VirtualDub(Mod)(MPEG2) - aktuelle Versionen
  • VirtualDub 1.7.3 Build 28191 ist raus.
    Gibt's hier.
    Cu Rippraff
    Blumige Grüße, Rippraff
  • VirtualDub-MPEG2 1.6.19 by fccHandler, Build 24563 (September 13, 2007)
    http://fcchandler.home.comcast.net/stable/
    Version 1.6.19 build 24563 (September 13, 2007)
    * I've discovered that my previous build will sometimes pause for an alarmingly long time, especially after parsing large (1 GB or larger) MPEG files. That issue is fixed now.
    * I'm still trying to improve the accuracy of the audio skew reported in "File Information" for MPEG files. This new build removes audio and video access units at the beginning of the MPEG stream if they lack Presentation Time Stamps, and I hope this will finally guarantee that the skew report is 100% accurate.
  • VirtualDub-MPEG2 1.6.19 by fccHandler, Build 24570 (September 14, 2007)
    Version 1.6.19 build 24570 (September 14, 2007)
    * The "File / Save WAV..." dialog no longer shows "mp3" and "ac3" file extensions.
    * Still more changes to improve the accuracy of the audio skew report.
  • VirtualDub 1.7.5 Build 28225 (stable): [September 29, 2007]
    http://www.virtualdub.org/
  • MPEG-2 plugin by fccHandler, Version 1.0
    For use with VirtualDub version 1.7.2 or later.
    http://fcchandler.home.comcast.net/Plugins/MPEG2/index.html
    Change Log started October 2007
    Version 1.0 (October 4, 2007)
    This is the first release of my new MPEG-2 plugin for VirtualDub version 1.7.2 and later. The following are known issues:
    * Direct stream copy of MPEG audio is not possible yet.
    * Direct stream copy of AC-3 audio is possible, but the plugin cannot decompress AC-3 itself. Use AC3ACM to allow VirtualDub to decompress AC-3.
    :D
  • MPEG-2 plugin by fccHandler, Version 1.1
    Version 1.1 (October 5, 2007)
    None of the known issues in version 1.0 have been fixed yet, but I'm uploading a new version to keep the code up do date with new things I've learned about VirtualDub's API. The only minor change which is likely to be noticed by users is the following:
    * Added ".mpeg" to the list of supported MPEG-2 extensions.
    Achtung: Damit das MPEG-2 Plugin nicht abstürzt, wird VirtualDub v1.7.6 oder neuer benötigt!
  • VirtualDub v1.7.6 test-4 (Oct 7 2007)
    http://www.virtualdub.org/beta/VirtualDub-1.7.6-test4.zip
    http://www.virtualdub.org/beta/VirtualDu…test4-AMD64.zip
    Diese Testversion behebt den Crash mit fccHandler's MPEG-2 plugin!
    Damit sollten die offiziellen VirtualDub-Builds ab sofort über uneingeschränkten MPEG-2-Support verfügen :D
    Bye bye, VirtualDub-MPEG2 :heul:
    //EDIT
    WMV plugin by fccHandler, Version 1.0 (October 7, 2007)
    http://fcchandler.home.comcast.net/Plugins/WMV/index.html
    This is the first release of my new WMV plugin for VirtualDub version 1.7.2 and later. The following are known issues:
    * There are no decompressors in the plugin itself. You must have the proper codecs installed on your system to decompress the video and audio streams.
    * When seeking to a random position and starting playback, you may see "Error code 512: (ACMERR_NOTPOSSIBLE)". To work around this, seek to a different position and try again.
    * Audio sync may not be perfect if the WMV file has a VBR audio track.
  • MPEG-2 plugin by fccHandler, Version 1.3
    Zu verwenden mit der neusten Testversion von VirtualDub v1.7.6
    WMV plugin by fccHandler, Version 1.2
    VirtualDub v1.7.6 test-9 (Oct 10 2007)
    http://www.virtualdub.org/beta/VirtualDub-1.7.6-test9.zip
    http://www.virtualdub.org/beta/VirtualDu…test9-AMD64.zip
  • MPEG-2 plugin by fccHandler, Version 1.4
    Version 1.4 (October 10, 2007)
    * Fixed a bug which prevented filter preview and cropping windows from working correctly.
    VirtualDub v1.7.6 test-10 (Oct 11 2007)
    http://www.virtualdub.org/beta/VirtualDub-1.7.6-test10.zip
    http://www.virtualdub.org/beta/VirtualDu…est10-AMD64.zip
  • Hier noch schnell der Changelog:
    http://www.virtualdub.org/blog/pivot/entry.php?id=175#body
    MPEG-2 plugin by fccHandler, Version 1.5
    Version 1.5 (October 13, 2007)
    * I've added an experimental feature which allows you to open multiple MPEG files, which are joined together virtually by the plugin. To use this feature, check the "Ask for extended options after this dialog" checkbox when you select an MPEG file.
  • Neues Mpeg2 und Quicktime-Plugin
    Zitat von fccHandler
    I've added a checkbox in the "extended open" dialog of my MPEG-2 plugin which allows you to save an index when you open an MPEG file:
    The name of the index will be "[filename].idx". It's basically a giant memory dump of all of the info which was generated by the parser, including your chosen audio stream, and the names of multiple file parts (if any).
    After this index is saved, if you open the base file again, the parser will find and use that index instead of reparsing the file(s), so re-opening is almost instantaneous. It works in jobs too.
    Und nach einer Fehlermeldung:
    The crash info doesn't reveal much, but the info dialog says "MPEG-2 Information (0 files)." That gives me a good idea where the problem is.
    EDIT: Well, I'm not sure. Please test this one for me:
    http://fcchandler.home.comcast.net/MPEG2.zip
    Quelle: http://forums.virtualdub.org/index.php?act=ST&f=7&t=14639&st=0
    cu
    Jens
  • nicht nur evtl ;)
    Some news update ;)
    VirtualDub 1.7.6, Build 28292 (2007-10-13)
    http://virtualdub.sourceforge.net/
    MPEG-2 plugin by fccHandler, Version 1.7 (2007-10-16)
    WMV plugin by fccHandler, Version 1.3 (2007-10-12)
    Version 1.3 (October 12, 2007)
    * I've done some major restructuring of the code, but that's mostly invisible to the end user. One change you will see is that the plugin now supports ASF files which don't contain video, but do contain audio. Therefore I've added "*.wma" to the list of supported extensions.
    * Fixed a bug which prevented closing the Info dialog with the [X] button.
    * Known bugs: Output playback stutters badly with some files.
    FLV Input Plugin by Moitah, Version 0.3.0 (2007-10-12)
    http://www.moitah.net/misc/FLVInputDriver-0_3_0.zip
    Zitat von Moitah
    I implemented TimeToPositionVBR/PositionToTimeVBR based on the audio tag timestamps. It seems to work pretty well, maybe I'll just leave it like this, but I'm not sure yet. Also, PCM audio might work with this version, but I don't have a FLV file to test it with (only have one .flv with PCM but there's no video stream). The synch in most files is pretty good now. I did spot one file that was quite a bit off but it isn't a problem with the audio, rather because the framerate of the video was variable.
    I should warn everyone, it's a bad idea to direct stream copy the MP3 audio into an AVI. It doesn't play correctly in most players, maybe because the MP3 frames are split across the AVI chunks or something, I'm not sure.
    Also if you just want to extract the MP3 without decompression, you might think to File > Save WAV and strip off the RIFF headers, but I don't recommend this because the end may be slightly truncated (I think this would be fixed by using ceil instead of rounding nAvgBytesPerSec, I'll consider doing that). Instead, I recommend FLV Extract.
    I'm thinking about how to handle variable framerate videos because a handful of the FLVs I saved from YouTube are like this. I could pad gaps of missing frames with drop frames, it might not be too hard.
  • MPEG-2 plugin by fccHandler, Version 1.9 (2007-10-19)
  • MPEG-2 plugin by fccHandler, Version 2.0
    changelog:
    * I've made some improvements in the multiple files feature. The plugin will automatically add multiple VOBs (of the form "VTS_##_#.VOB") when you open any VOB of a DVD title set. Plus I've changed the interface somewhat to make it clear that the multiple files feature is only intended for loading DVD VOBs. It will not usually work with other types of MPEG files.
    * The index file format has changed again, therefore ".midx" files written by version 1.9 won't work in this version.
    WMV plugin by fccHandler, Version 1.4
    changelog:
    * I've added improved support for variable frame rate (VFR) video, which is not uncommon in WMV files.
    ...hier wächst was richtig Gutes... :)
    Olnima
  • Quelle: http://www.virtualdub.org/
    cu
    Jens
  • VirtualDub 1.7.8, Build 28346 (stable)
