weiß jemand wie ich x265 unter debian dazu bringe, das er mir 10Bit encodes macht?
habe mir bisher nur eine 8bpp vers. bauen können.
ffmpeg# ffmpeg -h encoder=libx265ffmpeg version git-2015-04-22-86d00ed Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass --enable-libx265 --enable-libvpx libavutil 54. 23.101 / 54. 23.101 libavcodec 56. 35.101 / 56. 35.101 libavformat 56. 30.100 / 56. 30.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 14.100 / 5. 14.100 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100Encoder libx265 [libx265 H.265 / HEVC]: Threading capabilities: no Supported pixel formats: yuv420p yuv422p yuv444plibx265 AVOptions: -crf <float> E..V.... set the x265 crf (from -1 to FLT_MAX) (default -1) -preset <string> E..V.... set the x265 preset -tune <string> E..V.... set the x265 tune parameter -x265-params <string> E..V.... set the x265 configuration using a :-separated list of key=value parameters/ffmpeg# ffmpeg -codecs | grep -i hevcffmpeg version git-2015-04-22-86d00ed Copyright (c) 2000-2015 the FFmpeg developers built with gcc 4.9.2 (Debian 4.9.2-10) configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass --enable-libx265 --enable-libvpx libavutil 54. 23.101 / 54. 23.101 libavcodec 56. 35.101 / 56. 35.101 libavformat 56. 30.100 / 56. 30.100 libavdevice 56. 4.100 / 56. 4.100 libavfilter 5. 14.100 / 5. 14.100 libswscale 3. 1.101 / 3. 1.101 libswresample 1. 1.100 / 1. 1.100 libpostproc 53. 3.100 / 53. 3.100 DEV.L. hevc H.265 / HEVC (High Efficiency Video Coding) (encoders: libx265 )
encode$ wine avs2yuv_mod ./test.avs -o - | ffmpeg -i - -c:v libx265 -preset slow -x265-params crfdeblock=0:-1:aq-mode=2:aq-strength=1.2:bframes=6:ref=6:rd=5:tu-intra-depth=4:tu-inter-depth=4:me=3:max-merge=5:subme=6:merange=25:keyint=240:rc-lookahead=80:b-adapt=2:rect=amp:no-sao:no-open-gop:no-cutree:no-tskip:no-tskip-fast:weightp:weightb:no-strong-intra-smoothing -y test.hevcffmpeg version git-2015-04-22-86d00ed Copyright (c) 2000-2015 the FFmpeg developers
./test.avs: 1280x720, 24000/1001 fps, 501 frames
Input #0, yuv4mpegpipe, from 'pipe:':
Duration: N/A, bitrate: N/A
Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 1280x720, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc
x265 [info]: HEVC encoder version 1.6+274-859daedfbb29
[COLOR=#ff0000][B]x265 [info]: build info [Linux][GCC 4.9.2][64 bit] 8bpp[/B][/COLOR]
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x265 [info]: Main profile, Level-3.1 (Main tier)
x265 [info]: Thread pool created using 8 threads
x265 [info]: frame threads / pool features : 3 / wpp(12 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3
x265 [info]: Keyframe min / max / scenecut : 23 / 250 / 40
x265 [info]: Lookahead / bframes / badapt : 25 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb / refs: 1 / 1 / 0 / 3
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 64 / 1
x265 [info]: Rate Control : CRF-28.0
x265 [info]: tools: rect rd=4 psy-rd=0.30 rdoq=2 psy-rdoq=1.00 signhide tmvp
x265 [info]: tools: strong-intra-smoothing deblock sao
Output #0, hevc, to 'test.hevc':
Metadata:
encoder : Lavf56.30.100
Stream #0:0: Video: hevc (libx265), yuv420p, 1280x720, q=2-31, 23.98 fps, 23.98 tbn, 23.98 tbc
Metadata:
encoder : Lavc56.35.101 libx265
Stream mapping:
Stream #0:0 -> #0:0 (rawvideo (native) -> hevc (libx265))
frame= 501 fps= 14 q=0.0 Lsize= 660kB time=00:00:20.81 bitrate= 259.6kbits/s
video:660kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
x265 [info]: frame I: 4, Avg QP:22.63 kb/s: 3254.94
x265 [info]: frame P: 132, Avg QP:23.96 kb/s: 634.06
x265 [info]: frame B: 365, Avg QP:29.71 kb/s: 86.95
x265 [info]: global : 501, Avg QP:28.14 kb/s: 256.39
x265 [info]: Weighted P-Frames: Y:0.8% UV:0.8%
x265 [info]: consecutive B-frames: 6.6% 7.4% 10.3% 62.5% 13.2%
encode$ [B]wine avs2yuv_mod ./test.avs -o - | ffmpeg -i - -c:v libx265 -preset slow -x265-params crfdeblock=0:-1:aq-mode=2:aq-strength=1.2:bframes=6:ref=6:rd=5:tu-intra-depth=4:tu-inter-depth=4:me=3:max-merge=5:subme=6:merange=25:keyint=240:rc-lookahead=80:b-adapt=2:rect=amp:no-sao:no-open-gop:no-cutree:no-tskip:no-tskip-fast:weightp:weightb:no-strong-intra-smoothing -y test.hevc[/B]
Alles anzeigen
