• Hallo Jungs,
    ich habe mal einen kleinen DVD Multiplex Test gemacht. Und war dabei SEHR Erschrocken.
    Bitte vergleicht mal Time, fps und die Frames
    Original
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    Mutiplex Test mit 2 Audiospuren (PCM und AC3)
    DVD Maestro
    IfoEdit 0.95 / 0.96
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:06:17.07 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Red]00:06:17.07[/COLOR][/B] / [B][COLOR=Green]25 fps[/COLOR][/B] [Pos: 00:06:17.07] [Frames: [B][COLOR=Red]9432[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    dvdauthor (v 0.6.8 , mplex-2 kann kein LPCM2 deshalb Original VOB übergeben)
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: Not Specified (Linear PCM) 2ch 48Kbps 16bps (ID: 0xa0) Audio 2: Not Specified (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x81)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 30 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16[/COLOR][/B] / [B][COLOR=Red]30 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Red]5656[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    Mutiplex Test mit einer Audiospure (AC3 Audio Only)
    IfoEdit 0.96
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:06:17.07 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Red]00:06:17.07[/COLOR][/B] / [B][COLOR=Green]25 fps[/COLOR][/B] [Pos: 00:06:17.07] [Frames: [B][COLOR=Red]9432[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    DVDLab 1.3x
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    ReJig 0.5c
    Title Set (Movie) attributes: Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (pan-scan & letterboxed) Audio 1: English (Dolby AC-3) 6ch 48Kbps DRC (ID: 0x80)PGC_1 (program chain): [Title(TTN): 1] [00:03:08.16 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1) [Ch 01] [Pg 01] [Cell 01] [V/C Id: 1/ 1] : time: [B][COLOR=Green]00:03:08.16 / 25 fps[/COLOR][/B] [Pos: 00:03:08.16] [Frames: [B][COLOR=Green]4716[/COLOR][/B]] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    dvdauthor (0.6.8, mplex-2 2.0.0)
    Ergebniss
    ++++ DVD Maestro : mehrere Audiospuren, Time=ok, fps=ok, Frames=ok
    -+++ ReJig : versteht kein PCM, Time=ok, fps=ok, Frames=ok
    -+++ DVDLab : nur eine Audiospur, Time=ok, fps=ok, Frames=ok
    +-+- IfoEdit : mehrere Audiospuren, Time=falsch, fps=ok, Frames=falsch
    ++-- dvdauthor : mehrere Audiospuren, Time=ok, fps=falsch, Frames=falsch
    Fazit
    für mich kommt NUR noch DVD Maestro in Frage, auch wenn es nur kleine Sachen sind.
    Und über IfoEdit bin ich SEHR verwundert, das er so viel falsch macht.
    Bitte testet es selber mal. Und schreibt Eure Erfahrungen !!!
  • Ich habe eine miniDVD mit ReJig v0.5e und IFOEdit 0.96 authort. Hier das Ergebnis.
    ReJig:
    VTS overview:Menu attributes:		  Video: MPEG-1 720x480 (NTSC) (NTSC 525/60) (4:3) (pan-scan & letterboxed)		Title Set (Movie) attributes:		  Video: MPEG-2 352x576 (PAL) (PAL 625/50) (16:9) (pan-scan & letterboxed)		  Audio 1:      Deutsch              (Dolby AC-3) 6ch 48Kbps DRC       (ID: 0x80)  Audio 2:      English              (Dolby AC-3) 6ch 48Kbps DRC       (ID: 0x81)  SubPicture 1: Deutsch              (2-bit rle ) (ID: 0x20)		  SubPicture 2: Deutsch              (2-bit rle ) (ID: 0x21)		PGC_1 (program chain): [Title(TTN): 1] [00:49:16.23 / 25 fps] (Programs: 13) (Cells: 13) (uses VOB-IDs: 1)  [Ch 01] [Pg 01] [Cell 01] [V/C Id:  1/ 1]          : time: 00:07:18.22 / 25 fps     [Pos: 00:07:18.22] [Frames: 10972] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    IFOEdit:
    Das zweite Kapitel beginnt laut verwendeter Celltimes bei Frame 10948. Und ein Menu ist nicht vorhanden.
    Gruß Frank
  • wie gewünscht : TMPGEnc DVD Author v1.5.19.59
    Erstmal meldet TMPGEnc beim Video Import The video GOP is too long. ???
    AC3 Import:
    Title Set (Movie) attributes:		Video: MPEG-2 720x576 (PAL) (PAL 625/50) (16:9) (letterboxed)		Audio 1:      Not Specified        (Dolby AC-3) 6ch 48Kbps DRC       (ID: 0x80)		PGC_1 (program chain): [Title(TTN): 1] [00:03:08.05 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1)		[Ch 01] [Pg 01] [Cell 01] [V/C Id:  1/ 1]          : time: 00:03:08.05 / 25 fps     [Pos: 00:03:08.05] [Frames: 4705] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    LPCM Import:
    PGC_1 (program chain): [Title(TTN): 1] [00:03:06.04 / 25 fps] (Programs: 1) (Cells: 1) (uses VOB-IDs: 1)
    [Ch 01] [Pg 01] [Cell 01] [V/C Id:  1/ 1]          : time: 00:03:06.04 / 25 fps     [Pos: 00:03:06.04] [Frames: 4654] SP/ILVU/DISC/SA:[ no/ no/yes/ no]
    - nur eine Audiospur
    -- keines der beiden erzeugten DVDs funktionierte. Die DVD "harkte". Also kein flüssiges Abspielen.
  • Interessantes Ergebnis. Bislang hatte ich mit von TMPGEnc DVD Author erzeugten Disks keinerlei Probleme. Allerdings brenne ich auch nicht damit, sondern benutze dazu die Engine von DVD PowerTools.
  • Dann erwecken wir diesen Post mal wieder von den Toten :D
    katjarella:
    Dein Vergleich ist ja doch schon eine Weile her...
    Aber - hast du vielleicht das Testmaterial noch zur Verfügung?
    Mich würde interessieren wie MUXMAN damit abschneidet!
    EDIT:
    Wie bekommt man die Daten aus IfoEdit - so wie Katjarella oben?
    Habe jetzt einen mit DVD2DVD-R 1.8.1 encodeten Film sowohl mit IfoEdit 0.96 als auch Muxman 0.9 gemacht.
    Die Anzahl der Frames ist bei Beiden identisch mit der Angabe in der ECL.
    Nur bei 3 Kapitelmarken gibt es leichte Differenzen (max. 12 Frames).
    Bei den Menu-Attributes trägt mir allerdings Muxman MPEG-1 ein?
  • Danke fürs Feedback!
    Zitat von katjarella
    Ifoedit > open *.ifo > Copy2Clipboard :)
    Dachte ich mir ja fast ;)
    Allerdings habe ich immer im unteren Fenster markiert :seher:
  • Hat Derrow bei 0.971 nicht gerade dabei was verbessert?
  • hallo katjarella,
    kannst du mal beschreiben wie so ein test abläuft? also wie du vorgegangen bist?
    gibt es auch irgendein testverfahren um die qualität einer geauthorten dvd zu überprüfen?
    thx
  • * kannst du mal beschreiben wie so ein Test abläuft?
    * also wie du vorgegangen bist?
    * gibt es auch irgendein testverfahren um die qualität einer geauthorten dvd zu überprüfen?
    Der Test ist schon eine Weile her und wenn ich mal Zeit habe, Teste ich auch die neueren Versionen inc. Muxman / DVDPlanner.
    Und was soll ich da beschreiben? Man erstellt ( multiplext) Quellen mit dem TestProgramm, schaut sich das Ergebnis ( hier mit IfoEdit) an und vegleicht es mit der sauberen DVD Quelle.
    Testverfahren/ Programme gibt es schon: InterraSurveyor DVD-Video content Analyzer oder DVD-Video Verifier von Philips. Es gibt aber auch Firmen, die das für viel Geld übernehmen und einen DVDMaster vorher auf Fehler prüfen.
    hi,
    also den satz versteh ich nicht ganz, wie kann man denn eine quelle erstellen.
    grübel.
    ist es eigentlich nicht auch eine kontrolle, was du da machst?
    also zwei streams miteinander verbinden und dann aus dem verbund wieder die streams auszulesen um sie mit den orginalen zu vergleichen?(hab ichs jetzt verstanden oder ned?)
    was machen denn so teuere programme wie du sie genannt hast?
    vielen dank
