Seit Ende Juni 2008 existiert der MPC-HC 1.1.604.0:
Media Player Classic - aktuelle Version
Vom Patched Build v6.4.9.1 gibt es seit dem 6.7.09 eine revision 104:
Media Player Classic HCv1.3.1249.0
Zitatv1.3.1249.0 - 26 august 2009
NEW : Support for Flac audio streams
NEW : Support for Dolby Digital+ (Eac3) and Dolby true HD (MLP)
NEW : Nellymoser audio decoder
NEW : Belarusian, Brazilian and Sweedish translation
NEW : New shader "Sharpen Complex 2" (required hardware compatible with pixel shader 2.A)
NEW : Support for madVR video renderer (http://madshi.net/madVR.zip)
NEW : Additional information on video using MediaInfo (DLL can be download from http://mediainfo.sourceforge.net and placed in mpc-hc directory)
NEW : Internal DXVA decoder support for H264 with Intel G45 (thanks for people who help me at Intel Corp.)
CHANGED: Add support of interlaced flags in software mode for MPCVideoDecoder filter
CHANGED: D3DFullScreen mode now takes into account the monitor to full-screen mode in options, if monitor is not specified on the command line.
CHANGED: Auto-hide playlist on fullscreen(feature request #2219561)
CHANGED: Detours library updated to v2.1
CHANGED: Support for AC3 in MP4 splitter
CHANGED: Support for EAc3 in Matroska splitter
CHANGED: Hotkeys added to support more remote control keys
CHANGED: Support for Theora in Matroska internal splitter
CHANGED: LibVorbis updated to v1.2.3
CHANGED: LibOgg updated to v1.1.4
CHANGED: Improved streaming performances
CHANGED: Prevent display or computer to sleep during playback
CHANGED: Faad library updated to rev 2.2.7
CHANGED: LibPNG updated to release 1.2.38 (fix security bug)
CHANGED: Playlist file is now saved in mpc folder (patch # 2671496)
CHANGED: frame by frame modify to support step frame back functionality (except for VMR9)
CHANGED: support for AC3 in MP4 files created by Nero Digital
CHANGED: EVR custom and VMR9 renderless revamped (Beliyaal), better synchronisation, remove tearing in windowed mode, support for dialog box in DirectX exclusive mode, ...
FIXED : Support for Theora stream in Ogg internal splitter
FIXED : Save thumbnails crash in x64
FIXED : Bugs on presentation graphics (missing subtitles, better synchronization)
FIXED : Audio change on M2TS files reset the selected subtitle
FIXED : Switch to "Minimal view" reset main menu language to English
FIXED : Bug in Mpeg splitter for VC1
FIXED : Maximum texture resolution to "Desktop" not working with Haali renderer (Bug #2456735)
FIXED : Better synchronization with EVR custom to improve playback smoothness
FIXED : 24 bits LPCM not properly play
FIXED : Possible deadlock with Reclock
FIXED : Support of framestep backward, even if the codec didn't support it natively (bug #2600542)
FIXED : DXVA decoder support multiple graphics cards (PCI vendor id detection on the fly)
FIXED : Incorrect aspect ratio for some H264 files with DXVA1 decoder (extended SAR)
FIXED : H264 files with 16 reference frames freeze during playback (bug #2795785 and #2784256)
FIXED : AVI with H264 not decoded properly (bug #2794854)
FIXED : Revamped DXVA h264 decoder based on new insights, fixing black screen, macroblock, support for AVI, ...
FIXED : Incorrect playback for padded DTS
FIXED : Hang when moving player between monitors -
Neuer Meilenstein: Media Player Classic - Home Cinema Version 1.4.2499
Stable: http://sourceforge.net/projects/mpc-hc/files/
Development: http://www.xvidvideo.ru/media-player-c…cinema-x86-x64/
1.5.2.3011 betaZitatRevision 3011 - Directory Listing
Modified Sun Apr 3 16:16:21 2011 UTC (15 hours, 29 minutes ago) by v0ltupdate for commit 2991: don't use a worker thread in D3DFullscreen mode except madVR
Revision 3010 - Directory Listing
Modified Sun Apr 3 04:44:45 2011 UTC (27 hours, 1 minute ago) by v0ltrenamed title of the command for the borderless mode
updated russian translation. updated ukrainian translation by arestarhRevision 3009 - Directory Listing
Modified Sun Apr 3 01:56:02 2011 UTC (29 hours, 50 minutes ago) by aleksoidFix : EVR Custom with VSync - scanline and refresh rate detection fails occasionally, causing superspeed video - ticket #805
Revision 3008 - Directory Listing
Modified Fri Apr 1 19:20:31 2011 UTC (2 days, 12 hours ago) by v0ltback lost translations
Revision 3007 - Directory Listing
Modified Fri Apr 1 19:06:07 2011 UTC (2 days, 12 hours ago) by v0ltrenamed the strings of visual modes
Revision 3006 - Directory Listing
Modified Fri Apr 1 18:41:46 2011 UTC (2 days, 13 hours ago) by v0ltadded "Hide menu" mode. changed the order of the visual modes.
Revision 3005 - Directory Listing
Modified Fri Apr 1 14:35:57 2011 UTC (2 days, 17 hours ago) by madshi- re-added "D3D Fullscreen" option for madVR
- madVR allocator/presenter now supports ISubRenderCallback2
- added (relative) zlib path as additional include to ffmpeg makefile -
Schotenhüter
Das ist ja die Home Cinema Version und nicht der "einfachere" mpc
Habs dazu editiert. Danke
Stable: MPC-HC v1.5.0.2827 und MPC-HC v1.5.1.2903 auf http://sourceforge.net/projects/mpc-hc/files/
Media Player Classic Home Cinema
1.5.2.3021 beta
ZitatRevision 3021 - Directory Listing
Modified Sun Apr 10 09:36:08 2011 UTC (14 hours, 9 minutes ago) by xhmikosrupdate VSFilter.manifest, copyright year
Revision 3020 - Directory Listing
Modified Sun Apr 10 09:15:06 2011 UTC (14 hours, 30 minutes ago) by aleksoidFix : Crash/deadlock while move window between monitors and options "Reinitialize when change display" enable - big thanks to judelaw for this;
Fix : Possible crash in DXVA decoding;
Fix : DD Plus playback for some ts files;Revision 3019 - Directory Listing
Modified Fri Apr 8 14:32:48 2011 UTC (2 days, 9 hours ago) by nevcairielAdd the secondary LAV Splitter GUIDs where appropriate.
Revision 3018 - Directory Listing
Modified Thu Apr 7 00:39:13 2011 UTC (3 days, 23 hours ago) by aleksoidChange : disable Relative drive, ticket #384
Revision 3017 - Directory Listing
Modified Wed Apr 6 14:09:55 2011 UTC (4 days, 9 hours ago) by v0ltcorrected calculation of minimum toolbar width for all visual modes
Revision 3016 - Directory Listing
Modified Tue Apr 5 20:00:39 2011 UTC (5 days, 3 hours ago) by v0ltnew absolute minimum size of the main window is 16x16 (instead of 0x0)
Revision 3015 - Directory Listing
Modified Tue Apr 5 18:59:19 2011 UTC (5 days, 4 hours ago) by v0ltfixed play/pause via left-click when hiding the menu
Revision 3014 - Directory Listing
Modified Tue Apr 5 17:48:31 2011 UTC (5 days, 5 hours ago) by xhmikosrupdate lcms to the latest git
Revision 3013 - Directory Listing
Modified Tue Apr 5 11:24:25 2011 UTC (5 days, 12 hours ago) by clsid2Added LAVSplitter to list of compatible splitters in DirectVobSub
Revision 3012 - Directory Listing
Modified Tue Apr 5 08:14:15 2011 UTC (5 days, 15 hours ago) by nevcairielAdd LAV Splitter to the list of supported source filters for stream selection
1.5.2.3036 betaZitat
Revision 3036 - Directory Listing
Modified Sun Apr 17 02:30:05 2011 UTC (8 hours, 42 minutes ago) by aleksoidFix : rev. 3026
Revision 3035 - Directory Listing
Modified Sun Apr 17 02:00:06 2011 UTC (9 hours, 12 minutes ago) by jonasnoFixed current time goes beyond end of file time (Happens when stepping/jumping)
Revision 3034 - Directory Listing
Modified Sun Apr 17 01:55:43 2011 UTC (9 hours, 16 minutes ago) by jonasnoFixed folder locking when using windows file open/save dialog
Revision 3033 - Directory Listing
Modified Thu Apr 14 18:55:29 2011 UTC (2 days, 16 hours ago) by v0ltsimply moving the window without any toolbars and without any toolbars except search toolbar
Revision 3032 - Directory Listing
Modified Thu Apr 14 18:34:18 2011 UTC (2 days, 16 hours ago) by nevcairielAllow the external filter list to override merits for the "File Source (Async)" and the "StreamBufferSource"
Revision 3031 - Directory Listing
Modified Thu Apr 14 11:08:34 2011 UTC (3 days ago) by aleksoidFix : MPEG2 DXVA Decoder support deinterlacing;
Revision 3030 - Directory Listing
Modified Wed Apr 13 13:00:44 2011 UTC (3 days, 22 hours ago) by xhmikosrupdate atl include files
Revision 3029 - Directory Listing
Modified Wed Apr 13 12:13:40 2011 UTC (3 days, 22 hours ago) by xhmikosrminor project file cleanup, update comments in Version.h
Revision 3028 - Directory Listing
Modified Wed Apr 13 12:09:49 2011 UTC (3 days, 23 hours ago) by xhmikosrremove unneeded atl include files
Revision 3027 - Directory Listing
Modified Wed Apr 13 09:55:31 2011 UTC (4 days, 1 hour ago) by xhmikosrupdate resources
Revision 3026 - Directory Listing
Modified Wed Apr 13 00:31:41 2011 UTC (7 hours, 48 minutes ago) by aleksoidUpdate: resource for rev. 3025;
Change: Show only 32bpp resolution for select;Revision 3025 - Directory Listing
Modified Tue Apr 12 20:13:10 2011 UTC (12 hours, 7 minutes ago) by nevcairiel- mark madVR compatible with the internal subtitle renderer
- block DirectVobSub when using madVRRevision 3024 - Directory Listing
Modified Tue Apr 12 18:10:34 2011 UTC (14 hours, 9 minutes ago) by xhmikosrupdate lcms to the latest git
Revision 3023 - Directory Listing
Modified Tue Apr 12 06:44:25 2011 UTC (25 hours, 35 minutes ago) by aleksoidFix: Better synchronization video after resolution change(EVR Custom);
Revision 3022 - Directory Listing
Modified Sun Apr 10 23:38:19 2011 UTC (2 days, 8 hours ago) by aleksoidChange : Back "Render Device" info in EVR Custom statistic;
Es gibt mal wieder eine neue offizielle "Milestone"-Version: 1.6.0.4014
http://sourceforge.net/apps/trac/mpc-hc/milestone/1.6 oder http://sourceforge.net/projects/mpc-hc
Kann aber immer noch nicht Canopus Lossless und Canopus HQ abspielen.
Dann wünsch es dir in deren Tracker oder im Entwicklerbeitrag. Aber nicht hier im News-Beitrag!
Außerdem wird das ohnehin eher eine Frage der Implementation in die libav-Bibliothek sein, statt den Player spezifisch zu betreffen.
1.6.3.5818
ZitatNew:
New webpage (http://mpc-hc.sourceforge.net)
Source code moved to GitHub (https://github.com/mpc-hc)
The DirectX runtime dlls are included in the distribution packages so it’s no longer needed to install the DirectX runtime
MpegSplitter: support for DVD-Audio LPCM and MLP in .aob files
Use FFmpeg for AC3 and DTS decoding
If the icon library is modified in a way that can break the icons associated to the extensions handled by MPC-HC, MPC-HC will automatically try to fix the registry so that each extension is associated to the correct iconChanged:
Unrar is statically linked and so MPC-HC and VSFilter no longer need the unrar dll
The Icon Library was rewritten leading to smaller size
The Output Options page was redesigned for better usability
Ticket #625, The translation dll’s size was decreased by 2/3 (uncompressed)
Ticket #2227, Hide the seek bar in capture mode
Ticket #2276, Use the new user interface on Vista and later for the Save dialogs
Ticket #2342, MPC-HC will now use the Windows theme font for the Statusbar, OSD messages and a few other places on Windows Vista and newer
Ticket #2378, Move the “Remember last playlist” option into the Options dialogUpdated:
Unrar to v4.20
MediaInfoLib to v0.7.59
ZenLib to v0.4.28
FFmpeg (git 603221e)
Little CMS to v2.4 (git eb67549)
SoundTouch to v1.7.0pre r143
Armenian, Basque, Belarusian, Catalan, Chinese Simplified and Traditional, Czech, French, German, Japanese, Polish, Russian, Slovak and Ukrainian translationsFixed:
The hand cursor wasn’t shown in the web links in Keys and WebServer options page
Toolbar code cleanup and background fix for Windows XP
The last textbox used in the Goto dialog was not remembered since r3964 and r3965
Always show an error message instead of crashing when the argument of a command line switch is missing
OggSplitter: Fix crash with some files
Logitech Keyboard support updated and made optional (Options -> Tweaks)
WebServer: various bugfixes and improvements
Ticket #504, Fixed rounding errors that prevented a properly centered image and caused unneeded resizing because the video size was off by one
Ticket #2330, Fix the radio buttons in the Logo options page
Ticket #2349, Recent Files: “Clear List” did not remove all files from the list
Ticket #2356, The “With icons” and “File(s)” options in the Formats options page were not applied if no association was previously modified
Ticket #2362, [DVB] Fix the Electronic Program Guide (EPG):Fix the parsing of the event’s information
Fix the parsing of the characters’ encoding
Fix the display of the start and end time when DST is observedTicket #2365, The volume slider wasn’t properly redrawn in some cases
Ticket #2427, The command line was not parsed when using slave mode
Ticket #2470, API: Ensure that a 32-bit application can control MPC-HC 64-bit
Ticket #2493, Fix a crash when saving subtitles using the sub format
Numerous other bugfixes and improvements -
Lange nicht mehr aktualisiert... aber da es gerade ein paar teilweise ungewöhnliche, vielleicht sogar amüsante neue Features gibt:
Zitat von vBmAfter 3 months since the last stable build, we decided to release 1.6.6.
This release has many bugfixes and a few new features. Also, the binaries are digitally signed so you can easily verify their integrity.
Highlights of this release:
- Uncompressed RAR files can now be played directly in MPC-HC, drag any .rar or part file (.r00, .r01, etc.) into the player to play it (thanks to RARFileSource)
- The Subtitle menu now shows all available subtitle tracks including the tracks offered by the splitter
- “Now playing” information can now be sent to Skype’s mood message, MSN support has been removed
- VSync is now turned off by default due to playback issues, if you have Aero on you already have VSync and will not notice the difference
- The hotkeys related to D3D Fullscreen and Frame Time Correction have changed to avoid accidental activation
- The external filter list has been split for the 32-bit and 64-bit versions of the player, your current filter list will automatically be corrected
Also besides the usual localization updates a new Romanian localization has been added. We thank our translators for keeping MPC-HC accessible to our non-English users.
You can download the new version here. For the complete changes see the changelog.
Vorher gab es noch:
Zitat von vBmAfter 2 and a half months since the last stable build, we decided to release 1.6.5.
This release has many bugfixes and some new features.
Alles anzeigen* Some long standing issues for the Internal Subtitle Renderer/VSFilter have been fixed: - Support UTF-8 subtitles without BOM - Fix high memory usage with complex subtitles (mostly ASS) - Fix most cases where subtitles are not correctly positioned - Allow floating-point values for \fscx and \fscy in ASS subtitles * Windows 8 is now officially supported and the file association problem has been solved. Windows 8 users should click the "Set Default Programs" button after selecting new formats. * The DVB support has been improved with a better handling of DVB subtitles and a clearer display of the Electronic Program Guide information when using live capture.
You can download the new version here. For the complete changes see the changelog.... nachdem seit Version 1.6.4 von vBm einen neuer Beitrag bei doom9 erstellt wurde.
SourceForge meldet:
MPC-HC 1.6.8
Mittlerweile ist auch die Ankündigung da. Es ging in diesem Schritt v.a. um DVB(-T2)-Unterstützung.
MPC-HC 1.7.1
mit aktuellen LAV-Filtern, die auch HEVC (H.265) und VP9 unterstützen. Außerdem wurden Startprobleme unter Windows 8 gelöst: Meist sind fehlerhafte DirectShow-Filter (wie ffdshow64) Schuld und sollten deinstalliert werden.
Zitat von vBmAfter almost 1 and a half months since our last stable build, we decided to release v1.7.1.
This release is mostly a bugfix release, with a few new features.
- Support for HEVC and VP9
- Fixed MPC-HC crashing on startup on >= Windows 8. Broken codecs installed on the system tend to crash the player on startup.
Now this crash will only happen if/when you enter capture mode. One common cause is ffdshow x64. Check if you have it installed and uninstall it. - Many LAV Filters fixes including a crash on AMD cards with DXVA when stopping playback
- Fixed subtitle selection settings of the internal LAV splitter
- British (English) and Slovenian localization
