x265 10Bit compile debian
    weiß jemand wie ich x265 unter debian dazu bringe, das er mir 10Bit encodes macht?
    habe mir bisher nur eine 8bpp vers. bauen können.
    ffmpeg# ffmpeg -h encoder=libx265ffmpeg version git-2015-04-22-86d00ed Copyright (c) 2000-2015 the FFmpeg developers  built with gcc 4.9.2 (Debian 4.9.2-10)  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass --enable-libx265 --enable-libvpx  libavutil      54. 23.101 / 54. 23.101  libavcodec     56. 35.101 / 56. 35.101  libavformat    56. 30.100 / 56. 30.100  libavdevice    56.  4.100 / 56.  4.100  libavfilter     5. 14.100 /  5. 14.100  libswscale      3.  1.101 /  3.  1.101  libswresample   1.  1.100 /  1.  1.100  libpostproc    53.  3.100 / 53.  3.100Encoder libx265 [libx265 H.265 / HEVC]:    Threading capabilities: no    Supported pixel formats: yuv420p yuv422p yuv444plibx265 AVOptions:  -crf               <float>      E..V.... set the x265 crf (from -1 to FLT_MAX) (default -1)  -preset            <string>     E..V.... set the x265 preset  -tune              <string>     E..V.... set the x265 tune parameter  -x265-params       <string>     E..V.... set the x265 configuration using a :-separated list of key=value parameters/ffmpeg# ffmpeg -codecs | grep -i hevcffmpeg version git-2015-04-22-86d00ed Copyright (c) 2000-2015 the FFmpeg developers  built with gcc 4.9.2 (Debian 4.9.2-10)  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass --enable-libx265 --enable-libvpx  libavutil      54. 23.101 / 54. 23.101  libavcodec     56. 35.101 / 56. 35.101  libavformat    56. 30.100 / 56. 30.100  libavdevice    56.  4.100 / 56.  4.100  libavfilter     5. 14.100 /  5. 14.100  libswscale      3.  1.101 /  3.  1.101  libswresample   1.  1.100 /  1.  1.100  libpostproc    53.  3.100 / 53.  3.100 DEV.L. hevc                 H.265 / HEVC (High Efficiency Video Coding) (encoders: libx265 )
  • x265 [info]: build info [Linux][GCC 4.9.2][64 bit] 8bpp
    Hast du denn x265 mit gesetzten HIGH_BIT_DEPTH kompiliert?
    Stellt man vor dem Kompilieren ein. z.B. wie unten oder in den GUI (ccmake ../../source)
    hg clone https://bitbucket.org/multicoreware/x265 x265
    cd x265/build/linux/
    cmake -G "Unix Makefiles" -D HIGH_BIT_DEPTH:BOOL=ON  ../../source
    make -j4
    P.S. gab es da nicht mal die Meldung, dass sich das irgendwie ändern soll. Also beides in eine Exe.
  • Hast du denn x265 mit gesetzten HIGH_BIT_DEPTH kompiliert?
    hg clone https://bitbucket.org/multicoreware/x265 x265cd x265/build/linux/cmake -G "Unix Makefiles" -D HIGH_BIT_DEPTH:BOOL=ON  ../../sourcemake -j4
    Thx, geht jetzt.
