Nachtrag:
Habe das File eingeladen und gescannt. Bekomme folgende Meldungen:
Found 1 video stream.
Found 1 MPEG audio stream.
VIDEO #1
Resolution 384 x 288
Aspect ratio is reserved (= 0x8)
Frame rate 25.00 fps
Nominal bitrate 1500000 bps
First PTS: 00:02:58.587
MPEG AUDIO #1
MPEG1, Layer 2
joint stereo, sampled at 44.1 kHz.
Bitrate 192 kbps
Each frame contains 26.1 ms audio (627 bytes)
First PTS: 13:14:46.952
==SCANNING==
Input: x:\MPEG\newyork.mpg
Closing starting GOP.
Aiming for sync at 13:14:46.952
Cutting video.
Audio stream 1: PTS DISCONTINUITY
Cutting video.
Aiming for sync at 13:15:21.858
Cutting audio.
PTS discontinuity found in video. Restarting sync.
Cutting video.
ALERT> Cannot sync. Not enough data.
Last fileset:
0 total bytes written
Sync estimate at EOF:
MPEG Audio #1 : sync
(Autosaving log to /dev/null.txt)
Cannot save to /dev/null.txt
Bitte denkt bei Euren Antworten daran, dass am anderen nde nur ein Anfänger sitzt.
Danke
Lunares
