LAV Filters – DirectShow-Source/Splitter+Decoder, Alternative zu ffdshow
  • Projekt-Homepage/Blog (1f0.de)
    Projekt-Downloads und -Quellen (Google Code)
    Changelog
    Diskussionsthema (doom9-Forum)
    Diskussionsthema (Gleitz-Forum)
    Aktuelle Version: 0.54.1 - 2012/11/27
  • Version 0.60 ist als Installer und ZIPs verfügbar; wird mal langsam Zeit, hier wieder was zu vermelden, da diese Filter mittlerweile auch schon als Decoder im MPC-HC/MPC-BE integriert sind...
  • LAV Filters 0.60.1
    LAV Splitter
    - Fixed a crash when opening MPEG-2 files with Stereo3D Metadata
    - Improved the format of the chapter names created from *****ded cue sheets
    - Fixed an incompatibility in the IPropertyBag metadata interface with a few players
  • LAV Filters 0.61.0
  • LAV Filters 0.61.1
    LAV Splitter
    - NEW: Support for opening "icyx://" stream URLs
    - Fixed: Opening of some Blu-ray discs would take several minutes and could hang the player.
    LAV Video
    - Fixed: Aggressive Deinterlacing is no longer applied to soft-telecined content, which caused severe playback issues.
    Zitat von nevcairiel
    Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
    Only a few more fixes that I didn't want to leave in the repository until the next major release, as they can really improve the experience in certain configurations.
    In case you missed the 0.61 release from earlier this week, the notes are here.
    Have fun!
  • LAV Filters 0.62.0
    Mostly pushing this release to get updated ffmpeg libraries out, as well as not cause the new things to rot too long.
    WMV9 MFT
    As it appears, the WMV9 DMO decoder is kinda broken on Windows 8.1, it doesn't properly identify interlaced videos anymore, which causes them to never engage deinterlacing.
    To solve this problem, I've implement a new wrapper around Microsofts decoder, using the MFT (Media Foundation Transform), instead of the DMO. DMOs are a tech from Windows XP and before, and are really old and deprecated, while MFTs are new and clearly better supported - plus getting the information I need out of it was actually quite a bit easier than with the DMO before.
    Note that this has no influence on anything DirectShow, LAV is not a Media Foundation filter all of the sudden, it just happens to use the WMV9 MFT, nothing else changes.
    Anyway, have fun, and as always report any regressions you find.
  • LAV Filters 0.63.0 - 2014/10/03 - Release Notes
  • LAV Filters 0.64 - 2015/02/13 - Release Notes
  • LAV Filters 0.65
  • Neuer Deinterlacer von der BBC:
    _
    Was bisher geschah:
    LAV Filters 0.67
    LAV Splitter- NEW: Support for HTTPS URLs- NEW: Automatic selection of the highest quality variant in HLS streams- Changed: Reverted back to the old ASF demuxer- Changed: Backported ASF seeking improvements to the old ASF demuxer- Fixed: ASS in AVI did not work in recent versions- Fixed: RTP/RTSP did not work properly in 0.66LAV Video- NEW: Improved DVD subtitle and menu drawing with madVR (support for madVRs subtitle repositioning and lower latency)- Changed: HEVC and 4K HWAccel is enabled by default- Changed: Enabled DXVA2-CB Direct Mode with YV12 output on 8-bit sources- Fixed: DVD menus could show a black screen instead of the menu in some situationsLAV Audio- Fixed: Improved clipping behavior in badly mastered DTS-HD tracks
    LAV Filters 0.66
  • Wieder eine "stable"-Version:
  • Diesmal mit mehr Unterstützung für HDR und HBD:
  • Lange hat es gedauert – entsprechend umfassende Neuigkeiten gibt es, inklusive D3D11-Decodierung:
    Und letzten Juni gab es dies:
  • Blu-ray-Besitzer aufgepasst:
  • Wieder etwas spät... 8|
    19.3.2019: VP9-Fix
    16.3.2019:
    11.10.2018:
    5.10.2018: AV1 support
