Simple x264/x265 Launcher
ZitatAlles anzeigenThis application is a lightweight GUI front-end for the x264 H.264/AVC as well as the x265 H.265/HEVC encoder, based on the Qt toolkit.
Some key features of the Simple x264/x265 Launcher software include:
Support for creating H.264/AVC (x264) and H.265/HEVC (x265) files
Fully self-contained, no additional Codecs or Plugin's are required
64-Bit as well as 32-Bit encoder binaries are fully supported
Optionally the "high bit-depth" encoder variants can be selected
Batch encoding (job control) support is implemented
If desired, multiple encoding jobs can be executed concurrently
Adding new jobs via command-line interface is supported
Input from the Avisynth and VapurSynth frame servers is supported
32-Bit Avisynth/VapourSynth can be mixed with 64-Bit x264/x265
Straightforward encoder setup thanks to the Preset and Tuning system
Custom encoder parameters can be added, if desired
Easily manage your encoder configurations with user-defined templates
Consistent "look & feel" on all systems thanks to the Qt toolkit
[Blockierte Grafik: http://i.imgur.com/x7D7UDQ.png]
[Blockierte Grafik: http://i.imgur.com/hbJ8uFX.png][Blockierte Grafik: http://i.imgur.com/LCT4gdc.png]
Download:
- https://github.com/lordmulder/Sim…releases/latest
- https://www.assembla.com/spaces/simple-…ncher/documents
- https://bitbucket.org/lord_mulder/si…ncher/downloads
Siehe auch:
http://www.portablefreeware.com/?id=2240
