Habe hier Kodi 17.3 aktuelle Version auf dem Raspberry Pi 3 OS Raspbian. Allerdings spielt er folgendes Video nicht ab
General
Unique ID : 215613386142676548822908257226304806043 (0xA235A0AF8643AD348B69FD6AF82C5C9B)
Complete name : video.mkv
Format : Matroska
Format version : Version 2
File size : 862 MiB
Duration : 50mn 38s
Overall bit rate : 2 378 Kbps
Encoded date : UTC 2012-07-19 05:55:28
Writing application : mkvmerge v5.7.0 ('The Whirlwind') built on Jul 8 2012 20:08:51
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 50mn 38s
Bit rate : 2 000 Kbps
Width : 1 088 pixels
Height : 592 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.124
Stream size : 705 MiB (82%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=abr / mbtree=1 / bitrate=2000 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 50mn 38s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 139 MiB (16%)
Language : German
Default : Yes
Forced : No
Alles anzeigen
, ich klicke es an Doppelklick ganz normal aber es passiert nichts. Betrifft einige, wird von einer Externen FP 1TB gelesen.
avplay (Libav, ffmpeg-Fork) hat damit keine Probleme
Woran liegts?
Edit: Ok avplay auch nicht wirklich, Audio wird nicht abgespielt und avplay stürzt ab
Dateien fehlerhaft?
