Ich bekomme in der letzten Zeit häufiger folgende Fehlermeldung bei der Audiokonvertierung von DTS bzw. DTS-HD nach AAC:
eac3to v3.27
command line: "C:\Program Files (x86)\StaxRip_1.1.7.2\Applications\eac3to\eac3to.exe" "E:\Blu\DKM" 1) 4:"C:\DVD Data\DKM\1_4_audio.aac" -quality=0.3 -down16 -down6 -progressnumbers
M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 1:33:13, 24p /1.001
1: Chapters, 12 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, German, 5.1 channels, 16 bits, 48kHz
(core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz)
4: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz
5: Subtitle (PGS), German
6: Subtitle (PGS), German
[a04] The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
[a04] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING>
[a04] Extracting audio track number 4...
[a04] Extracting DTS core...
[a04] Decoding with libav/ffmpeg...
[a04] Reducing depth from 64 to 16 bits...
[a04] Encoding AAC <0.30> with NeroAacEnc...
[a04] Clipping detected, a 2nd pass will be necessary. <WARNING>
[a04] The original audio track has a constant bit depth of 64 bits.
[a04] The processed audio track has a constant bit depth of 16 bits.
[a04] The Nero AAC encoder seems to be stuck... <ERROR>
[a04] [NeroAacEnc] Processed 0 seconds...
[a04] [NeroAacEnc] Processed 1 seconds...
[a04] [NeroAacEnc] Processed 2 seconds...
[a04] [NeroAacEnc] Processed 3 seconds...
[a04] [NeroAacEnc] Processed 4 seconds...
[a04] [NeroAacEnc] Processed 5 seconds...
[a04] [NeroAacEnc] Processed 6 seconds...
[a04] [NeroAacEnc] Processed 7 seconds...
[a04] [NeroAacEnc] Processed 8 seconds...
[a04] [NeroAacEnc] Processed 9 seconds...
[a04] [NeroAacEnc] Processed 10 seconds...
[a04] [NeroAacEnc] Processed 11 seconds...
[a04] [NeroAacEnc] Processed 12 seconds...
[a04] [NeroAacEnc] Processed 13 seconds...
[a04] [NeroAacEnc] Processed 14 seconds...
[a04] [NeroAacEnc] Processed 5522 seconds...
[a04] [NeroAacEnc] Processed 5523 seconds...
[a04] [NeroAacEnc] Processed 5524 seconds...
[a04] [NeroAacEnc] Processed 5525 seconds...
[a04] [NeroAacEnc] Processed 5526 seconds...
[a04] [NeroAacEnc] Processed 5527 seconds.
Aborted at file position 21039661056. <ERROR>
Alles anzeigen
Hat schon jemand dasselbe Problem gehabt, bzw. Lösungsvorschläge?
lg knight
