Ich habe hier ein Musikvideo mit folgenden Kapiteln:
GeneralComplete name : 8848179.mkvFormat : MatroskaFormat version : Version 4 / Version 2File size : 1.26 GiBDuration : 1h 37mnOverall bit rate : 1 865 KbpsEncoded date : UTC 2013-01-01 00:42:52Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 23 2012 14:24:43Writing library : libebml v1.3.0 + libmatroska v1.4.0VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L3.0Format settings, CABAC : YesFormat settings, ReFrames : 4 framesMuxing mode : Header strippingCodec ID : V_MPEG4/ISO/AVCDuration : 1h 37mnWidth : 720 pixelsHeight : 400 pixelsDisplay aspect ratio : 16:9Frame rate mode : ConstantFrame rate : 25.000 fpsColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveWriting library : x264 core 116 r2074 2641b9eDefault : YesForced : NoAudioID : 2Format : AACFormat/Info : Advanced Audio CodecFormat profile : LCCodec ID : A_AACDuration : 1h 37mnChannel(s) : 2 channelsChannel positions : Front: L RSampling rate : 44.1 KHzCompression mode : LossyDefault : YesForced : NoMenu00:00:00.000 : en:00:00:00.000 start of chapter #100:05:32.000 : en:00:05:32.000 start of chapter #200:09:58.000 : en:00:09:58.000 start of chapter #300:15:50.000 : en:00:15:50.000 start of chapter #400:20:00.000 : en:00:20:00.000 start of chapter #500:24:00.000 : en:00:24:00.000 start of chapter #600:30:44.000 : en:00:30:44.000 start of chapter #700:38:25.000 : en:00:38:25.000 start of chapter #800:44:05.000 : en:00:44:05.000 start of chapter #900:52:00.000 : en:00:52:00.000 start of chapter #1000:56:00.000 : en:00:56:00.000 start of chapter #1101:00:00.000 : en:01:00:00.000 start of chapter #1201:06:50.000 : en:01:06:50.000 start of chapter #1301:14:25.000 : en:01:14:25.000 start of chapter #1401:18:40.000 : en:01:18:40.000 start of chapter #1501:22:10.000 : en:01:22:10.000 start of chapter #1601:31:09.000 : en:01:31:09.000 start of chapter #17
und muxe nun Kapitel 1 & 17 zusammen mit diesem Kommando:
das Ergebnis ist eine MKV mit diesen Kapiteln:
GeneralComplete name : output\8848179.mkvFormat : MatroskaFormat version : Version 4 / Version 2File size : 178 MiBDuration : 11mn 22sOverall bit rate : 2 186 KbpsEncoded date : UTC 2013-01-15 21:54:11Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 31 2012 17:36:59Writing library : libebml v1.3.0 + libmatroska v1.4.0VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L3.0Format settings, CABAC : YesFormat settings, ReFrames : 4 framesCodec ID : V_MPEG4/ISO/AVCDuration : 11mn 23sWidth : 720 pixelsHeight : 400 pixelsDisplay aspect ratio : 16:9Frame rate mode : ConstantFrame rate : 25.000 fpsColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveWriting library : x264 core 116 r2074 2641b9eDefault : YesForced : NoAudioID : 2Format : AACFormat/Info : Advanced Audio CodecFormat profile : LCCodec ID : A_AACDuration : 11mn 22sChannel(s) : 2 channelsChannel positions : Front: L RSampling rate : 44.1 KHzCompression mode : LossyDefault : YesForced : NoMenu00:00:00.000 : en:00:00:00.000 start of chapter #100:05:31.920 : en:00:05:32.000 start of chapter #200:09:57.920 : en:00:09:58.000 start of chapter #3
was falsch ist. Video & Audio sind dabei richtig 1 + 17 zusammengefügt.
Lasse ich mir das so in 2 MKVs ausgeben, ist alles richtig:
GeneralComplete name : output\8848179-001.mkvFormat : MatroskaFormat version : Version 4 / Version 2File size : 85.4 MiBDuration : 5mn 32sOverall bit rate : 2 153 KbpsEncoded date : UTC 2013-01-15 22:03:33Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 31 2012 17:36:59Writing library : libebml v1.3.0 + libmatroska v1.4.0VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L3.0Format settings, CABAC : YesFormat settings, ReFrames : 4 framesCodec ID : V_MPEG4/ISO/AVCDuration : 5mn 32sWidth : 720 pixelsHeight : 400 pixelsDisplay aspect ratio : 16:9Frame rate mode : ConstantFrame rate : 25.000 fpsColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveWriting library : x264 core 116 r2074 2641b9eDefault : YesForced : NoAudioID : 2Format : AACFormat/Info : Advanced Audio CodecFormat profile : LCCodec ID : A_AACDuration : 5mn 32sChannel(s) : 2 channelsChannel positions : Front: L RSampling rate : 44.1 KHzCompression mode : LossyDefault : YesForced : NoMenu00:00:00.000 : en:00:00:00.000 start of chapter #100:05:31.920 : en:00:05:32.000 start of chapter #2
General
Complete name : output\8848179-002.mkv
Format : Matroska
File size : 92.5 MiB
Duration : 5mn 50s
Overall bit rate : 2 216 Kbps
Encoded date : UTC 2013-01-15 22:05:41
Video
Format : AVC
Duration : 5mn 50s
Width : 720 pixels
Height : 400 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 5mn 50s
Delay relative to video : 10ms
Default : Yes
Forced : No
Menu
00:00:00.000 : en:01:31:09.000 start of chapter #17
Alles anzeigen
Ich habe das noch an anderen Videos und mit anderen Versionen von mkvmerge (5.6, 5.7, 5.8) getestet, mit dem selben Ergebnis.
Weiss jemand, warum das so ist?
