Version 1.3.1 release 25.11.2003- As always when you release software, something come up the same day - The Record module was not updated and it remembers the output folder from 1.1 release, not 1.3.
You can download just the module here.
Version 1.3 release 25.11.2003- Deleteing a movie will now keep the First Play and Title button with correct movie (fix from beta 9)
- Throw error if importing file is a mono wav. (this caused to play the DVD 2x speed - chipmunk)
- Rewrite GOP Timecodes fix for file >4GB
- Compile Dilaog: Frame-Index is now moved to Pre-Compile options (Create/Use Frame Index...) and few other small changes
Download
Version PRO 1.4 BETA 1 08.12.2003
(Download dvdlabup14beta1.exe (4MB), you need at least 1.3 full version)
Version Std 1.4 BETA 2 24.03.2004
(Download dvdlab14b2.exe (4MB).)
Version PRO 1.4 BETA 4 01.06.2004
(Download ProBeta4 (5MB))
Danke an eDealer für die INFO
DVDlab - aktuelle Version
Hallo Fr_An,
Danke fürs Splitten... werde gleich mal die Überschrift ändern "DVDlab Letzte Version".@ALL
wenn es eine neue Version von DVDLab gibt, postet es einfach hierein, die Moderatoren oder ich werden dann immer den ersten Beitrag Editieren. OK ? -
Hi katjarella,
ist ne gute Idee. Zusätzlich steht ja auch immer die letzte Version in diesem Thread:
http://doom9.gleitz.de/showpost.php?p=35723&postcount=1 -
Seit gestern ist auf http://www.mediachance.com/dvdlab/history.html BETA 9 verfügbar:
QuoteVersion 1.3 BETA 9 20.11.2003 (download dvdlabup13beta9.exe (4.2 MB) - you need to have installed at least full 1.1 version)
- Deleteing an object (like menu or movie) will now shift all End links to proper place. This was often seen in transition when deleting one will mess up all other transition connections.
- because of the work in progress the beta 8 menus in connections displayed all ROOT icon. It was only cosmetic issue and it is fixed in beta 9
- If total time can't be quickly determined in assets it will write '0-GOP' instead of 00:00:00 which may take people less by surprise
- If you use Bitrate Viewer and let it finish the whole length of movie, this new calculated time will be set in the Assets -
Jetzt ist es vorbei mit Betas:
Version 1.3.1 is released !!!
QuoteVersion 1.3.1 release 25.11.2003- As always when you release software, something come up the same day - The Record module was not updated and it remembers the output folder from 1.1 release, not 1.3.
- Compile Dilaog: Frame-Index is now moved to Pre-Compile options (Create/Use Frame Index...) and few other small changes -
Hallo Leute,
ich versuche seit gestern (erfolglos) den Download von DVD Lab 1.3.1. Bei den meisten Download Sites lande ich nach der Warteschleife auf dieser Seite
http://www.simtel.net/spotlights/burnquick.php
oder bekomme die Fehlermeldung : DVDLAB131.exe nicht vorhanden. Mache ich etwas falsch oder geht es euch ähnlich? Oder kann jemand einen Direktlink zum Downlaod posten? Wäre nett.
Viele Grüße an alle Forumsmitglieder
Local Hero
Der Link sollte gehen:
Download -
...oder direkt den hier ftp://ftp.freenet.de/pub/ftp.simtel…t/dvdlab131.exe
Danke, danke, danke! Ihr seid ja unglaublich schnell. Gleich 2 Antworten innerhalb von Minuten, klasse! Der Download hat geklappt, heute Abend werde ich die neue Version testen.
Noch besser wäre: http://www.simtel.net/product.download.mirrors.php?id=64228
da kann man sich aus 49 Servern einen aussuchen.
Hi Fr_AN
da sind halt einige bei die nicht funkrionieren! -
Quote from eDealer
Wirklich?
Ich habe jetzt wahllos 12 Links ausprobiert. 11x startete der Download, 1x sollte ich einen Namen und ein Passwort eingeben. Das heißt, dass die freigegebene Anzahl von Besuchern ausgeschöpft ist. Also ist die Wahrscheinlichkeit, dass man von der Seite einen Download erhält äußerst groß.
Ansonsten muss man es mal bei File-Mirrors versuchen. Dort werden in der Ergebnisliste nur augenblicklich verfügbare Downloadadressen aufgeführt.
Hi Leute,
in Zukunft wird es eine Normal und eine Pro Version geben.
Die neuen Dinge sind spannend (1.3.2beta ist in Arbeit!)
z.B. import von compilierten Projekten, d.h. multiple VTS DVDs sind möglich usw..
Leider noch nichts von mehrfachen Audiospuren zu sehen.
http://www.mediachance.com/dvdlab/history.html -
Version PRO 1.4 BETA 1 (DownloadQuotedvdlabup14beta1.exe (4MB), you need at least 1.3 full version) 08.12.2003
From now DVD-lab versions will be splitted to Standard and PRO. This is important because there are too many advanced additions planned that a normal user may find them too overwhelming. The PRO version will require a bit more knowledge about the DVD authoring and structure but it will allow you to create DVD structure as you require. During the beta-testing DVD-lab registerd users will have no time limit on the PRO version.
Both Normal & Pro
- Component system in Connection windows - you can group objects and use them as black box, you can also export/import such components
- Adobe Photoshop 6,7 export/import fixes
- Load Sub Picture now converts the subpicture to 4 Colors
- You can directly drag images and *.mnu files from explorer to menu
- Output folder is now saved with the project.
- Testing mpa audio frequency in PS mpg without demuxing throw error if not 48kHz.
- You can also drag link from Project to Connections Menus and it will behave as if you use Draw Button Links. Bit awkward but the option is there.
- Some changes in mpa testing, the large allocated buffer seems to caused some problems
- Rebuild All Transitions on one click
- Add Transition Tool in connection (Draw arrow from menu to menu)
- Test compile now replaces also slideshow. The dummy image is now dynamically generated with information about the movie.
- Fix for the case when two or more menus with 16:9 motion background would crash compiler.
- Choose type of Default (Empty) project or create your own default project.
Pro Version
- Added real VMG Menus. Now you will be able to build the full DVD hierarchy.
- Import second VTS (menus+movie(s)) directly from any previously compiled project (loading the VTS_xx_0.IFO). This is a great new way to build multiple VTS DVD by simply first building one normal single VTS project, testing it, then use the compiled result directly as a second VTS in a new project. This way will add flexibility to the whole authoring process where you won't need to touch or recompile already working part.
- Re-authoring: Import VOB files (via IFO) as whole without joining - part of the multi-VTS solution as described above. It allows you to easy directly import previously created project or whole VTS created in other authoring software so you no longer need to join vobs and recreate chapter, etc, all is imported from ifo.
Und eDealer,
schon getestet ? Wie ist Dein Ersteindruck ? -
Es gibt einen Projektvizard, der die Standardabfrage erledigt.
Die VMG option habe ich noch nicht getestet, aber wenn das so geht wie es soll
wäre schon gut -
NEWS/Spekulationen
In der Beta 1.4b2 unterstützt DVDlab u.a. neben dem ex- und import von Components (Zusammenfassungen von Items, deren Inhalte und Verlinkungen aus dem Connections Fenster) aus der 1.4b1 nun auch das Editieren mit einem SourceScript Editor. Dieser Scripting Support nennt sich lab-Talk. -
Die Beta 1.4b2 in der Standard Version wurde freigegeben.
Version 1.4 (BETA 2) download dvdlab14b2.exe (4MB). There are no backgrounds, buttons or any templates so you need to have 1.3 full installed before adding this update.- New multiplexer that should fix the WAV problems together with few other muxer related issues
- The File Browser is completely redone (the MS stuff is out), now with file info, color coding, favorities and ability to preview files.
- Menu Object can have various new effects - Bevel, Glass, Mirror, Magnifier...
- The Render Motion Menu some work, smoother fine scrub, Pre-Buffering (starts decoding a movie bit earlier and then extact frames when the decoder ir "warmed up". This should fix the first GOP jump issue)
- Plug-ins folder in assets, has space for Plug-ins (Components, Scripts)
- Run lab-TALK scripts in either interpreting mode or pre-compiled form (in C++ for example)
- Run Smart Components - a component with embedded script
- Fix for LPCM multiplexing issues with Panasonic and few others.
- DCT Transcoder to reduce size of asset files. This operates similarly to DVD Shrink or DVD2One, (but on the input mpeg files rather than on whole DVD) where the transcoder simply reuse mpeg motion vectors and therefore recompress the mpeg file size in just few minutes. This is just a means for a quick reducing less important files. Make sure you know the tradeof.
- Audio Delay Info. If you select Program Stream in assets and click Audio Delay button you will get the info of the PS A/V delay. If you select audio file then it is as before - correct Audio Delay.
- MPEG-1 ES files can now be previewed and compiled
- Direct access from DVD-lab assets to TMPGEnc AC3 plugin (WAV and MPA transcoding)
- New and improved demultiplexer, now it will demux in 2 pass (video then audio) which prevents from fragmentation of the disc. It is also faster and more stable than previous one.
- Some changes in Record module - now you can manually select the type of DVD which works more reliably than auto-sensing.
Es scheint mir da eine Bug beim Import von z.b. SVCD Content direkt von einem CD Laufwerk zu geben, und zwar fehlt bei mir die Abfrage zur Angabe des Speicherortes der demultiplexten Audio und Video Inhalte, vielmehr erscheint nur eine Fehlermeldung aus der ich schließen musste daß DVDlab automatisch den Ursprungspfad der Dateien auch als Zielpfad setzt.
(der genaue Wortlaut der Fehlermeldung ist mir leider nicht mehr eingefallen...)
Wenn dem so wäre könnte man natürlich einfach erst auf HD kopieren, ist aber wohl kaum im Sinne des Entwicklers.
(nach Downgrade auf Version 1.4 BETA1 war die Welt wieder in Ordnung)
Oder sollte ich da irgendeine Einstellungsoption übersehen haben?
Übrigends habe ich die Erfahrung gemacht daß beim Reauthoring von sagen wir 6 SVCD's auf DVDR der Ton auf einigen Standalones nur korrekt wiedergegeben (erkannt) wird wenn ich nach dem Compilen der DVDR unter "Tools > Ifo Editor - Audio" die Audio Eigenschaften manuell aud Deutsch und MPEG Audio setze.
Zum Transcoden von Audio auf 48 kHz muß ich leider auch ab und zu noch BeSweet bemühen da auch dort öfters die interne Routine von DVDlab versagt.
mfg
ylfcam -
