[Error] Log
-[Information] Versions
--[Information] [06.04.2013 00:04:38] MeGUI: 2338
--[Information] [06.04.2013 00:04:38] Operating System: Windows 7 Premium Edition x64 SP1 (6.1.65536.7601)
--[Information] [06.04.2013 00:04:38] .Net Framework: 4.5 (4.5.50709)
--[Information] [06.04.2013 00:04:38] AviSynth: 2.6.0.3 (09.03.2013 09:28:48)
--[Information] [06.04.2013 00:04:38] AvisynthWrapper: 02.01.2009 20:34:04
--[Information] [06.04.2013 00:04:38] Haali Matroska Splitter: 1.11.96.14 (03.03.2011 11:40:46)
--[Information] [06.04.2013 00:04:38] Haali DSS2: 03.03.2011 11:37:50
--[Information] [06.04.2013 00:04:38] ICSharpCode.SharpZipLib: 0.85.5.452 (07.08.2008 20:31:12)
--[Information] [06.04.2013 00:04:38] LinqBridge: 1.0.0.0 (28.05.2009 01:24:34)
--[Information] [06.04.2013 00:04:38] MediaInfo: 0.7.62.0 (22.02.2013 10:32:55)
--[Information] [06.04.2013 00:04:38] MediaInfoWrapper: 0.7.61.0 (06.01.2013 14:47:15)
--[Information] [06.04.2013 00:04:38] MessageBoxExLib: 1.0.2218.28317 (19.12.2008 20:53:04)
--[Information] [06.04.2013 00:04:38] SevenZipSharp: 0.64.3890.29348 (02.01.2011 10:59:32)
--[Information] [06.04.2013 00:04:38] 7z: 9.20 (18.11.2010 16:27:34)
-[Information] Update detection
--[Information] [06.04.2013 00:04:38] Connecting to server: http://megui.xvidvideo.ru/auto/
--[Information] [06.04.2013 00:04:39] All files are up to date
-[Error] Log for job1 (video, 02 Training 2 2130h.avs -> )
--[Information] [06.04.2013 00:05:29] Started handling job
--[Information] [06.04.2013 00:05:29] Preprocessing
--[Information] [06.04.2013 00:05:29] Avisynth input script
---[NoImage] SetMemoryMax(1200)
---[NoImage] SetMTMode(5,4)
---[NoImage] LoadPlugin("C:\Software\Megui\tools\dgindex\DGDecode.dll")
---[NoImage] DGDecode_mpeg2source("E:\1 24h kassetten\2007-01\2007-01.d2v", cpu=4, info=3)
---[NoImage] LoadPlugin("C:\Software\Megui\tools\avisynth_plugin\ColorMatrix.dll")
---[NoImage] ColorMatrix(hints=true, interlaced=true, threads=0)
---[NoImage] LoadPlugin("C:\Software\AviSynth 2.5\plugins\chromashift27\ChromaShift.dll")
---[NoImage] ChromaShift(C=-4,L=-4)
---[NoImage] SetMTMode(2)
---[NoImage] QTGMC( Preset="Fast", EdiThreads=1 )
---[NoImage] crop(6, 4, -14, -8)
---[NoImage] LanczosResize(720,576) # Lanczos (Sharp)
---[NoImage] #denoise
---[NoImage] __film = last
---[NoImage] __t0 = __film.trim(194960, 244175)
---[NoImage] __t1 = __film.trim(256920, 296761)
---[NoImage] __t2 = __film.trim(316004, 365784)
---[NoImage] __t3 = __film.trim(381752, 417271)
---[NoImage] __t4 = __film.trim(433905, 446389)
---[NoImage] __t0 ++ __t1 ++ __t2 ++ __t3 ++ __t4
--[Information] [06.04.2013 00:05:30] resolution: 720x576
--[Information] [06.04.2013 00:05:30] frame rate: 50/1
--[Information] [06.04.2013 00:05:30] aspect ratio: 5:4 (1.250)
--[Information] [06.04.2013 00:05:30] custom command line: --sar 16:15
--[Information] [06.04.2013 00:05:30] Job commandline: "C:\Software\Megui\tools\x264\avs4x264mod.exe" --profile main --level 4.1 --pass 1 --bitrate 2000 --stats "E:\1 24h kassetten\2007-01\02 Training 2 2130h.stats" --keyint 500 --ref 5 --vbv-bufsize 62500 --vbv-maxrate 50000 --sar 16:15 --output NUL "E:\1 24h kassetten\2007-01\02 Training 2 2130h.avs"
--[Information] [06.04.2013 00:05:30] Encoding started
[B]--[Error] [06.04.2013 01:00:58] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)[/B]
--[Information] [06.04.2013 01:00:58] Standard output stream
--[Information] [06.04.2013 01:00:58] Standard error stream
---[NoImage] raw [info]: 720x576p 16:15 @ 50/1 fps (cfr)
---[NoImage] x264 [info]: using SAR=16/15
---[NoImage] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 SlowShuffle
---[NoImage] x264 [info]: profile Main, level 4.1
---[NoImage]
---[NoImage] x264 [info]: frame I:272 Avg QP:23.47 size: 22380
---[NoImage] x264 [info]: frame P:69611 Avg QP:26.09 size: 6064
---[NoImage] x264 [info]: frame B:26254 Avg QP:28.32 size: 1935
---[NoImage] x264 [info]: consecutive B-frames: 45.7% 53.5% 0.8% 0.0%
---[NoImage] x264 [info]: mb I I16..4: 54.7% 0.0% 45.3%
---[NoImage] x264 [info]: mb P I16..4: 31.7% 0.0% 0.0% P16..4: 55.4% 0.0% 0.0% 0.0% 0.0% skip:12.9%
---[NoImage] x264 [info]: mb B I16..4: 4.8% 0.0% 0.0% B16..8: 26.4% 0.0% 0.0% direct:12.7% skip:56.0% L0:31.1% L1:54.9% BI:14.0%
---[NoImage] x264 [info]: final ratefactor: 21.91
---[NoImage] x264 [info]: coded y,uvDC,uvAC intra: 8.8% 46.5% 5.6% inter: 17.7% 28.3% 0.2%
---[NoImage] x264 [info]: i16 v,h,dc,p: 29% 39% 22% 10%
---[NoImage] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 27% 15% 7% 8% 6% 7% 5% 8%
---[NoImage] x264 [info]: i8c dc,h,v,p: 55% 25% 15% 5%
---[NoImage] x264 [info]: Weighted P-Frames: Y:17.1% UV:5.8%
---[NoImage] x264 [info]: kb/s:1993.12
---[NoImage] encoded 96137 frames, 28.91 fps, 1993.12 kb/s
--[Warning] [06.04.2013 01:00:58] The 64 bit mode of x264 is enabled. Depending on the error it may help to disable it in the MeGUI settings.
--[Information] [06.04.2013 01:00:58] Job completed
-[Information] [06.04.2013 01:01:30] Shutdown initiated
Alles anzeigen
