Beiträge von wilgut
Hi
Ich habe das gleiche Problem. Will 2 CDs machen und jedesmal macht er 3. Ob mit DVD2SVCD alleine oder mit D2SRoba. Mit der Version 2.5 habe ich das Problem nicht, nur mit der 2.67.
Was könnte da echt schuld sein.
Hier meine Logdatei:
WNASPI32.DLL 4.6.0.1021
- 29.06.2006 10:30:19
- AVI to SVCD Conversion
- AVI2SVCD ver. 1.2.3 build 1
Initializing
- E:\lebenkomplett.avi
Initializing finished.
- 29.06.2006 10:30:21
- Free on drive C: 4235.89 mb
- Free on drive E: 27336.58 mb
- AUDIO Extraction
Audio extraction finished.
- 29.06.2006 10:32:29
- Free on drive C: 4235.82 mb
- Free on drive E: 27084.46 mb
- AUDIO conversion
- 29.06.2006 10:32:32
- AUDIO conversion
Converting MP2 to WAV. Filename: E:\DVD2SVCDAVI\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Programme\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"E:\DVD2SVCDAVI\Encoded_audio_1.mp2.wav" "E:\DVD2SVCDAVI\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of E:\DVD2SVCDAVI\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: E:\DVD2SVCDAVI\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\DVD2SVCDAVI\Encoded_audio_1.mp2.wav" -output "E:\DVD2SV~1\Encoded_audio_1.mp2" -logfile "E:\DVD2SV~1\Encoded_audio_1.log" ) -ota( -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 192 -m s )
Audio conversion of E:\DVD2SVCDAVI\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 29.06.2006 10:48:13
- Free on drive C: 4235.67 mb
- Free on drive E: 25723.02 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 1667869728
AudioSectors: 160909112
VideoPAPO: 23343624
ScanOffsetBytes: 198272
SeqAligningBytes: 12601313
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 1470817399.07
Seconds: 6615.08
CalcMPEGStream: 1470817399.07
Frames: 165227
CDSize: 800.00
Number of CDs: 2
Cut point 795.00
Variable Settings:
Frames: 165227
Anti Noise Filter: Off
Passes: 2
Image Quality: 17
VAF file creation: On
Video Encoding Mode: Multipass VBR
Min. bitrate: 300
Max. bitrate: 2562
Avg. Bitrate: 1778
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\dgindex\DGDecode.dll")
AVISource("E:\LEBENK~1.AVI",audio=false)
ConvertToYUY2()
Import("C:\Programme\DVD2SVCD\Tylo\RoBaConditional.avs")
BicubicResize(480,416,0.0,0.6)
AddBorders(0,80,0,80)
Import("E:\DVD2SVCDAVI\ResampleAudio.avs")
ResampleAudio(44100)
----AVS End----
Closing program
CCE Max Speed: 0.000
Video Encoding finished.
- 29.06.2006 12:08:59
- Free on drive C: 4234.83 mb
- Free on drive E: 24218.35 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Programme\DVD2SVCD\bbMPEG\default.ini
- 29.06.2006 12:09:02
- Free on drive C: 4234.82 mb
- 29.06.2006 12:09:05
- 29.06.2006 12:09:08
- Multiplexing and cutting
Offset in Seconds: 1
Executing bbMPEG.
Variable Settings:
Movie offset: 1 seconds
Cut point: 795 mb
Executing RunbbMPEG. Commandline:
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\DVD2SVCDAVI\bbMPEG_Muxed_File.mpg"
Multiplexing and cutting finished.
- 29.06.2006 12:20:11
- Free on drive C: 4234.72 mb
- Free on drive E: 22564.97 mb
- Determining length of audio
Analyzing: E:\DVD2SVCDAVI\bbMPEG_Muxed_File00.mpg
3165.127 seconds E:\DVD2SVCDAVI\bbMPEG_Muxed_File00.mpg
Analyzing: E:\DVD2SVCDAVI\bbMPEG_Muxed_File01.mpg
3180.042 seconds E:\DVD2SVCDAVI\bbMPEG_Muxed_File01.mpg
Analyzing: E:\DVD2SVCDAVI\bbMPEG_Muxed_File02.mpg
262.713 seconds E:\DVD2SVCDAVI\bbMPEG_Muxed_File02.mpg
Analyzing finished.
- 29.06.2006 12:22:13
- Free on drive C: 4234.69 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 27
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"C:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="E:\DVD2SV~1\CD_Image_File_CD1.cue" --bin-file="E:\DVD2SV~1\CD_Image_File_CD1.bin" "E:\DVD2SV~1\VCDXBU~1.XML"
- 29.06.2006 12:25:24
- Free on drive C: 4234.67 mb
- Free on drive E: 21759.48 mb
CD image #2: CD_Image_File_CD2.bin
"C:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="E:\DVD2SV~1\CD_Image_File_CD2.cue" --bin-file="E:\DVD2SV~1\CD_Image_File_CD2.bin" "E:\DVD2SV~1\VCDXBU~2.XML"
- 29.06.2006 12:28:44
- Free on drive C: 4234.64 mb
- Free on drive E: 20953.89 mb
- No. of chapters to create: 3
CD image #3: CD_Image_File_CD3.bin
"C:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="E:\DVD2SV~1\CD_Image_File_CD3.cue" --bin-file="E:\DVD2SV~1\CD_Image_File_CD3.bin" "E:\DVD2SV~1\VCDXBU~3.XML"
MFG
Zitat von PlaYaAhOk ich werds heute Abend mal versuchen und berichten ob es geklappt hat!
Besten dank schonmal -
HI
dann müsste ich die 8 sek. von cd2 an cd1 wieder anbinden. Werde es mal versuchen, aber es wäre interessant wieso das passiert. Hab etliche filme so gemacht ausser bei 2 ist das.
bye -
Hi
Ich habe folgendes Problem und auch nichts im Board dazu gefunden.
Bei 2 Filmen das gleiche Problem.
Mit DVDdecrypter die DVD auf die Platte gerippt (File Mode), dann mit DVD2SVCD plus D2Sroba encodet. Bei CD1 am Ende ist der Film aus und der Ton läuft aber noch 8 sek. , bei CD2 Bild ist da und nach 8 sek. fängt der ton an, sprich die 8 sek. von CD1 gehören auf die CD2. Ton ist synchron.
Dann hab ich die DVD nur mit DVD2SVCD gemacht und da kann er CD2 nicht machen, da das mpg file 1,2 Gig gross ist.
Wie oder was kann ich machen das es funzt, bzw. was mach ich falsch ?
Habe mal die log datei angehängt.
Ich danke im Vorraus.
mfg
