Mein WDTV mag kein VC-1 . Werde die Dateien nun mit SelectEven() per avisynth importieren und encoden, danke nochmals.
Beiträge von AlexMineiro
Ja hier mal die Daten...
Mediainfo:
Code[size=8]GeneralComplete name : G:\Encodieren\umwandeln\test.wmvFormat : Windows MediaFile size : 3.17 GiBDuration : 37mn 30sOverall bit rate : 12.1 MbpsMaximum Overall bit rate : 12.1 MbpsEncoded date : UTC 2011-09-03 09:27:49.000VideoID : 2Format : VC-1Codec ID : WVC1Codec ID/Hint : MicrosoftDuration : 37mn 30sBit rate : 1 bpsWidth : 1 920 pixelsHeight : 1 080 pixelsDisplay aspect ratio : 16:9Frame rate : 59.940 fpsBit depth : 16 bitsCompression mode : LossyBits/(Pixel*Frame) : 0.000Stream size : 281 Bytes (0%)AudioID : 1Format : WMAFormat version : Version 2Codec ID : 161Codec ID/Info : Windows Media AudioDuration : 37mn 30sBit rate : 128 KbpsChannel(s) : 2 channelsSampling rate : 44.1 KHzBit depth : 16 bitsStream size : 34.3 MiB (1%)[/size]
Handbrake Scan Log (Analyse):
Code[size=8]OS: Microsoft Windows NT 6.1.7601 Service Pack 1CPU: AMD Phenom(tm) II X4 B50 ProcessorRam: 8190 MB, Screen: 1920x1080Temp Dir: C:\Users\Michael\AppData\Local\Temp\Install Dir: C:\Program Files\HandbrakeData Dir: C:\Users\Michael\AppData\Roaming\HandBrake\HandBrake\0.9.6.4466------------------------------------------- -i "G:\Encodieren\umwandeln\test.wmv" -t0 --min-duration=10 -v [12:26:28] hb_init: starting libhb threadHandBrake 0.9.6 (2012022800) - MinGW x86_64 - http://handbrake.fr4 CPUs detectedOpening G:\Encodieren\umwandeln\test.wmv...[12:26:28] hb_scan: path=G:\Encodieren\umwandeln\test.wmv, title_index=0libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\Encodieren\umwandeln\test.wmv/BDMV/index.bdmvlibbluray/bluray.c:1471: nav_get_title_list(G:\Encodieren\umwandeln\test.wmv) failed (000000000031D200)[12:26:28] bd: not a bd - trying as a stream/file insteadlibdvdnav: Using dvdnav version 4.1.3libdvdread: Encrypted DVD support unavailable.libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failedlibdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failedlibdvdread: Can't open file VIDEO_TS.IFO.libdvdnav: vm: failed to read VIDEO_TS.IFO[12:26:28] dvd: not a dvd - trying as a stream/file insteadInput #0, asf, from 'G:\Encodieren\umwandeln\test.wmv': Duration: 00:37:30.43, start: 0.000000, bitrate: 12083 kb/s Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s Stream #0.1: Video: vc1 (Advanced), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 0 kb/s, 62.50 fps, 59.94 tbr, 1k tbn, 59.94 tbc[12:26:28] No channel layout reported by Libav; guessing one from channel count.[12:26:28] scan: decoding previews for title 1Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...Scanning title 1 of 1...[12:26:35] scan: 10 previews, 1920x1080, 62.500 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1[12:26:35] scan: title (0) job->width:1920, job->height:1072[12:26:35] libhb: scan thread found 1 valid title(s)+ title 1: + stream: G:\Encodieren\umwandeln\test.wmv + duration: 00:37:30 + size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 62.500 fps + autocrop: 0/0/0/0 + chapters: + 1: cells 0->0, 0 blocks, duration 00:37:30 + audio tracks: + 1, Unknown (wmav2) (2.0 ch) (iso639-2: und) + subtitle tracks:HandBrake has exited.[/size]
Handbrake Encoding Log:
Alles anzeigen[size=8] HandBrake 0.9.6 2012022800 OS: Microsoft Windows NT 6.1.7601 Service Pack 1 CPU: AMD Phenom(tm) II X4 B50 Processor Ram: 8190 MB, Screen: 1920x1080 Temp Dir: C:\Users\Michael\AppData\Local\Temp\ Install Dir: C:\Program Files\Handbrake Data Dir: C:\Users\Michael\AppData\Roaming\HandBrake\HandBrake\0.9.6.4466 ------------------------------------------- CLI Query: -i "G:\Encodieren\umwandeln\test.wmv" -t 1 --start-at duration:1800 --stop-at duration:60 -o "G:\Encodieren\Fertig\Test.mp4" -f mp4 -4 --detelecine --decomb -w 1280 --loose-anamorphic -e x264 -q 20 --vfr -a 1,1 -E faac,ffac3 -B 160,160 -6 dpl2,auto -R Auto,Auto -D 0,0 --gain=0,0 --audio-copy-mask none --audio-fallback ffac3 -x b-adapt=2:rc-lookahead=50 --verbose=1 User Query: False [12:27:27] hb_init: starting libhb thread HandBrake 0.9.6 (2012022800) - MinGW x86_64 - http://handbrake.fr 4 CPUs detected Opening G:\Encodieren\umwandeln\test.wmv... [12:27:27] hb_scan: path=G:\Encodieren\umwandeln\test.wmv, title_index=1 libbluray/bdnav/index_parse.c:157: indx_parse(): error opening G:\Encodieren\umwandeln\test.wmv/BDMV/index.bdmv libbluray/bluray.c:1471: nav_get_title_list(G:\Encodieren\umwandeln\test.wmv) failed (000000000031DF80) [12:27:27] bd: not a bd - trying as a stream/file instead libdvdnav: Using dvdnav version 4.1.3 libdvdread: Encrypted DVD support unavailable. libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed libdvdnav:DVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed libdvdread: Can't open file VIDEO_TS.IFO. libdvdnav: vm: failed to read VIDEO_TS.IFO [12:27:27] dvd: not a dvd - trying as a stream/file instead Input #0, asf, from 'G:\Encodieren\umwandeln\test.wmv': Duration: 00:37:30.43, start: 0.000000, bitrate: 12083 kb/s Stream #0.0: Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s Stream #0.1: Video: vc1 (Advanced), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 0 kb/s, 62.50 fps, 59.94 tbr, 1k tbn, 59.94 tbc [12:27:27] No channel layout reported by Libav; guessing one from channel count. [12:27:27] scan: decoding previews for title 1 Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... Scanning title 1... [12:27:33] scan: 10 previews, 1920x1080, 62.500 fps, autocrop = 0/0/0/0, aspect 16:9, PAR 1:1 [12:27:33] scan: title (0) job->width:1920, job->height:1072 [12:27:34] libhb: scan thread found 1 valid title(s) + title 1: + stream: G:\Encodieren\umwandeln\test.wmv + duration: 00:37:30 + size: 1920x1080, pixel aspect: 1/1, display aspect: 1.78, 62.500 fps + autocrop: 0/0/0/0 + chapters: + 1: cells 0->0, 0 blocks, duration 00:37:30 + audio tracks: + 1, Unknown (wmav2) (2.0 ch) (iso639-2: und) + subtitle tracks: [12:27:34] 1 job(s) to process [12:27:34] starting job [12:27:34] work: sanitizing track 1 mixdown Dolby Pro Logic II to Stereo [12:27:34] work: mixdown not specified, track 2 setting mixdown Stereo [12:27:34] sync: expecting 3812 video frames [12:27:34] job configuration: [12:27:34] * source [12:27:34] + G:\Encodieren\umwandeln\test.wmv [12:27:34] + title 1, start 0:30:0.00 stop 0:31:0.00 [12:27:34] + container: asf [12:27:34] + data rate: 12083 kbps [12:27:34] * destination [12:27:34] + G:\Encodieren\Fertig\Test.mp4 [12:27:34] + container: MPEG-4 (.mp4 and .m4v) [12:27:34] + 64-bit formatting [12:27:34] * video track [12:27:34] + decoder: vc1 [12:27:34] + bitrate 0 kbps [12:27:34] + frame rate: same as source (around 62.500 fps) [12:27:34] + loose anamorphic [12:27:34] + storage dimensions: 1920 * 1080 -> 1280 * 720, crop 0/0/0/0, mod 0 [12:27:34] + pixel aspect ratio: 1 / 1 [12:27:34] + display dimensions: 1280 * 720 [12:27:34] + filters [12:27:34] + Detelecine (pullup) (default settings) [12:27:34] + Decomb (default settings) [12:27:34] + encoder: H.264 (x264) [12:27:34] + options: b-adapt=2:rc-lookahead=50 [12:27:34] + quality: 20.00 (RF) [12:27:34] * audio track 1 [12:27:34] + decoder: Unknown (wmav2) (2.0 ch) (track 1, id 0x0) [12:27:34] + mixdown: Stereo [12:27:34] + encoder: AAC (faac) [12:27:34] + bitrate: 160 kbps, samplerate: 44100 Hz [12:27:34] * audio track 2 [12:27:34] + decoder: Unknown (wmav2) (2.0 ch) (track 1, id 0x0) [12:27:34] + mixdown: Stereo [12:27:34] + encoder: AC3 (ffmpeg) [12:27:34] + bitrate: 160 kbps, samplerate: 44100 Hz [12:27:34] yadif thread started for segment 0 [12:27:34] yadif thread started for segment 1 [12:27:34] yadif thread started for segment 2 [12:27:34] yadif thread started for segment 3 [12:27:34] decomb thread started for segment 0 [12:27:34] decomb thread started for segment 1 [12:27:34] decomb thread started for segment 2 [12:27:34] decomb thread started for segment 3 [12:27:34] encx264: min-keyint: 63, keyint: 630 [12:27:34] encx264: encoding with stored aspect 1/1 [12:27:34] encx264: Encoding at constant RF 20.000000 x264 [warning]: --psnr used with psy on: results will be invalid! x264 [warning]: --tune psnr should be used if attempting to benchmark psnr! x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2 x264 [info]: profile High, level 4.0 [12:27:34] reader: first SCR 161880750 id 0x0 DTS 161880750 [12:27:34] sync: adding 189 ms of silence to audio 0x0 start 17010, next 0 [12:27:34] sync: adding 189 ms of silence to audio 0x0 start 17010, next 0 [12:27:34] sync: first pts is 53010 [12:31:51] sync: reached pts 5400900, exiting early [12:31:55] work: average encoding speed for job is 13.952473 fps [12:31:56] reader: done. 1 scr changes [12:31:56] sync: got 3597 frames, 3812 expected [12:31:56] vc1-decoder done: 3870 frames, 1 decoder errors, 0 drops [12:31:56] render: lost time: 0 (0 frames) [12:31:56] render: gained time: 0 (0 frames) (0 not accounted for) x264 [info]: frame I:7 Avg QP:21.11 size: 48015 PSNR Mean Y:53.87 U:56.09 V:56.43 Avg:54.51 Global:47.73 x264 [info]: frame P:936 Avg QP:22.49 size: 20174 PSNR Mean Y:43.91 U:46.61 V:47.05 Avg:44.67 Global:44.54 x264 [info]: frame B:2653 Avg QP:23.96 size: 3083 PSNR Mean Y:43.36 U:46.33 V:46.81 Avg:44.18 Global:44.04 x264 [info]: consecutive B-frames: 0.4% 2.5% 3.2% 93.9% x264 [info]: mb I I16..4: 22.5% 65.1% 12.4% x264 [info]: mb P I16..4: 2.1% 10.5% 0.8% P16..4: 51.8% 15.4% 7.2% 0.0% 0.0% skip:12.1% x264 [info]: mb B I16..4: 0.1% 0.4% 0.0% B16..8: 23.7% 2.1% 0.3% direct: 1.3% skip:72.0% L0:42.2% L1:54.0% BI: 3.8% x264 [info]: 8x8 transform intra:77.5% inter:80.1% x264 [info]: coded y,uvDC,uvAC intra: 61.0% 77.9% 28.3% inter: 11.7% 18.2% 0.5% x264 [info]: i16 v,h,dc,p: 17% 20% 10% 52% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 17% 21% 6% 10% 8% 12% 6% 8% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 20% 17% 5% 12% 8% 10% 5% 5% x264 [info]: i8c dc,h,v,p: 58% 20% 17% 6% x264 [info]: Weighted P-Frames: Y:3.5% UV:1.6% x264 [info]: ref P L0: 57.5% 12.3% 20.7% 9.1% 0.4% x264 [info]: ref B L0: 88.3% 7.9% 3.8% x264 [info]: ref B L1: 98.7% 1.3% x264 [info]: SSIM Mean Y:0.9779111 (16.558db) x264 [info]: PSNR Mean Y:43.521 U:46.421 V:46.894 Avg:44.327 Global:44.174 kb/s:3653.72 [12:31:56] wmav2-decoder done: 0 frames, 0 decoder errors, 0 drops [12:31:56] wmav2-decoder done: 0 frames, 0 decoder errors, 0 drops [12:31:56] mux: track 0, 3596 frames, 27398930 bytes, 3644.44 kbps, fifo 2048 [12:31:56] mux: track 1, 2591 frames, 1203707 bytes, 160.11 kbps, fifo 2048 [12:31:56] mux: track 2, 1726 frames, 1202330 bytes, 159.93 kbps, fifo 1024 [12:31:56] decomb: deinterlaced 0 | blended 0 | unfiltered 3596 | total 3596 [12:31:56] libhb: work result = 0 Encode done! HandBrake has exited. [/size]
hätte auch mal zu dem Thema eine Frage.
Habe hier eine WMV Datei mit Folgenden Attributen:
Video
Format : VC-1
Codec ID : WVC1
Duration : 54mn 0s
Bit rate : 1 bps
Bit depth : 16 bits
Stream size : 405 Bytes (0%)Audio
Format : WMA
Codec ID : 161
Duration : 54mn 0s
Bit rate : 128 Kbps
Bit depth : 16 bits
Stream size : 49.5 MiB (1%)Nehme ich Handbrake und ändere nichts an den Einstellungen macht er daraus eine 30 fps Datei die ruckelfrei ist. Nehme ich aber Ripbot264 mit dem ich am liebsten arbeite und lass die 59.940 fps kommt ne Datei raus die auf meinem WDTV ein wenig komisch aussieht und ruckelt. Mache ich Decimate 23.976 fps ist die Datei auch nicht perfekt. Kann mir jemand sagen welches nun die perfekten Einstellungen wären damit ich mit Ripbot264 die 30 fps hinbekomme damit alles prima aussieht ?
danke für deine Antworten. Also hab vorher gelesen das die 64bit wohl nicht empfohlen wird, deshalb hab ich mal die 32bit version neu installiert sowie die Filter. Bei der Ausgabe von meinen Videos ist das aber auch in den Standard Einstellungen das FFDShow + CoreAVC beide gleichzeitig filtern. Hier ein Screenshot:
test.jpgOder ist das doch normal ?
ich hab mir vor ein paar Tagen den MPC HD 64bit installiert mit folgenden Filtern: Lav Splitter, CoreAVC, FFDSHOW in 64bit jeweils. Irgendwie hab ich das Gefühl das trotz meiner PC Austattung bei manchen Filmen einfach das Vorspulen dauert oder der Player bisschen laggy ist. Hier mal mein System:
Betriebssystem: MS Windows 7 Ultimate 64-bit SP1
CPU: AMD Phenom II X4 - Deneb 45nm Technilogie
RAM: 8,00 GB Dual-Kanal DDR3 @ 669MHz (9-9-9-24)
Motherboard: ASUSTeK Computer INC. M4A78LT-M (AM3)
Grafikkarte: 1024 MBGeForce GTX 550 Ti (CardExpert Technology)
Festplatten: 117GB Corsair Force 3 SSD SATA Disk Device (SATA-SSD) , 488GB Western Digital WDC WD50 00AAKS-007AA0 SATA Disk Device (SATA)Meine Fragen:
1.) Ist die 64bit Version zu empfehlen oder nicht ?
2.) Ist der Lav Splitter oder Haali Media Splitter besser ?
3.) Reihenfolge der Externen Filter: LAV Splitter, CoreAVC, FFDSHOW Video Decoder, LAV Audio Decoder, FFDSHOW so in Ordnung?
4.) Ist das normal das bei laufendem Video und im Menü Filter einmal der FFDSHOW Video Decoder und der CoreAVC Decoder gleichzeitig laufen ?Gruss
AlexM
also bis auf den richtigen Delay beim Ton rauszufinden weil jedes Tool was anderes sagt hab ich es nun hinbekommen und arbeite nun mit Staxrip das ist meiner Meinung stabiler als Megui. Danke nochmals.
Mhh danke, heut nachmittag probier ich erst mal den Tip mit TS-Doctor aus und dann File Convert.. müsste doch ne lösung geben wieso das ZDF HD nicht in Megui funktioniert.. oder hat das einer von euch mal mit Megui / Staxrip probiert und gleicher Fehler zu sehen bekommen ?
Bin grad nicht daheim, jedoch kann ich mit erinnern das der Hali Splitter unten rechts in der leiste aufgetaucht ist als ich codieren wollte bis halt der Fehler aufgetaucht ist mit dem "Speicher"... und das passierte halt immer bei den ZDF HD Rips.. bei Anixe HD war der fehler nicht...
Die Aufnahmen sind per Samsung LED TV aufgenommen worden durch den SamyGo Hack der die Files von DRM befreit.. einstellungen oder so kann ich also keine machen bei der aufnahme ausser auf recording zu drücken
Hi, wenn ich das aber in ein 720 x 404 Xvid umwandeln möchte wie gehe ich da am besten vor ?
habe grad ein wenig Staxrip und Megui getestet und bei Sat1 Aufnahmen (SD) funktioniert alles prima, nehme ich ZDF HD auf kommen ständig "Es wurde versucht im geschützten Speicher zu lesen ..."
Ich habe das Quellmaterial mal hochgeladen und hoffe jmd kann mir weiterhelfen wie ich dieses Quellmaterial entweder in 640 x ??? Xvid oder 1280 x ??? x264 codieren kann.
Download Testvideo -> http://www.file-upload.net/download-3880829/video.zip.html
MediaInfo:
Allgemein
Vollständiger Name : video.ts
Format : MPEG-TS
Dateigröße : 93,6 MiB
Dauer : 56s 578ms
Gesamte Bitrate : 13,8 MbpsVideo
Menü-ID : 11110 (0x2B66)
Format : AVC
Format-Profil : Main@L4.0
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrame : 5 frames
Codec-ID : 27
Dauer : 56s 100ms
Bitrate : 12,0 Mbps
Breite : 1 280 Pixel
Höhe : 720 Pixel
Bildseitenverhältnis : 16:9
Bildwiederholungsrate : 50,000 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.261
Stream-Größe : 80,4 MiB (86%)
colour_primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
transfer_characteristics : BT.709-5, BT.1361
matrix_coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177Audio #1
Format : MPEG Audio
Format-Version : Version 1
Format-Profil : Layer 2
Codec-ID : 3
Dauer : 56s 424ms
Bitraten-Modus : konstant
Bitrate : 256 Kbps
Kanäle : 2 Kanäle
Samplingrate : 48,0 KHz
Video Verzögerung : -1s 115ms
Stream-Größe : 1,72 MiB (2%)
Sprache : DeutschAudio #2
Format : MPEG Audio
Codec-ID : 3
Dauer : 56s 544ms
Bitrate : 192 Kbps
Kanäle : 2 Kanäle
Video Verzögerung : -1s 214ms
Stream-Größe : 1,29 MiB (1%)Audio #3
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec-ID : 6
Dauer : 56s 512ms
Bitrate : 448 Kbps
Kanäle : 2 Kanäle
Kanal-Positionen : Front: L R
BitDepth/String : 16 bits
Video Verzögerung : -1s 211ms
Stream-Größe : 3,02 MiB (3%)
Sprache : DeutschAudio #4
Format : MPEG Audio
Codec-ID : 3
Dauer : 56s 448ms
Bitrate : 192 Kbps
Kanäle : 2 Kanäle
Video Verzögerung : -1s 99ms
Sprache : qaaText
ID : 6130 (0x17F2)-100
Format : Teletext
Sprache : DeutschMenü
Dauer : 56s 578ms
Liste : 6110 (0x17DE) (AVC) / 6120 (0x17E8) (MPEG Audio, Deutsch) / 6121 (0x17E9) (MPEG Audio) / 6122 (0x17EA) (AC-3, Deutsch) / 6123 (0x17EB) (MPEG Audio, qaa) / 6130 (0x17F2) ()
Sprache : / Deutsch / / Deutsch / qaa -
ich wollte mal nachfragen wie man das mit der zweiten Tonspur dann macht mit dem Delay, denn ich bekomme leider auch beim zusammenfügen einen delay an der stelle an der die "cd2" anfängt im gejoinenden Avifilm.
MediaInfo zeigt bei Audio an:
CD1: Video Verzögerung 1s 123 ms
CD2: Video Verzögerung steht nichtsAvimux Gui zeigt an:
CD1: (default) audio: MPEG 1 Layer 3 (VBR, 2 Ch, 48kHz, bad:23040 , delay: 480 ms, 84.2 MByte)
CD2: (default) audio: MPEG 1 Layer 3 (VBR, 2 Ch, 48kHz, bad:11520 , delay: 240 ms, 77.5MByte)Wie kann ich diese Infos nutzen um den Film richtig mit VirtualdubMod zu joinen ?
Danke im vorraus...
Ja der ist bei ffdshow aktiviert. Das Problem taucht ja nur bei Avidemux auf. Nimmt man das Video und lädt es wieder in Virtualdub oder mit Gordianknot z.B. kann man es ja prima in xvid umwandeln. Nur ist nun die Frage warum das so ist, denn wenn ich den ffdshow MJPEG bei VirtualVCR nehme und dann mit Avidemux öffne klappt ja alles einwandfrei.
Erklär mir das mal mit Graph, weis nicht was du damit meinst
jmittelst: du kannst ja mal die obige 52 MB Rawversion downloaden und es in Virtualdub / GordianKnot laden und dann auch mal in Avidemux damit du siehst was ich meine
aufgenommen ist das ja mit ffdshow und dem intergrierten MJPEG Codec. Da kann ich aber leider nix ändern.
Hier hab ich mal das aufgenomme Rohmaterial aus Virtualdub:
Länge 22s
Grösse 54 MB -
hab da ein Problem mit Avidemux und Captures die mit Virtualdub aufgenommen wurden. Das Quellvideo hat folgende Eigenschaften:
Alles anzeigenAllgemein #0 Vollständiger Name : C:\Dokumente und Einstellungen\Standard\Desktop\capture.avi Format : AVI Format/Info : Audio Video Interleave Format/Family : RIFF Dateigröße : 53.4 MiB Spielzeit : 22s 960ms Bitrate : 19 Mbps Video #0 Codec : M-JPEG Codec/Info : M-JPEG including Huffman Tables Spielzeit : 22s 960ms Bitrate : 18 Mbps Breite : 704 Pixel Höhe : 576 Pixel Bildseitenverhältnis : 1.222 Bildwiederholungsrat : 25.000 FPS Bits/(Pixel*Frame) : 1.782 Audio #0 Codec : PCM Codec/Family : PCM Codec/Info : Microsoft PCM Spielzeit : 22s 502ms Bitrate : 1411 Kbps Kanäle : 2 Kanäle Samplingrate : 44 KHz Auflösung : 16 bits
Also aufgenommen wie immer mit MJPEG Quantizer 2, und Audio ohne Komprimierung.
Benutze ich da AutoGK, Virtualdub ,... dann encodieren diese Tools das Video richtig.
Lade ich das Video bei Avidemux, kann ich schon beim cutten oder wenn ich nur das Video durchgehe sehen das ständig ein grünes Bild vorkommt. Wenn ich das encodierte Video anschaue stockt das Bild ständig und der Ton hat ein Knacksen drinne.
Hab auch mal ein Testvideo hochgeladen ( Dauer : 23sekunden , Grösse: 2,3 MB)
http://rapidshare.com/files/11543707/test.avi.html
Weis jmd ob man bei Virtualdub noch irgendwo was besonderes einstellen muss oder mag Avidemux einfach keine Captures von Vdub, denn mit VirtualVCR funktioniert alles.
Hi, hab mir heut mal überlegt ob es möglich ist, das Bild eines Captures mit Hilfe von Photoshop zu verbessern indem man durch ermittelte Werte von Photoshop diese dann in avisynth überträgt ? Hab mal ein Bild genommen und find es nach dem bearbeiten viel besser, jedoch weis ich nicht wie ich diese Werte nun richtig in avisynth übertragen kann, da ich bei der Tonwertkorrektur Rot , Gelb und Blau einzeln korrigiere.
[Blockierte Grafik: http://img1.myimg.de/test8ea.jpg]
Ok,
wenn ich die Datei in den MeGui Avisynth Script Editor reinlade und dann als avs speichere, schreibt der automatisch DirectShowSource(...). Da es sich bei meiner Datei um ffdshow MJPEG Capture handelt, hab ich das in AviSource(...) verändert.
1. Hab 4 Partititionen auf jeder noch knapp 10 gb frei
2. Ja es bleibt nur die 1-muxed.avi übrig.
3. Hab nun einen Fehler gefunden den der MeGui Avisynth Script Creator macht meine MJPEG Captures mit DirectShowSource .. aber file wird immer noch nicht richtig encodet. GSpot zeigt immernoch den Junk: DivxDivxDivx...... an
Meine Xvid Einstellungen:
[Blockierte Grafik: http://img1.myimg.de/20c0.jpg]
mehr hab ich ned verändert..
Achso der Cap is grad mal 1 min lang und 200 MB gross als Info
naja bei 40 GB noch Restplatz sollte der doch Platz haben :cool:
Kann mir jmd weiterhelfen, hab mir megui installiert und versucht nen capture in xvid q=4 + mp3 vbr 50 zu encoden. Leider kommt da nur mist raus siehe bild
Bild: http://img1.myimg.de/1823.jpg
Logfile:
Alles anzeigenGenerating jobs. No desired size. User doesn't care what the filesize is. Leaving bitrate/qp/crf at the profile's valueStarting job job1-1 at 15:47:49 encoder commandline: successfully started encoding Processing ended at 15:47:57 ---------------------------------------------------------------------------------------------------------- Log for job job1-1 Channels=2, BitsPerSample=16, SampleRate=44100Hz C:\Programme\megui\tools\lame\lame.exe -V 4 -h --silent - "C:\Dokumente und Einstellungen\Standard\Desktop\1.mp3" ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job1-1 has been processed. This job is linked to the next job: job1-2 No desired size. Continuing without making any changes. Starting job job1-2 at 15:47:57 encoder commandline: -i "C:\Dokumente und Einstellungen\Standard\Desktop\1.avs" -single -cq 4 -smoother 0 -max_key_interval 250 -nopacked -closed_gop -lumimasking -threads 1 -avi "C:\Dokumente und Einstellungen\Standard\Desktop\1.avi" successfully started encoding Processing ended at 15:50:19 ---------------------------------------------------------------------------------------------------------- Log for job job1-2 xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003 Trying to retrieve width and height from input header Input colorspace is YV12 xvidcore build version: xvid-1.2.0-dev Bitstream version: 1.2.-127 Detected CPU flags: ASM MMX MMXEXT SSE 3DNOW 3DNOWEXT TSC Detected 1 cpus, using 1 threads. Tot: enctime(ms) =94585.00, length(bytes) = 14264487 Avg: enctime(ms) = 63.23, fps = 15.82, length(bytes) = 9535 I frames: 8 frames, size = 45061/ 360495, quants = 4 / 4.00 / 4 P frames: 511 frames, size = 19772/10103530, quants = 4 / 4.00 / 4 B frames: 975 frames, size = 3897/3800462, quants = 7 / 7.00 / 7 This is a CQ job so there's no desired bitrate. Obtained video bitrate: 1914756 kbit/s ---------------------------------------------------------------------------------------------------------- Job completed successfully and deletion of intermediate files is activated job job1-2 has been processed. This job is linked to the next job: job1-3 Starting job job1-3 at 15:50:19 encoder commandline: -v "C:\Dokumente und Einstellungen\Standard\Desktop\1.avi" -a "C:\Dokumente und Einstellungen\Standard\Desktop\1.mp3" -o "C:\Dokumente und Einstellungen\Standard\Desktop\1-muxed.avi" successfully started encoding Processing ended at 15:50:20 ---------------------------------------------------------------------------------------------------------- Log for job job1-3 DivXMux: Version 6.1 Build Num: 36 Output File Streams: TrackId 0: Video Stream: From AVI Frame Rate: 25000.000000 Resolution: 640x528 TrackId 1: Audio Stream: From MP3 SamplesPerSec: 44100 BlockAlign: 1152 ERROR: DIVXMUX_DISKSPACE while muxing
Mhh also lass ich das mal "ausgeschaltet" .. benutz für meine Tv Captures immer dieses Script
Alles anzeigenLoadPlugin("C:\programme\AviSynth 2.5\plugins\Peachsmoother\Peachsmoother.dll") LoadPlugin("C:\programme\AviSynth 2.5\plugins\Undot\Undot.dll") #LoadPlugin("C:\programme\AviSynth 2.5\plugins\TomsMoComp\TomsMoComp.dll") AviSource("H:\capture.avi",Pixel_Type="YUY2") # Anfang Trimmen Trim(35,0,false) # Deinterlacer #TomsMoComp(1,5,1) # Entrauscher PeachSmoother(noiselevel=4.286, baseline=3.141, NoiseReduction = 60, Stability = 30, Spatial = 0) # Resizer LanczosResize(576,432,3,0,698,572) # Sonstiges ColorYUV(levels="PC->TV") # Sonstiges 2 FadeOut(25) # Entrauscher 2 Undot()
Denk mal das "entrauscht" dann sowieso schon gut.
