A:\Aufnahme>set _ffmpeg_="C:\ffmpeg\bin\ffmpeg.exe"
A:\Aufnahme>set _x264_="C:\MeGui\tools\x264\x264.exe"
A:\Aufnahme>set _input1_="A:\Aufnahme\Test.mkv"
A:\Aufnahme>set _name_=Test2
A:\Aufnahme>"C:\ffmpeg\bin\ffmpeg.exe" -i "A:\Aufnahme\Test.mkv" -map 0:v -map 0
:1 -c:v libx264 -c:a copy -preset veryfast -crf 15 -pix_fmt yuv420p10le -x264-pa
rams keyint=100:bframes=0 "Test2 Video1.mkv"
ffmpeg version N-92179-gc27c7b49dc Copyright (c) 2000-2018 the FFmpeg developers
built with gcc 8.2.1 (GCC) 20181011
configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfi
g --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-lib
freetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amr
wb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --
enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-l
ibwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --
enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --en
able-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --en
able-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --e
nable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enab
le-avisynth
libavutil 56. 19.101 / 56. 19.101
libavcodec 58. 33.100 / 58. 33.100
libavformat 58. 19.100 / 58. 19.100
libavdevice 58. 4.105 / 58. 4.105
libavfilter 7. 33.101 / 7. 33.101
libswscale 5. 2.100 / 5. 2.100
libswresample 3. 2.100 / 3. 2.100
libpostproc 55. 2.100 / 55. 2.100
Input #0, matroska,webm, from 'A:\Aufnahme\Test.mkv':
Metadata:
ENCODER : Lavf58.19.100
Duration: 00:00:10.36, start: 0.000000, bitrate: 42 kb/s
Stream #0:0: Video: h264 (High 10), yuv420p10le(progressive), 2048x1152, 50
fps, 50 tbr, 1k tbn, 100 tbc (default)
Metadata:
ENCODER : Lavc58.33.100 libx264
DURATION : 00:00:10.363000000
Stream #0:1: Audio: vorbis, 44100 Hz, stereo, fltp (default)
Metadata:
title : Track1
ENCODER : Lavc58.33.100 libvorbis
DURATION : 00:00:10.359000000
Stream mapping:
Stream #0:0 -> #0:0 (h264 (native) -> h264 (libx264))
Stream #0:1 -> #0:1 (copy)
Press [q] to stop, [?] for help
[libx264 @ 0000006e77f22ec0] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
AVX
[libx264 @ 0000006e77f22ec0] profile High 10, level 5.0, 4:2:0, 10-bit
[libx264 @ 0000006e77f22ec0] 264 - core 157 r2932 303c484 - H.264/MPEG-4 AVC cod
ec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 r
ef=1 deblock=1:0:0 analyse=0x3:0x113 me=hex subme=2 psy=1 psy_rd=1.00:0.00 mixed
_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pski
p=1 chroma_qp_offset=0 threads=18 lookahead_threads=6 sliced_threads=0 nr=0 deci
mate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=0 weightp=1 keyi
nt=100 keyint_min=10 scenecut=40 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1
crf=15.0 qcomp=0.60 qpmin=0 qpmax=81 qpstep=4 ip_ratio=1.40 aq=1:1.00
Output #0, matroska, to 'Test2 Video1.mkv':
Metadata:
encoder : Lavf58.19.100
Stream #0:0: Video: h264 (libx264) (H264 / 0x34363248), yuv420p10le, 2048x11
52, q=-1--1, 50 fps, 1k tbn, 50 tbc (default)
Metadata:
encoder : Lavc58.33.100 libx264
Side data:
cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: -1
Stream #0:1: Audio: vorbis (oV[0][0] / 0x566F), 44100 Hz, stereo, fltp (defa
ult)
Metadata:
title : Track1
frame= 59 fps=0.0 q=35.0 size= 5kB time=00:00:01.40 bitrate= 27.8kbits/
frame= 140 fps=139 q=35.0 size= 15kB time=00:00:03.03 bitrate= 39.7kbits/
frame= 223 fps=148 q=35.0 size= 15kB time=00:00:04.66 bitrate= 25.9kbits/
frame= 306 fps=152 q=35.0 size= 24kB time=00:00:06.35 bitrate= 31.0kbits/
frame= 389 fps=155 q=35.0 size= 33kB time=00:00:07.98 bitrate= 34.2kbits/
frame= 470 fps=156 q=35.0 size= 43kB time=00:00:09.62 bitrate= 36.3kbits/
frame= 518 fps=155 q=-1.0 Lsize= 54kB time=00:00:10.34 bitrate= 42.8kbits
/s speed=3.09x
video:43kB audio:0kB subtitle:0kB other streams:0kB global headers:4kB muxing ov
erhead: 24.663485%
[libx264 @ 0000006e77f22ec0] frame I:6 Avg QP:10.50 size: 484
[libx264 @ 0000006e77f22ec0] frame P:512 Avg QP:13.01 size: 79
[libx264 @ 0000006e77f22ec0] mb I I16..4: 100.0% 0.0% 0.0%
[libx264 @ 0000006e77f22ec0] mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0
% 0.0% 0.0% 0.0% skip:100.0%
[libx264 @ 0000006e77f22ec0] 8x8 transform intra:0.0%
[libx264 @ 0000006e77f22ec0] coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0%
0.0% 0.0%
[libx264 @ 0000006e77f22ec0] i16 v,h,dc,p: 99% 0% 1% 0%
[libx264 @ 0000006e77f22ec0] i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 0% 0% 100% 0% 0%
0% 0% 0% 0%
[libx264 @ 0000006e77f22ec0] i8c dc,h,v,p: 100% 0% 0% 0%
[libx264 @ 0000006e77f22ec0] Weighted P-Frames: Y:0.0% UV:0.0%
[libx264 @ 0000006e77f22ec0] kb/s:33.47
A:\Aufnahme>pause
Drücken Sie eine beliebige Taste . . .
