Posts by RB
Na endlich!
Nein. Jetzt aber...
Bis jetzt alles flasch :zunge:
OK, sollte auch nicht allzu schwierig sein....
Die Insel?
Der Flug des Phoenix? Falls richtig, bitte jemand anders weiter machen
The Big Empty?
Auf doom9.org gibt's eine ausführlichere Liste der Neuerungen, ich kopiere mal:
Display MoreAdded: Content description for audio streams Added: Content description for subpicture streams Changed: Custom Resize form layout Hidden: Audio transcode feature to UI including Size prediction Hidden: Per audio format preferences to UI Fixed: AUDIO_TS and JACKET_P folder also selected on no DVD-ROM and Main Movie only Fixed: Use Instant Drive PDI only if mounted Added: Full screen preview on double click in custom resize dialog Added: Shutdown computer after process Added: Progress in taskbar when minimized Added: Idle Prority when minimized Hidden: Multi device write Added: PCM for VCD conversion Added: New data buffering system when converting Hidden: Support for destination folder (VIDEO_TS folder or image%.2d.pdi) Added: /dstfolder command line option Added: Reduction method saved in VideoCopy Settings Fixed: Quality from VideoCopy Settings restored Added: DBG: save settings automatically (new ICopyBatch.exe is aware of the log) Added: Registry setting "DVDAnalyzeBeforeCustomize" to show customize dialog after analyzing Hidden: Seekbar and chapter selection for preview in DVD Resize Added: Hidden Power Toys (Strg+Shift+F12 in Advanced DVD settings) Added: Hidden setting minimum quality mode reduction (Default: 30%) Fixed: Update checkmarks after changing include DVD-ROM content in resize dialog Fixed: Resize Dialog: various clicks changing other options (DVD-ROM content, menu, etc) Added: Main window restores position Changed: Progress while analyzing Fixed: various analyze bugs Fixed: /autoload command line Added: /autoload file names Added: Resize Dialog Ctrl+F6/F7 asks for filename instead of default Fixed: error on source filter values Fixed: Some Analyze errors Added: /autoburn cmd line to burn to first availible DVD inserted Added: AC3 Encode support ReAdded: Problem cell set handling Fixed: Percent finished in Application.Title when not processing data Fixed: Destination location not shown when writing to folder Fixed: Copy stealing focus when starting new direct show graph (Analyze and transcode) Fixed: Different splitter Buffers for analyze Changed: Aboutbox shows .local dll/ax if existing Changed: (S)VCD writing without CDWizard.exe Added: .local under XP support Added: Language dependent Help filename support Added: Data Size selection button in Customize disc dialog (DVD9 support) Added: Title Lengths in treeview Added: DVD-9 Support to Main UI Added: Auto detection of DVD Destination format Added: DVD Medium Size detection when writing VIDEO_TS/DVD -> DVD Fixed: /autoburn closes ICopy if no ready to burn device is found Fixed: writing of .pdi was broken because of Auto detection of DVD Destination Added: DVD9-PDI writing over IDiscSDK2.dll for correct Layer break handling
Thread: http://forum.doom9.org/showthread.php?s=&threadid=81016 -
Grr, Bild vergessen
Du musst mit IFOUpdate 0.78 (nicht IFOEdit!) die Original-IFOs aktualisieren. Die originale IFO als "original IFO" and die von IFOEdit erstellte IFO als "Authored IFO" laden. Dann im Options-Menü die im Bild gezeigten Einstellungen vornehmen und "Update IFO" klicken.
Quote from LaMpIDisplay More
Hallo Leute
Benutze:
Cinema Craft Encoder 2.67.00.10
eclcce 0.17b
DVD ReBuilder v0.28
Einstellungen:
Options\CCE Options\CCE Basic (v2.67+)
Options\Setup\Path to CCE Basic:.........EclCCE.exeDu must das alles bei "Path to CCE-SP (New)" eintragen, nicht bei CCE-Basic, da Du keinen CCE-Basic verwendest. Dann Options - CCE Options - CCE SP (v2.66+)
1.8 war nicht buggy, es gab lediglich ein Problem mit von jdobb's DVD-RB erzeugten ECLs für CCE-SP 2.50 über die Kommandozeile. Das lag aber nicht an EclCCE, sondern an CCE und DVD-RB. Ist jetzt in der 1.8b wieder behoben.
Passiert das denn nur mit EclCCE? Kann ich mir nicht vorstellen...
In EclCCE 1.8a ist ein Fix dafür eingebaut.
Versuche es doch mal mit den originalen Encodereinstellungen, ZigZag und Progressive Frames aus. Beeinflusst die Qualität nicht, Progressive hat aber wie gesagt mit dem Abspeichern der Farbinformationen zu tun.
Der Film wurde als interlaced encodet, deshalb muß auch Interlaced=True verwendet werden.
Ich lese immer wieder, daß der BitrateViewer hier "falsche Informationen" anzeigen würde, das ist aber nicht korrekt. Natürlich kann der BitrateViewer Dir nicht sagen, ob der Film wirklich interlaced aussieht, er liest einfach, und das völlig fehlerfrei, die entsprechenden Flags im MPEG-Stream aus. Und dieser kann entweder interlaced (equivalent zu Progressive Frame Flag AUS im CCE) oder progressiv (equivalent zu Progressive Frame Flag EIN im CCE) erstellt worden sein. Das hat absolut gar nichts damit zu tun, ob das Material ursprünglich wirklich interlaced war, also beispielsweise von einer DV-Kamera mit 50 Halbbildern pro Sekunde kam.
Viele DVDs werden einfach interlaced encoded, obwohl das Ausgangsmaterial progressiver Film ist, wahrscheinlich um die Darstellung auf das übliche Anzeigegeraät, einen Fernseher, zu optimieren. Nun werden die Farbinformationen bei interlaced YV12 und progressive YV12 unterschiedlich gespeichert, diesem Umstand muß mit ConvertToYUY2(Interlaced=True/False) Rechnung getragen werden. Näheres dazu unter http://forum.doom9.org/showthread.php…8800#post354127
Faustregel: Video mit BitrateViewer bzw. DVD2AVI Preview checken (auf die Frame Type: -Anzeige achten). Erscheint dort "interlaced", dann ConvertToYUY2(Interlaced=True) verwenden. Dann kann man sich das Video anschauen und wenn keine Interlacing-Artefakte zu sehen sind, als progressive encoden.
In Deinem Beispiel wurden auch keine "progressiv + interlaced Informationen vermischt", der Scan Type ist von interlaced/progressive unabhängig, obwohl für echtes interlaced-Material natürlich Alternate statt ZigZag gewählt werden sollte. -
Was sagt denn der BitrateViewer? Progressiv "aussehen" und progressiv encodet sind zwei verschiedene Dinge. Hast Du es probiert?
