Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:01:06;14" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:04:00;06" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:06:04;00" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:30:54;08" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:33:13;04" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:49:19;21" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "00:58:38;08" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:00:35;21" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:03:11;08" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 4 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 5 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 6 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 7 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 8 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 9 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 10 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 11 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Error The Subpicture "01:08:16;14" in Video Track "VTS01_1_Track", Subpicture stream 12 does not have the same display stop time as Subpicture Stream 1. Subpictures in different streams must have the same duration if highlight exists.
Alles anzeigen
