InterFrame-Problem
Aus der beiliegende Readme:
ZitatTuning:
- Tunes the settings for the type of content.
- Film - This offers a good balance between the accuracy of individual moving things and the cohesiveness of the frame. Useful for content that was filmed or rendered (Recommended).
- Animation - This should be used for cartoons/anime.
- Smooth - This increases the accuracy of individual moving things while decreasing the cohesiveness of the frame. Some people prefer it since it gives the motion an overall "smooth" feeling.
- Weak - This decreases the accuracy of individual moving things while increasing the cohesiveness of the frame.
Note: This will weaken the interpolation a lot, meaning the motion isn't as smooth.Some people will prefer to use the Film tuning even for animated content, so don't automatically assume this is the right tuning for you; use with caution.
- default - Film (string)
Sprich: probier's mal mit Tuning="Smooth" oder Tuning="Weak". Beide Optionen haben aber technikbedingt ihre Vor- und Nachteile. Erwarte also keine Wunder. Perfekt kann das Ergebnis nämlich nie werden. - Tunes the settings for the type of content.
Mit der Einstellung "smooth" wird es etwas besser; natürlich nicht perfekt. Danke!
