DVDlab - aktuelle Version
  • http://www.mediachance.com/files/dvd-labpro155.zip
    • Group assets by Parent Folder option, with the ability to drag the whole group to the connection which will create multiple movie objects.
    • Customizable Test Compile (you can specify which Movies are going to be replaced by Dummy)
    • A new Link HUB object, a single place that distributes links across the project optionally with setting two GPRM parameters. Great for training, quiz etc.
    • fix: Labtalk VM commands and the Block/Script confussion
    • added Open & Free memory - open large project while freeing menu memory on the same time
    • Record module enhancements and drivers compatibility issues (v. 3.1)
  • update auf 1.6
    - Fix for jumping subtitles. The position on screen is now calculated by the absolute line, so a subtitle with only capital letters (AAAA) will remain on the same line position as a subtitle with only small underlined letters (pppp). See example. Because subtitles normally use combination of all kinds of letters you may not actually see this problem very often.
    - Subtitles imported from bitmap will be not trimmed anymore (it could have the same jumping problem as above). If the imported bitmap is a full D1 size then the margins will be ignored, otherwise the margins will be used on the original - size bitmap. This should solve few troubles with positioning.
    - Open GOP warning can be disabled in Properties.
    - Open GOP warning is now always disabled on a files < 4MB (transition files etc.)
  • Ist es möglich, es zu verschmelzen?
    Update auf 2.1
    • Fixed problem with menu audio on certain Pioneer players (DV340, DV344, DV525)
    • Menu vobs are now smaller (like in 1.5 version)
    • Some timing issues with subtitles
    • Creating over 1000 subtitles shows "Out of memory" message
    Edit by Rippraff: Alläs iste mögelisch! :)
  • Und hier die 2.21
    http://www.mediachance.com/dvdlab/historypro.html
    -Add: Comment box in VM script
    -Ch: Circle in menu is few pixels smaller so it doesn't cut off the right and bottom
    -Add: New Enhanced menu rendering to PAL and NTSC, improves Highlighting coverage
    -Add: Sub-Registers wizard in VM Editor. You can virtually divide first 10 GPRM registers into more (2 ,4, 8,16) smaller parts . This allows you to have for example 20 one-byte sized registers (values: 0-255), 40 four-bit registers (values:0-15) or even 160 single-bit flags. The wizard makes easier to generate the necessary VM operations.
    -Changed, Fixed and Cleaned - Subtitle Timecode, now you should always use the Real Time 25fps & 29.97 fps settings for your subtitles. But there are two other options Correct if subs show early and Correct if subs show late, use these if at some point the DF/NDF is incorrect in your subtitles, this will correct it in the right dirrection and hopefully end the confussion about DF and DF subtitles.
    - Das Kreistool (Kreise malen :) ) wurde so geändert, dass ein Kreis nicht mehr rechts und unten angeschnitten wird.
    - Das Subpicture-Highlighting funktioniert jetzt besser (bessere Übereinstimmung zw. Objekt und Highlite, insb. Text)
    - Subregister-Wizard im VM-Editor wurde implementiert. Damit lassen sich z.B. Teile eines/mehrerer Register setzen/auswerten (Flags, Parts etc.). Interessant für nutzerdefinierte Playlists, Randomlists etc. - Entstanden auf Anregung eines Users im MMBForum.(http://www.mmbforums.com/phpbb/viewtopic.php?t=15919).
    - Verbesserte Unterstüzung bei Untertiteln (experimental) für DF/NDF (NTSC)-Material.
    IHMO kosmetische Operationen (abgesehen vom Menütool und der endlich verbesserten Subpicture-Unterstützung in Menüs) ...
    BJ1
  • DVDlab Pro 2.23
    "Global VM - almost revolutionary new way how to write VM script. Modal-less window (like lab-Talk). One, place for all the objects. Comments in code. Automatic GPRM partioning, Aliases, IF-THEN-ELSE and Goto by labels. Link/Jump/Call by Object name. Hardcore DVD nerds heaven.
    -Fix: Displaying VM command in connection was broken if VM command had OR operator."
    Info: http://www.mediachance.com/dvdlab/historypro.html
    DL: http://www.mediachance.com/files/DVD-labPRO223.zip (.exe/.dll only)
    BJ1
  • DVD-lab PRO 2.24 ist raus ;)
    History 2.24
    • Fix: Override Aspect Ratio in VTS will not change aspect ratio of Cells, same when loading.
    • Fix: for some players 2xFF and REW problem (ADT is now set as ROM, before it has been set as R/RW which may cause on some old players to simply disable 2xFF/REW - courtesy of DVD specs)
    • Fix: Combo-Buttons didn't work correctly with new Enhanced menu rendering introduced in 2.2
    • Fix: for stuttering bug on long movies after certain time
    • Clone Mega-Project (Save As... in mega project didn't work as expected - now it will Clone whole Mega-Project into new directory.
    • Time map unit fix - time map will not exceed 2048
    • Slideshow Muxer adjustement
    Download update 2.24
    MfG Laserman!
  • DVD-lab PRO 2.25 ist raus ;)
    History 2.25
    • Merge Projects, different aspect (it will adjust the new merged VTS properties if aspect is different in the merged files)
    • External Subpicture and external background - it will now save the external link into the project file and by default alwasy try to use the external file. Some more checkings to make sure the file is correct.
    • Zoom In allowed bigger than 1:1, zoom by mouse wheel follows the cursor
    • Chapter Play-list (Movie Branch) - added option to set sequential chapters seamless
    • Enter reg. code now has note for Vista (You have to use the option Current user, not all users )
    Download update 2.25
    MfG Laserman!
  • DVD-lab PRO 2.26 ist raus ;D
    History 2.26
    • If a chapter is set to pause, the next chapter must be set as non-seamless
    • Right Click Link menu will now collapse to divided form
      if there are too many menus or movies to make it manageable and to avoid scrolling.
      The items will be sorted in SubMenus by 10s.
    • Change Order of items will also display PGCN.
    • Added Movie Gap object for various VM tricks in Title domain,
      for example as link collector for movies
      (to go away with the 128 limit VM commands in Root VTS)
    • Added option to export Connection window to ASCII art for simple posting on web boards.
    • VISTA registration fix.
    • * 2 PM: quick fix Movie GAP was cancelled when saved and load back
    Download update 2.26
    Important: After you update to this version, the software may ask you to enter the registration code again -
    this is due to the changes necessary for MS VISTA.
    MfG Laserman!
  • DVDlab 2.27 -> http://www.mediachance.com/dvdlab/historypro.html
    History:
    [INDENT]
    • Subtitles Mapping verification if the subtitles maps to existing subtitle track
    • Subtitles Track Deletion now checks if there is no residual mapping in other tracks to the deleted track
    • Reverted back the External Subpictures from 2.25. The external Subpictures will be loaded into internall buffer and used from there (so the external file is no longer needed).
    • Added buttons on menu toolbar for loading external subpicture and showing it.
    • Subtitles with type Black bar and Transparent Bar were switched on DVD (Transp bar showed as full black )
    • Pressing Cancel on Close-Caption dialog will remove the Close caption.
    • Crashing when deleting multiple objects in Connections, or crashing when deleting object that has opened window
    • Paragrpah text rendered bit differently on Enhanced rendering (Which made impossible to use Hot-Spot over it)
    • Check for maximum 36 buttons on menu before compillation
    [/INDENT]
    Also keine neuen Innovationen, dafür Eliminierung kleinerer Wanzen und ein bischen Kosmetik. Die Rechtschreibfehler sind von der Originalseite und dürfen behalten werden :)
    BJ1
  • DVD-lab PRO 2.28 - 2007.03.23
    • - Fixed the ability to support more than 255 menus in a single VTS (up to 640 menus). Previously AI would not write double BYTE command into VM which was necessary for linking menus higher than 255 in VTS
    • - FIX: If start Debugging from the VTS Root, it will show "unknow link" on any LINKPGCN commands
  • DVD-lab PRO 2.32 ist raus (12.09.2007) ;D
    History 2.32
    • Create IMG file after compilling (option in Compile dialog).
      Alternative creation of IMG file with 2048 (normal), 2054 and 2064 byte block,
      the later is currently being tested with some replicators as a vehicle for ftp image to plant
    • Enhanced editing of bitmap images and buttons directly from menu (painting color and transparency)
    Download update 2.32 (3 MB)
    DVDlab Pro 2.32 deutsch patch --> http://technik.movie2digital.de/thread.php?threadid=35292
    MfG Laserman!
