Die Betas wollen bei mir überhaupt nicht... der GUI "flackert" ständig beim Einlesen, Aufhänger und Abbrüche an jeder Ecke. Die 3.1.5 dagegen geht wunterparr.
Posts by Jan T.
Die Änderungen seit 3.05:
QuoteDisplay More
Version 3.1.5 - 8 Feb 2004
--------------------------Added warning in case of re-authoring menus: reminder that they
will be converted into video clips, not menus.Fixed closed captions: no longer stripped from output files.
Fixed navigation command for "no subpicture" in re-author.
Also now use separate commands for default audio and subpicture
as easier for IFOedit users.Changed default streams GUI in re-author mode.
Fixed various problems in still-picture encoder:
- PTS/DTS set correctly
- timestamp of sequence end code recorded in NV_PCK
- 3:2 pulldown disabledFixed checking of DVD files when opened in "open files" mode.
Fixed ISO-639 code for Hebrew to "iw".
Automatically stop video preview when doing quick analysis in
re-author mode.Improved support for mousewheel in DVD browser view.
Backup proceeds without warning if total compilation size is
within 128KB of the target size. This helps prevent warnings if
automatic compression is slightly inaccurate (due to floating
point rounding error).Added menu option to turn on/off "combined shared titles" in
full-disc mode.Changes to application startup code, attempt to fix crash on
some windows 2000 systems.Added Carlitus/Mandraker toolbar buttons.
Changed compiler switches to optimize for Pentium systems.
Changed all spellings of "disk" to "disc" (except in the case
of "hard disk").Fixed small bug in main window where selected menus could fail
to deselect.Version 3.1.4 - 25 Jan 2004
---------------------------Booktype DVD-ROM is checked by default, disabled if unsupported.
Fixed bug where deep analysis could still be forced on.
Added preferences option for "built-in software renderer" which
solves video preview problems on some systems.Preview window now tries to play only audio streams which are
available in a title.Changes to file reading code, can enable overlapped I/O and
specify read block size by options in preferences.Automatically stop video preview when using Start/End control in
re-author mode.Fixed problem of incorrectly reported burning speeds.
Prefix drive letter to list of available burning devices.
Fixed bug where analysis results file could be saved to the wrong
filename after "deep analysis before backup", so the results were
not cached when opening the same DVD a second time.Some performance improvements, analysis and encoding approx. 6%
faster on test systems.Version 3.1.3 - 18 Jan 2004
---------------------------Added support for RGB 16-bit and 24-bit video preview (for really
old video cards).Fixed possible crash during video preview initialization.
Added preference options for overlapped I/O and read block size,
this may increase ripping performance on some systems.Changes to Nero initialization parameters which caused excessively
slow read speeds on some configurations.Added Nero burn options: write speed, book type and DVD+R/RW high
compatibility mode switch.Fixed "no default audio" and "no default subpicture" options in
re-author mode. These are the default selection. In this case the
DVD player determines which streams to play.Fixed bug where deep analysis could still be forced on.
Increased maximum compression to same level as 3.0b5.
Fixed bug which prevented opening of individual IFO files (can
do this by dropping IFO file into DVD Shrink main window, use with
caution because unless you open a VIDEO_TS.IFO file the output
will not be a complete DVD).Version 3.1.2 - 13 Jan 2004
---------------------------Fixed possible corruption of output video when low compression
applied at a scene change. This may have caused pixelation or
intermittent freezing.Some changes to support unicode build for Japanese language.
Version 3.1.1 - 11 Jan 2004
---------------------------Disabled overlapped IO in UDF disc reader: this solves problems with "DVD Region Free" software.
Ensure all overlapped IO in generic file system code is aligned to sector boundaries.
Added option to enable/disable Nero in preferences.
Fixed bug where "deep analysis before backup" was forced on, even though no compression required.
Some modification to Nero initialization parameters, which solves problems when virtual cd-drive software is installed.
Set "system default renderer" to the default DirectX video renderer instead of VMR-9.
Added support for YUVY, YUY2 and YVYU directshow formats.
Don't eject burned DVD if "shutdown when complete" was selected.
Fixed crash when opening IC8 generated DVDs. They still cannot be opened however.
Modified text of "set toolbar buttons" dialog, so people don't think it is wallpaper.
Version 3.1 - 10 Jan 2004
-------------------------Added "analysis not necessary" message if click analysis but DVD
does not require any compression. In this case, deep analysis option
is also disabled in backup dialog.Added "phoenity" buttons from Lim Chee Aun.
Version 3.1 Beta 10 - 9 Jan 2004
--------------------------------Added dummy help file when hit F1.
Modified text in RCE dialog.
Changed dialog fonts to "MS Shell Dlg" which should map to Tahoma
on XP/2000. Backup and preferences window fonts refuse to change
however.Version 3.1 Beta 9 - 8 Jan 2004
-------------------------------Added Ctrl+R, Ctrl+B keyboard accelerators.
Modified view menu.
Added default audio/subpicture selection in re-author mode (by
popup menu)Fixed bug where "logical stream remapping" would attempt to remap
subpicture stream no 62 and 63 (these IDs have special meaning and
should not be remapped)."Logical stream remapping" is unchecked by default.
Fixed bug where non-logical stream remapping would fail to zero
completely the disabled stream in PGC_GI tables.Added "Mixed Compression" entry to the video compression box which
is purely for information, better than displaying a blank entry.Version 3.1 Beta 8 - 8 Jan 2004
-------------------------------Burn dialog automatically steps progress control when in "waiting
for insert media" mode: try to create the impression that we have
not crashed, but are waiting...Wrapped NeroAPI code in exception handlers: if a crash occurs
within Nero, then DVD Shrink should be able to continue (without
burning functionality).Improved checking of target folder validity.
Improved handling of scenario where the burn target is the same
drive as the current DVD source material: user is prompted to insert
blank media after encoding and replace original disc after burning.Added "Logical remapping of enabled streams" option. This is checked
by default. If checked, all disabled streams are entirely removed
from IFO files, and menu buttons, navigation commands are remapped to
point to the correct remaining streams. If unchecked, disabled streams
are only marked as unavailable in PGC_GI tables, and no remapping of
any kind occurs. The first (default checked) option is generally
recommended, but may cause problems with stream selection on some
discs.Version 3.1 Beta 7 - 7 Jan 2004
-------------------------------Changed deep analysis button, it is always enabled but a message
will popup if no analysis necessary.Changed rate reporting to KB/s rather than MB/s, which makes easier
comparison with DVD Decryptor.Changed back to "DVD Shrink 2.3" buttons by default.
Changed Aymeric buttons name to "Smooth" at request.Fixed progress bar in analysis dialog, so it starts at an offset
depending how much of the DVD has already been analysed.If error occurs during Nero initialization (demo version expired,
etc) then burning is disabled and backup dialog displays hyperlink
to http://www.nero.com instead. Backup to hard disk will function
normally.Append ".nrg" extension if user doesn't type one when saving
an image file.Added property page for burn settings if burning is enabled
* volume label
* auto erase RW media if non-empty
* image recorder fileVersion 3.1 Beta 6 - 6 Jan 2004
-------------------------------Added burning functionality.
Burning is enabled if you have nero 6 installed. It may also work
with Nero version 5, not yet tested.Changed "finished" dialog to handle the various states:
* finished without burning
* finished and burned successfully
* finished but burning failedAdded hyperlink to finished dialog, opens windows explorer at
the output file folder.Changed DVD opening code to allow open of partial (incomplete) DVD
folders in re-author mode. VIDEO_TS.IFO file must exist however.Added aymeric buttons, and set them to default. Not fully decided
on this yet.Version 3.1 Beta 5 - 4 Jan 2004
-------------------------------Fixed bug in re-author where titles would fail to deselect (this
caused unintended titles could be dragged into composition).Fixed crash if attempt to load a DVD from invalid media.
Increased shutdown time to 120 seconds.
Deep analysis before backup is unchecked by default.
Decreased time to wait for state change in preview window to 100ms
which can improve response when selection changes.Added device-removal handling. It is now impossible to re-author
a title from an ejected disk, or edit an ejected disk in full-disk
mode (the document closes).Added F5 refresh shortcut. DVD browser should automatically refresh
if a disk is inserted or removed (but volume label does not always
display correctly until manually refreshed).Current re-authored DVD is preserved if you switch away from
re-author mode (it will still be there if you switch back, no matter
what you do in full-disk mode).Disabled copy or drag of the root item in re-author view.
Fixed crash when copy from fulldisk and paste into re-author (beta-
testers are supposed to report this kind of thing!)Added "Close All Open DVDs" menu option which flushes and resets
DVD Shrink cache of opened DVDs.Fixed "Add" operation in re-author, also works with double-click.
Fixed saving of analysis results in re-author mode and after quick
analysis when dragging/adding titles. Analysis results are saved
back to the original source DVD.Moved analysis results folder to common appdata:
C:\Documents and Settings\All Users\Application Data\DVD Shrink.
This folder is version independent and will not change in future
releases of DVD Shrink.Changed DeCSS disk reader to use overlapped IO on WinNT systems,
this may (or may not) increase performance.Version 3.1 Beta 4 - 3 Jan 2004
-------------------------------Fixed crash after start/end frames in re-author.
Keyboard shortcuts:
* F11 - switch in and out of fullscreen preview
* F12 - play/pause previewChanged backup dialog
backup dialog now reports disk space available
better looking GUI
better checking for target folder validityAdded "low priority mode" to preferences dialog
Added "disable all subpicture streams" option in preferencesDeep analysis now hides the application window while analysing.
Added pause/resume function during analysis and encoding.
Version 3.1 Beta 3 - 31 Dec 2003
--------------------------------Changes to preferences dialog layout.
Added preferences option to set DirectX video renderer for video
preview (this may solve problems on some systems).Added preferences option to automatically select audio and subpicture
streams.Fixed bug where deep analysis would recalculate all compression
settings to fill the target size, even if user set custom ratio.Version 3.1 Beta 2 - 30 Dec 2003
--------------------------------Modified preview window to use VMR-9 if possible, otherwise use
default video renderer.Fixed EULA so does not display twice.
Fixed possible hang in video preview when dragging from re-author.
Version 3.1 Beta 1 - 29 Dec 2003
--------------------------------Improved re-author GUI.
Switched to DirectShow architecture for video preview, added audio
preview functionality.Improved pre-analysis routines, analysis takes longer but provides
more accurate estimation of compressed size.Deep Analysis option disabled if no compression necessary.
Fixed bug in "Perform deep analysis before backup" option, where
resulting files could be over/undersized if video not set to
automatic compression.Disabled audio/subpicture streams are remapped and completely
removed from output IFO file _if_ they are disabled in every title
which contains a reference to them.Added support for custom toolbar images.
Fixed "Cannot decrypt VOBS" error.
Improved error reporting to indicate filenames where appropriate.
Added Layer break removal.
Changed "open files" to browse for a folder, not a filename. The
folder must contain a complete DVD title.Added automatic creation of VIDEO_TS and AUDIO_TS subfolders in
output directory.Added "low priority mode" for backup.
Added check for available disk space.
Added shutdown computer warning so user can cancel.
Added installer/uninstaller (courtesy of Inno Setup Compiler).
Improved support for Win98.
No longer steal ".IFO" file extension for DVD Shrink.
Man benötigt das DVD-Video Plugin dazu.
ODER die richtige Seriennummer.
Ja das ist wohl Standard so, und bei Nero geht's auch nicht anders. Nur Grossbuchstaben, keine Leer- und Sonderzeichen, und nur 16 Stellen. Mit anderen Progs geht das aber, wenn ich z. B. mit DVD-lab was brenne, kann ich angeben was ich will, und das wird auch so gebrannt. Ich frage mich allerdings was das ganze überhaupt soll - denn dem PC ist es völlig egal, und ein Standalone ignoriert den Titel völlig... also vielleicht kann uns hier mal jemand aufklären
Du willst mehrere, fertig authorte DVD-Strukturen zusammenfügen, also nicht nur einzelne Videodateien, sehe ich das richtig? Einfach mit DVD Shrink im "Re-Author"-Modus die jeweiligen "DVDs" auf der Platte auswählen, und die enthaltenen Titel neu zusammenstellen! Kapitel, Spuren etc. werden übernommen. Geht wunderbar, und erlaubt auch das zusammenwürfeln von 16:9- und 4:3-Material.
Sowas in der Art hatte ich auch mal - ging nix mehr, auch nicht durch entfernen und neu einspielen. Versuch's vielleicht mal mit einem guten Codec-Pack, evtl. zuvor formatieren
Mit dem K-Lite Pack hab' ich nur gute Erfahrungen gemacht:Du hast nicht zufällig den LAME-ACM- Codec einer Beta-Version installiert??? Instabile ACM-Codecs haben mir schon zweimal die Prioritäten derart geschrottet, dass die Audio- und Video-Codecs nicht mal mehr über die Systemsteuerung angezeigt wurden. Entfernt, alles wieder in Butter...
_
_ -
Die PrimeDisc laufen bei mir am besten von allen
, auf verschiedenen Brennern. Probleme hatte ich bisher mit Intenso, Philips und DataSafe. -
Für's Authoring evtl. besser als IfoEdit:
Das hatte ich auch stets, allerdings nur mit der v1.1 - danach nicht mehr. Die aktuelle 1.4 B1 läuft richtig rund... welche Version verwendest du?
Ich verwende seit einiger Zeit nur noch ReCode und hab' alles andere entmüllt
[Shrink, DVD2one, IC, Fab...] - allerdings gibt's von meiner Seite nicht viel zu posten; denn es funktioniert einfach alles, ohne wenn und aber
. Keine Bugs, keine Einschränkungen, das Non-Plus-Ultra zum DVDs shrinken bzw. zusammenwürfeln. -
PrimeDisc Plus+RW, für 1,65 !!!
Eine gute Alternative wäre auch http://mdienert.de/mpeg2schnitt/ , aber das Teil hat noch so seine Macken; und ohne Demuxen geht garnix [ist aber Absicht].
MPEG2VCR wäre da zu empfehlen: http://womble.com/purchase.htm ; ist aber nix für Linux. Wenn nicht neu kodiert werden soll, beim Abspeichern unter "Video" und "Audio" nix verstellen.
Für sowas gibt's ReJig:
Plus-RWs habe ich vorgestern erstmals für unter 2 Euro entdeckt [Raushau-Ramsch mal ausgenommen], und zwar die 2,4fachen PrimeDisc +RWs [hübsch und sehr sauber, im JewelCase, noch nie Probs damit gehabt] von Technikdirekt.de, für 1,90 Euro [4fache für 2,14 E]; auch sonst ist der Laden preislich in Ordnung:
Beide Hauptfilme der SSE-Edition passen mit einer Tonspur wunderbar auf je einen Rohling, OHNE Komprimierung. DVD Shrink, Re-author, nur die erste - grösste - Datei verwenden, und bei der zweiten Disc den endlosen Nachspann etwas einkürzen. Dasselbe gilt für LOTR I SSE Disc 1.
Den Ricoh MP-5240A gibt's jetzt für 79.- [4x4x8x/24x10x40x DVD+R/+RW, Amazon, VK-frei, Bulk]!
Beiträge solltest du bergeweise finden, aber bestimmt keine Antwort darauf
Heute ist die v1.3 Final erschienen ;)!
