264 4:4:4 lossless files
- More strict handling of output pixel formats, only enabled formats are allowed for output
- QuickSync: Improved compatibility with new driver series
- Improved support for VC-1 with the SageTV MpegDemux
LAV Audio
- Fixed a few issues with audio mixing
- Some channels would occasionally be mixed twice, causing incorrect audio levels
- Downmixing 8ch to stereo could crash on some systems
- Increased maximum LFE coefficient to 3.0 and fixed scale to be consistent with surround/center coefficients
- Added downmixing to Mono
- Clipping protection is no longer reset on seeks
- Added support for Opus
- Fixed excessive memory allocations when decoding MPEG4-ALS
0.51.3 - 2012/07/19
LAV Splitter
- Further improved H264 media type creation
LAV Audio
- Fixed an issue with the initial media types causing graph building failures in some situations
- Fixed a bug with DVBViewer which caused a delay on channel changes
0.51.2 - 2012/07/15
LAV Splitter
- Improved H264 media type creation with some files
- Fixed reading of QuickTime/AppleText chapters in MOV/MP4
LAV Video
- Reduced latency of H264 software decoding (improves Live TV playback)
- Fixed chroma handling of the YCgCo to RGB conversion
- Fixed timestamp handling of MPEG2 (regression introduced in 0.51)
LAV Audio
- Re-Mix audio as a fallback when the audio chain refuses a new channel configuration
- Fixed an error that caused 16-bit FLAC to show as 24-bit on the status panel
0.51.1 - 2012/07/10
LAV Video
- Improved compatibility between DXVA and certain DVB players
0.51.0 - 2012/07/09
LAV Splitter
- Increased IO responsiveness on high-latency network connections
- Improved timestamp handling for MPEG-PS (.mpg/.vob/.evo)
- Improved support for H264 streams in SSIF MPEG-TS files
- Added an option to control the priority of audio streams for the hearing/visually impaired
- Added new flags to the advanced subtitle selection
- "h" for hearing impaired
- "n" for normal streams (no flags)
- "!" NOT operator for inverting the meaning of the flags
LAV Video
- Improved DXVA2 Native to software fallback in some situations
- Support for YCgCo to RGB conversion
- Added a new smart Stream Aspect Ratio mode
- Will only use Stream AR when the container does not provide a realiable AR
LAV Audio
- Improved decoding performance of MP4 ALS and a few other formats
- Fixed playback of COOK with the MPC-HC RM Splitter
- Auto A/V Sync is now automatically disabled on pure-audio files to avoid potential conflicts
- Audio Down-Mixing support
0.50.5 - 2012/05/12
LAV Video
- Fixed a crash in DXVA2-Native decoding (introduced in 0.50.4)
0.50.4 - 2012/05/12
LAV Video
- Fixed seeking with QuickSync running in madVR Exclusive Mode
0.50.3 - 2012/05/11
LAV Splitter
- Fixed playback of raw PCM in AVI streams
- Fixed a rare misdetection of MPEG-2 as VC-1
LAV Video
- QuickSync: Fixed playback of some H.264 streams that would run out of sync on newer drivers
- Fixed a memory leak when playing H.264 RGB (and some other formats)
- Improved behaviour for H.264 and MPEG-2 on Live TV channel changes
LAV Audio
- Added support for Speex (via libspeex)
- Improved support for AMR-NB/WB (using OpenCore decoder)
0.50.2 - 2012/04/26
LAV Splitter
- Improved support for Playback Rates other then 1.0x
- Improved demuxing performance by implementing a custom Sample Allocator to avoid one extra memory copy
LAV Video
- Fixed a rare crash when using YV12 output on non-mod16 video
- Fixed excessive memory consumption with Haali Splitter and DXVA2-CB
- Fixed a deadlock on dynamic format changes with DXVA2 Native
- Added support for YV24 output
LAV Audio
- Support for ALAC and ALS with the MPC-HC MP4 splitter
- Improved A/V Sync on dynamic format changes
- Improved Auto A/V Sync Correction algorithm (lower threshold, faster reaction)
- Fixed audio pitch when bitstreaming 44.1KHz AC3/DTS
0.50.1 - 2012/03/29
LAV Splitter
- Fixed Stream Detection on some Blu-rays with short Logo clips before the main movie
- Fixed a crash when processing invalid/broken PGS subtitles
LAV Video
- Fixed a crash on dynamic format changes (stream change, Blu-ray clip change)
0.50 - 2012/03/27
LAV Splitter
- Improved support for H264 Elementary Streams
- Fixed a regression with seeking in MPEG-TS files recorded by some HD-PVR devices
LAV Video
- New Worker Thread design for Decoding/Deinterlacing
- WMV9+YADIF is up to 40% faster
- Improved DXVA2 for MPEG-2 interlaced
- Improved H264 DXVA2 on AMD with certain streams
- Improved CUVID support for 4K streams on supported hardware (GT520, GTX680, other VP5 hardware)
LAV Audio
- Added support for RealAudio Lossless (RALF)
0.49 - 2012/03/10
LAV Splitter
- Improved MKV demuxing performance from slow sources (network streaming, etc)
- Improved stream detection on Blu-rays
- Improved support for RealAudio (COOK, SIPR, etc) in MKV
- Support for streaming from HTTP URLs
LAV Audio
- Improved support for DTS files with Little-Endian or 14B encodings
LAV Video
- New VC1/WMV3 decoder based on the Microsoft DMO Decoder (new default)
- Updated Intel QuickSync decoder (0.29, r44)
- Fixed decoding of some MBAFF H264 streams with DXVA2
- Improved Stream Aspect Ratio logic in the CUVID decoder for H264 streams
- Fixed Deinterlacing when DXVA2 Native is active in certain situations
0.48 - 2012/02/24
LAV Splitter
- Improved Video/Audio stream detection in some MPEG-TS files
LAV Video
- Fixed a potential crash with native DXVA2 when the software fallback was used
0.47 - 2012/02/20
LAV Audio
- Fixed seeking in COOK audio with the MPC-HC RealMedia splitter
LAV Video
- New DXVA2 "native" decoder (see release notes)
- Updated Intel QuickSync decoder and tweaked configuration (0.28, r41)
- Overall performance improvements
- Multi-threaded decoding for Fraps
- Fixed a regression that resulted in only single-threaded playback on certain H264 files
- Fixed a crash in the CUVID decoder introduced in 0.46 under certain circumstances
0.46 - 2012/02/12
LAV Splitter
- Experimental support for streaming protocols (RTSP, RTP, MMS)
- Support for IBufferInfo (Buffer Status in MPC-HC "Statistics" pane)
- Added a memory limit to avoid too high memory use from the frame queues
- Fixed playback of files with Subtitles in WMP/WMC in some cases
LAV Audio
- Improved playback of files with bad audio frame interleaving
- Improved support of COOK, ATRAC and SIPR (RealAudio codecs)
LAV Video
- Updated and improved Intel QuickSync decoder (0.26, r38)
- Fixed DXVA2 software fallback on some lossless H264 clips
- Improved Fraps decoding with EVR
- Improved playback of MPEG4 in MP4
- Multi-threaded decoding for Lagarith
- Fixed playback of Theora with the MPC-HC Ogg Splitter
- Dithering Enhancements:
- New "Random Dithering" option (new default)
- Improved "Ordered Dithering" in the RGB converter
- Support for decoding v210/v410 raw formats
- Support for Snow and FFV1
0.45 - 2012/01/28
LAV Splitter
- Improved playback of concatenated H.264 MOV/MP4 files
- Adjusted FLAC MediaType to avoid ReClock stealing the connection
- Improved playback of MPEG-TS with timestamp discontinuities
LAV Audio
- Fixed playback of very short PCM samples
- Improved COOK decoding without LAV Splitter
LAV Video
- New DXVA2 "copy back" decoder (see release notes)
- Updated Intel QuickSync decoder (r29)
- Multi-threaded decoding for RV30/40, UtVideo and DNxHD
- Support for the "FCC" color matrix
- Improved Dirac support
- CUVID support for MPEG-4 ASP (experimental)
- Support for Intel Indeo 4, MS Video 1, 8BPS, LOCO, ZMBV, VCR1, AASC
0.44 - 2012/01/07
LAV Splitter
- Fixed a seeking regression in the mkv demuxer introduced in 0.43
- Fixed a bug that caused stream descriptions to vanish after the file finished playing
- Improved playback of WMVA video with commercial decoders
- Added support for the new OpenType MIME type produced by mkvtoolnix > 5.2.0
LAV Audio
- Fixed LATM AAC playback with some source filters
LAV Video
- Added Intel QuickSync hardware decoder
- Added support for YADIF with hardware decoding
- Added support for Dirac decoding
- Added support for DNxHD decoding
- Added support for v210/v410 output
- Improved dynamic reconnection with post-processing filters
- Fixed a seeking related corruption issue with MPEG4-ASP
0.43 - 2011/12/21
LAV Splitter
- Improved MKV seeking and demuxing performance
- Improved buffering for smoother playback (especially at start/after seeks)
- Fixed a few audio media type issues
- Fixed a minor resource handle leak
LAV Audio
- Updated to new ffmpeg audio decoding API
- Disabled Float Audio output on Windows XP by default
LAV Video
- Fixed handling of soft-telecined MPEG2/H264 broadcasts in CUVID mode
- Improved support for 4:2:2 10-bit streams
- Fixed a crash related to unaligned memory buffers on Windows XP
- Added support for decoding AMV streams
0.42 - 2011/11/30
LAV Splitter
- Fixed a timestamping bug in the new MKV demuxer
- Futher enhancements to explorer thumbnail generation
0.41 - 2011/11/29
LAV Splitter
- New MKV Demuxer (see release notes for details)
- Fixed a bug with the Vorbis Media Type
- Disabled Subtitles when generating Thumbnails in Explorer
LAV Video
- Fixed a overflow in 10 -> 8 bit dithering and NV12 output
0.40 - 2011/11/21
LAV Splitter
- Improved demuxing of raw PCM streams
- Fixed VC-1 in MP4 with the MS WMVideo Decoder
- Improved playback of files with TrueHD audio streams
- Added support for a requested stop time from the player
- Improved playback of Blu-ray rips created by EasyBD
- Added support for RGB24 raw video in AVI
LAV Audio
- Improved decoding of formats with extremely large audio frames
LAV Video
- Added YADIF software deinterlacing
- Rewritten Interlaced options
- Added new "Aggressive" deinterlacing mode
- Moved many interlaced related options to global level
- Fixed an issue with stream compatibility detection in the CUVID decoder, causing a software fallback when not required
0.39 - 2011/11/07
LAV Splitter
- Fixed a bug that caused MPEG-2 and VC-1 parsers to produce wrong timestamps after a seek
- Fixed playback of raw .h264 files
LAV Video
- NV12 is now the preferred YUV 4:2:0 output format
- Fixed handling of the "As Input" RGB output setting
- Improved VP6 cropping
- Don't report completely progressive movies as interlaced to the renderer
- Fixed playback of some broken MPEG-2 MKV muxes
- RGB will now by default be offered as Bottom-Up instead of Top-Down for improved compatibility
0.38 - 2011/11/01
LAV Splitter
- New subtitle selection options (see release notes or readme)
- Improved handling of languages with more then one ISO 639-2 code (f.ex. German, French, etc)
- Improved seeking to the start of the file
- Added support for VobSubs in MP4
- Added support for MKV nested chapters
- Improved playback of RV40 in MKV
- Improved support of H264 in WTV
LAV Audio
- Fixed a crash with raw audio and SPDIF processing
- Improved support for COOK
- Improved DTS-in-WAV detection
LAV Video
- Fixed a issue that caused MPC-HCs EVR-CP to produce wrong colors when using CUVID decoding
- Support Multi-Threading and CUVID decoding for MPEG-1
- Improve decoder flushing
- Fixed a potential freeze on load and dynamic type changes
- Fixed a freeze on seeking with certain VP8 files
- Added support for UtVideo
- Added support for H264 4:2:2
0.37 - 2011/10/06
LAV Splitter
- Improved handling of failures on the output pins
- Improved VC-1 in EVO timestamps
LAV Audio
- Added support for dynamic channel count changes in AAC
- Implemented support for sample format conversions
- Implemented Audio Delay options
- Disabled the WMA codecs by default
- Improved Bitstreaming data flow
LAV Video
- Fixed cropping of VP6 video
- New SSE2 YUV420 -> YUV422 converter
- Performance enhancements in the CUVID decoder on some systems
- Fixed playback with the XP Overlay Mixer
- Fixed a crash when decoding RGB video (Fraps, etc)
0.36 - 2011/09/29
LAV Splitter
- Improved support for ADTS AAC
- Fixed MPEG-2 timestamps in VOB
- Fixed MPEG-2 frame rate reporting for telecined/interlaced
LAV Video
- Integrated NVIDIA CUVID Hardware decoder
- Performance enhancements in 10bit decoding
- Support for Flash Screen Video (FSV1)
- Support for Apple ProRes
- Improved MPEG-2 playback
- Improved A/V sync with VC-1 and MPEG4-ASP
0.35 - 2011/09/07
LAV Splitter
- Fixed a crash in IAMStreamSelect::Info handling with certain applications
- Improve duration calculation for MPEG files
LAV Audio
- Fix playback of DTS streams which change the channel mid-playback
LAV Video
- Fixed a crash with 10-bit decoding and benchmarking tools
- Fixed a H264 NALU parsing issue with certain streams
0.34 - 2011/09/04
LAV Splitter
- Improve playback of VC-1 in EVO
- Support for SSA subtitles in AVI
- Support for H264 in VFW mode in MKV
LAV Video
- New optimized pixel format converters (faster and more accurate)
- New YUV->RGB converter
- Support for PNG video
0.33 - 2011/08/22
LAV Splitter
- Improved compatibility with the MS WMVideo decoder
- Fixed the mediatype for raw PCM streams
LAV Audio
- Added support for Vorbis streams demuxed by Haali and MPC-HC Splitters
LAV Video
- VC-1 decoding is now disabled by default
- Fixed behaviour of the Stream AR option
- The maximum number of decoding threads is now 16
- Free decoding buffers when the input pin disconnects to avoid big memory leaks
0.32 - 2011/08/19
General
- The installer will now add shortcuts to the start menu to open the filter configurations
- The ffmpeg DLLs have been renamed to carry a "lav" suffix to avoid collisions with other components
LAV Splitter
- Improved detection of AAC LATM tracks (previously mis-detected as mp1/mp2)
- Fixed playback of badly interleaved AVI files
- Smarter default stream selection for RealMedia files
- Improved stream language handling for Blu-rays
- Fixed a crash issue with the Forced Subtitle pin on Blu-rays
LAV Audio
- DTS decoding failures are now handled more gracefully
- Fixed Media Types for Stereo 44.1kHz Audio
LAV Video
- First official version - refer to release notes for details
0.31 - 2011/07/28
LAV Splitter
- Improved audio codec selection priorities
- Improved VC-1 playback when using the madVR internal decoder
- Improved playback of MPEG-TS files with a timestamp wrap right at the beginning of a file
- Reduced amount of data required for file probing, resulting in faster startup time
- Fixed demuxing/timestamping of RealMedia files
LAV Audio
- Fixed a bug in the DTS parser which caused occasional hiccups on DTS-HD content
- Added the ability to detect DTS-in-WAV
0.30 - 2011/07/15
LAV Splitter
- Improved VC-1 playback with ffdshow DXVA
- Added support for outputting MPEG-4 Timed Text subtitles (only pure text supported)
- Better support for MLP audio
- I/O performance enhancements
- Added an option to toggle how LAV Splitter handles audio stream switching
- Added a hard-limit on queue sizes to avoid excessive memory usage when transcoding
- Added an experimental interface for the Player to control graph rebuilding
LAV Audio
- Further improvements to the DTS-HD parsing
- Added more E-AC3 subtypes
0.29 - 2011/06/09
LAV Splitter
- The language code is now always shown in the stream changer (as a hint to easily know what to put into the preferred languages fields)
- Enabled ITrackInfo
- Improved H264 in MPEG-TS playback (including an option to try to fix broken HD-PVR recordings)
- Added a programmatic configuration interface for players to configure LAV Splitter
LAV Audio
- Added support for decoding encrypted DVD audio
- Fix decoding of some DTS-HD streams with the ArcSoft decoder
- Added a programmatic configuration interface for players to configure LAV Audio
0.28 - 2011/05/27
LAV Splitter
- Improved PGS filtering, forced subtitles should be cleared off the screen properly more often.
- Improved playback of H264 in MPEG-TS with certain files (mostly from camcorders, but some Blu-rays as well)
- Fixed 16-bit LPCM on DVDs
- Fixed the Media Types for uncompressed video
LAV Audio
- Added the ability to decode DTS Express when using the ArcSoft DTS Decoder
- Fixed missing audio after seeks with Ogg Vorbis
0.27 - 2011/05/24
General
- Added debug versions which generate log files on your desktop
LAV Splitter
- Fixed a memory leak when switching streams
- Increased probe buffer size (which results in files to be properly detected in more cases)
- Fixed playback of MPEG-TS files with a odd program configuration
LAV Audio
- Improvements to the DTS decoder interface
- Support for 1.1.0.0
- Try to reverse any channel upmixing done by the decoder, outputting the audio as close to the original source as possible.
- New Channel Mapping functionality
- Output only "standard" channel layouts (Mono, Stereo, 5.1, 6.1, 7.1), filling non-existant channels with silence. Required by some HDMI receivers with "odd" source layouts. (default)
- Convert Mono to Stereo (simply double the audio channel)
- Convert 6.1 to 7.1 (Back Center gets doubled into both back channels)
0.26 - 2011/05/15
General
- The VC2010 runtime is no longer required to be installed
LAV Splitter
- Further VC-1 in MKV improvements
- Added a separate "mpegvideo" (m2v files) option to the Format section
- Added a flag for secondary audio streams
- Changed the default DTS media type (better compatibility)
LAV Audio
- Added the ability to use the ArcSoft DTS decoder directly through LAV Audio
- Added an automatic algorithm to keep A/V sync stable
- Improved Bitstreaming with splitters other then LAV Splitter
- Improved timestamp generation when bitstreaming
- Fixed LPCM 24-bit Media Types
0.25 - 2011/05/06
LAV Splitter
- Added the ability to filter Blu-ray PGS subtitles, so only frames flagged as "forced" are delivered
- Either through a new "Forced Subtitles" stream (default)
- Or, filtering for every PGS stream (configurable)
- Improved support for H264 in AVI
- Improved timings for TrueHD in MKV
- m2ts files directly openend inside a Blu-ray structure should now properly display stream languages
- Alot of fixes and enhancements for format compatibility (especially MPEG-TS)
- Support using the ArcSoft HD Audio Decoder for E-AC3
LAV Audio
- Audio bitstreaming (pass-through) for HDMI and S/PDIF
- Support for AC3, E-AC3, TrueHD, DTS and DTS-HD
- Use the float decoders for mp1/mp2
- Added official support for WMAv1, WMAv2 and WMA Pro
- Fixed an issue that caused sync issues with FLAC audio, and FLAC is once again enabled by default
0.24 - 2011/04/25
General
- Big ffmpeg update! Libraries have been renamed (version increase)
LAV Splitter
- Obviously wrong frame rates will no longer be reported to the decoder
- Improved mpeg2 playback
- Improved dynamic media type changes
- Fix the first few frames of ASS/SSA subtitles in Matroska
- Fix an issue with the display of some codec names
- Add proper subtypes for little-endian PCM
- Fix subtypes for QT PCM
LAV Audio
- Support processing of 64-bit double output from the decoders
- PCM data will be buffered before its send to the renderer/post processor
0.23 - 2011/04/21
General
- There is now an installer available in addition to the trusted old .zip files!
LAV Splitter
- Added support for using the "File Source (Async)" (and others) together with LAV Splitter
- This is the new default mode for improved compatibility!
- Check release notes for additional informations.
- Added configuration which input formats will be demuxed
- Improved VC-1 in MKV playback
LAV Audio
- Fixed playback of lossless formats with huge sample sizes
- Improved A/V sync with TrueHD (and possibly others)
- FLAC decoding is now disabled by default, because the decoder is not 100% working
0.22 - 2011/04/11
LAV Splitter
- Added support for MKV *****ded fonts
- Improved VC-1 and H264 parsing
- Fixed choppy XVID playback in MKV
- Fixed a seeking issues that caused incompatibilitys with certain decoders (eg. a crash in ffdshow libmpeg2)
- No longer report incomplete lists of keyframes via IKeyFrameInfo, as it would break seeking in certain players.
- Allow opening all .mpls files if the user directly specifys to open one, even if it contains loops or duplicate titles.
- Improved playback of MPEG-TS with multiple programs
- Added new debugging option (Generate missing timestamps)
0.21 - 2011/04/07
LAV Splitter
- Improve MPEG-TS program handling in some special circumstances
- Filter out misdetected audio streams (unsupported DTS Express on BluRays)
- Increase the priority of DTS-HD over normal DTS
- Use the official AVI MEDIASUBTYPE instead of a custom one
- Added options to completly disable stream parsing
- Added a new VC-1 parser which will take over when VC-1 timestamp adjustments are turned off
0.20 - 2011/04/05
LAV Splitter
- Added first BluRay support (see Release Notes or README for more details)
LAV Audio
- Removed static jitter check which caused corruptions in some audio streams
- Improved error resilience - broken streams should now play in many more cases
0.19 - 2011/03/19
General
- Version Information has been added to the filter .ax files, as well as shown on the property pages.
LAV Splitter
- Redesigned stream name generations
- Codec profiles are now shown (if known - supported are H264, VC1, MPEG2 and DTS)
- Audio bit-depth is no longer shown for lossy codecs, as it doesn't apply there
- Improved logic that parses the stream flags
- Names for the subtitle codecs have been added
- If the language is "Undetermined", it'll no longer be shown
- Size of the packet queue has been increased (solves subtitle issues, as well as improves playback stability)
- Redesigned the way the splitter registers for formats in the registry for better compatibility
- Changed the stream change handling for better compatibility with certain players (Media Portal, and others)
- Improved handling of unknown streams (no codec information present)
- Added a new option that controls if substreams should be exposed in the stream selector (Only AC3 in TrueHD supported)
LAV Audio
- Added a new configuration panel which allows to configure which formats the decoder should handle
0.18 - 2011/03/09
LAV Splitter
- Improved compatibility when decoding VC-1 with the ArcSoft and Cyberlink Decoders
- Increased the splitters merit
- Fixed an issue that caused the splitter to deadlock when changing streams with madVR
LAV Audio Decoder
- Fixed a bug that caused sample durations to be calculated wrong, causing playback glitches
0.17 - 2011/02/27
LAV Splitter
- Fixed seeking before starting playback
0.16 - 2011/02/27
LAV Audio Decoder
0.15 - 2011/02/27
LAV Splitter
- Fixed automatic selection of forced subtitle stream if the "Only Forced Subs" mode is active.
- Fixed a bug in file handling that caused file sizes above 4GB to overflow, causing invalid durations to be reported in some files.
- Improved performance on file opening
LAV Audio Decoder
- Enabled the ffmpeg codec parsers, which should improve compatibility with other DirectShow splitters.
- Added a audio channel activity display to the status property page (for debugging channel assignments)
0.14 - 2011/02/10
General
- The project and filters have been renamed slightly for consistency
LAV Splitter
- The settings have been moved to a different place in the Registry. You will need to re-apply them.
- Improved MPEG-TS duration calculations.
- The settings will now always be properly saved and loaded.
- Disabled the limit of 20 Streams per file.
- Fixed two seperate issues that caused files to not start playing.
LAV Audio Decoder
- Property Page for Configuration and Status has been added
- Dynamic Range Compression is now off by default, but configurable.
- Media Type creation has been improved, fixes filter connection issues.
- Processing of UINT8 Samples has been fixed.
- Fixed a crash with some Audio codecs.
- Fixed Channel Order for 7.1 Streams
- Increased the decoders Merit
- Added support for decoding QT PCM
0.13 - 2011/01/29
LAVFSplitter
- Added support for demuxing BluRay LPCM tracks into the MPC-HC format
- Added a new LAVFSplitter specific media type to all audio streams
LAVCAudio
- First version of LAVCAudio implemented
0.12 - 2011/01/21
- Fixed a crash issue with certain configurations and files with subtitles
- Revisited file duration logic, now tries to prefer the duration of the video stream. This fixes MPEG-TS duration issues.
- Updated ffmpeg (a lot of issues resolved)
0.11 - 2010/11/06
- Smart stream pre-selection based on language, flags and quality
- Properties page for configuration (languages, stream selection logic)
- Added support for AAC LATM (single stream)
- Changed the "No Subtitles" pin to a more "friendly" Media Type
- Fixed a crash with certain AAC tracks
0.10 - 2010/10/26
- Added more MOV/MP4 byte markers
- Added support for multichannel PCM tracks
- Added support for DVD LPCM tracks
- Added support for usign the ArcSoft HD decoder for DTS and TrueHD tracks
- Send the proper media type for TrueHD instead of trying to connect with AC-3
- Improved H264 frame rate detection
- Improved FLAC support
- Fix loading of files with unicode characters in their names
- Fixed timestamping issues that caused certain videos to play too fast
- Fixed M-JPEG media type
- Fixed corruption with MPEG-4 ASP (DivX/Xvid) when using the Xvid decoder
0.9 - 2010/09/12
- Added support for distinguishing hearing impaired subtitles in mpeg-ts streams
- Added BluRay LPCM support
- MP1/MP2 audio media type fixes
- Honor the original FourCC of the file in media type generation
- Added support for using the Cyberlink VC-1 decoder
- Fixed an issue with some H264/AVC1 files that caused video to not play at all
- Fixed unicode in chapter names
- Fixed getting the current chapter
0.8 - 2010/08/30
- Alot of internal changes to enhance performance and maintainability
- Fixed a potential deadlock on seeking
- Fixed playing files without a video stream
- Fixed an issue that caused some players to hang on playback start
- Improved language detection
0.7 - 2010/08/23
- Further improvements to aspect ratio detection
- Restore old FPS detection
- Adjusted flushing to fix subtitle delays
- Reverted a timing change that broke TrueHD
0.6 - 2010/08/22
- Added support for E-AC3
- Fixed MPEG2 Media Types
- Added support for RealVideo in MKV
- Set proper aspect ratio in media type
- Fixed memory leaks in packet handling code
- Unicode support for stream names
- Threading changes for more fluid playback at startup
- Changed Flushing behaviour that solves a conflict with the MS DTV-DVD Decoder
- Better support for Vorbis audio
- Registers for the OGG Container Format
0.5 - 2010/08/18
- Fixed duration of MPEG-TS files
- Added support for DVB subtitles
- Fixed switching of Audio and Subtitle Streams
- Added a "No Subtitles" Stream
0.4 - 2010/08/16
- Improved SSA Subtitle support
- Fixed freeze-on-stop issue
0.3 - 2010/08/15
- Added Chapter support
- Improved stream descriptions
- 64-bit support
0.2 - 2010/08/14
- Fixed overflow in timestamp calculation causing AVIs to play too fast
0.1 - 2010/08/14
- Initial Release[/size]
Alles anzeigen
