Posts by Selur
    2026.10.09.1:
    *changed*
    • Vapoursynth: improved deblendS6
    • Vapoursynth: move custom LoadPlugin into script-scope
    • Vapoursynth: adjusted torch to ProPainter version 1.2.4
    • Vapoursynth: interlaced handling for output
    • Vapoursynth: using ZSmooth now for nonAVX2 systems too (hope this works)
    • Filtering: option to overwrite input color primaries and transfer
    • Vapoursynth: using Vapoursynth R79 (last API3 compatible version)
    • Vapoursynth: removed xxSceneAware, TDeint, Waifu, SAFA(mlrt), SSIQ
    • Vapoursynth: removed most CTMF dependencies
    • Vapoursynth: tool choice under Filtering->Vapoursynth->Misc->Tools
    • Vapoursynth: deblendS6 turned into deblendS a full sRestore replacement
    • Avisynth: tons of changes to be more like Vapoursynth UI interface and code generation
    • MacOS: shipping Vapoursynth and filters
    • VPX: additional options
    • Removed MPlayer/Mencoder dependencies
    • Analysis: Rewrote interlace analysis to use ffmpeg and be more accurate. Also added a Vapoursynth based version.
    • Vapoursynth: Switching to open-svp for AVX2 and newer cpus.
    *fixed*
    • Vapoursynth: torch - BasicVSR+ resize zoom factor
    • Vapoursynth: LSFmod with nonAVX2
    • Vapoursynth: torch - SwinSR resizer never used
    • Vapoursynth: FrameRate Interpolation, not working with FilterQueue
    *added*
    • Vapoursynth: AntiRing(LR/LR2/..), CDEF, RemoveSpots, RemoveSpotsMCX, AutoChromaFix, HaloBuster,
    • ChubbyRain2, Composite, CLAHE, FixFlicker. BM3D
    • Avisynth: AVSResize, AVSCube, DGCube for Matrix&LUT handling
    • CPU/GPU usage indication
    • Video: VideoToolBox ProRes hardware encoding (on MacOS only)
    *Notes*
    • On Windows: Deinstall old version, before installing, since the Vapoursynth version changed
    Wie sollte man denn Dein Plugin verwenden?
    audio = core.std.AudioSplice(audio_cuts)
    core.avs.LoadPlugin("c:/Users/Selur/Desktop/AudioBoost.dll")
    audio = core.avs.AudioBoost(audio)
    (das komplette Skript)
    liefert:
    File "vapoursynth.pyx", line 3543, in vapoursynth.Function.__call__
    vapoursynth.Error: AudioBoost: argument c1 was passed an unsupported type (expected vnode compatible type but got AudioNode)
    Okay,
    audio = core.avs.AudioBoost(video)
    liefert:
    vapoursynth.Error: Input clip does not have audio.
    Scheint, dass Du davon ausgehst, dass Audio&Video in einem Objekt stecken.
    In Vapoursynth gibt es, soweit ich weiß, aber nur Video- und AudioNodes keine Kombination, sprich so wie Du es aktuell aufgebaut hast geht es in Vapoursynth nicht.
    Auch wenn Du die Werte von Original DAA verwendest?
    Im Vapoursynth (zu faul für Avisynth) mit:
    clip = core.std.Crop(clip, left=240, right=240, top=0, bottom=0) # cropping to 1440x1080
    # contrast sharpening using CAS
    clip = core.cas.CAS(clip, sharpness=0.700)
    # adjusting resolution before resizing
    clip = core.fmtc.resample(clip, w=1440, h=540, kernel="point", interlaced=False, interlacedd=False) # before YUV420P8 after YUV420P16
    # resizing using NNEDI3CL
    # current: 1440x540 target: 1440x1080
    clip = edi_rpow2.nnedi3cl_rpow2(clip, rfactor=2, nsize=3, nns=4) # 2880x1080
    # resizing 2880x1080 to 1440x1080
    clip = core.fmtc.resample(clip, w=1440, h=1080, kernel="spline64", interlaced=False, interlacedd=False) # before YUV420P16 after YUV420P16
    => https://slow.pics/c/k70TB9oy
    In AviSynth wäre:
    LWLibavVideoSource(...) # oder was auch immer für ein SourceFilter
    PointResize(1920,540) # PointResize ist hier bewusst gewählt
    nnedi3_rpow2(rfactor=2,nsize=6,cshift="spline36resize",fwidth=1920,fheight=1080) # spline36resize könne man auch durch was anderes ersetzen
    CAS(sharpness=0.70) # 0.7 scheint mir okay
    das was mir vorschwebt.
    Habe mich lange mit den Chat-KIs unterhalten und kam zu diesem Ergebnis:
    ¯\_(ツ)_/¯
    Das PureVerticalDAA was Du da hast ist ein modifiziertes DAA zu sein, was mehrere Pässe macht. DAA_core ist ein leicht modifiziertes:
    function daa(clip c) {
      nn = c.nnedi2(field=-2)
      dbl = mt_average(selecteven(nn),selectodd(nn),U=3,V=3)
      dblD = mt_makediff(c,dbl,U=3,V=3)
      shrpD = mt_makediff(dbl,dbl.removegrain((width(c)>1100) ? 20 : 11),U=3,V=3) # das Original verwendet 11 bei SD und 20 bei HD
      DD = shrpD.repair(dblD,13)
      return dbl.mt_adddiff(DD,U=3,V=3)
    was dann einfach passes-Mal angewerndet wird,.....
    Was Du also machst ist 3x DAA anwenden,... sehe da nichts besonderes.
    ¯\_(ツ)_/¯
    Habt ihr da Anmerkungen? Kann man die Funktionen noch verbessern, oder was weglassen?
    Ohne Quellmaterial würde ich empfehlen vielleicht mal andere AA filter noch anzutesten.
    (https://web.archive.org/web/2025120604…xternal_filters z.B. Santiag)
    Ja, uncompressed ist verlustfrei, aber halt ohne flags, da diese nicht zu den eigentliche Videodaten gehören. :)
    interleave zu progressive ist aber sc73+sse oder?
    Filternzum Capturen: Ja, da man da Filtern müsste und meist ist ein späteres Filtern zu bevorzugen. (um mehr Kontrolle über das Filtering und die Qualität des Outputs zu haben)
    Normalerweise sollte man in ein komprimiertes lossless Format capturen.
    soll später am TV wiedergegeben werden.
    Du hast die Wahl:
    a. Capture direkt in ein Format was Dein TV oder MediaPlayer versteht, hier fällt lossless und uncompressed i.d.R. raus.
    oder
    b. Capure in ein intermediate format, idealerweise lossless. (dies wäre dann auch zum Archivieren tauglich) Filtere und reencode das aufgenommene Material in ein Format, was dem Dein TV oder MediaPlayer versteht.
    Es gibt i.d.R. zwei Orte für Videotags:
    a. im Videostream selber, was bei RAW Video wegfällt
    b. im Container, soweit dieser sie unterstützt, avi unterstützt nicht, was du willst
    => Entweder anderen Container (z.B. MKV) oder anderes verlustfreies Videoformat (z.B. ffv1) verwenden, oder selber wissen was wo einzustellen ist bei der Weiterverarbeitung.
    An sich schon, aber man müsste quasi die gleichen Werte dort eingeben wie in der Datei, sprich lohnt nicht wirklich.
    Falls das noch mehr Benutzer brauchen kann ich da was für schreiben, aber aktuell erscheint es mir ziemlich exotisch. :)
    Nebenbei: Hybrid erstellt standardmäßig, bereits ein qp-file, wenn die Quelle Kapitelmarken hat und keines manuell gesetzt ist.
    (x264->Misc->Automatically->Create qp file for chapters)
    zu 1.:
    x264 hat zones und ein qpfile.
    => Zones setzen keine Frame Typen, dazu würde man ein qpfile nutzen.
    Unter "x264->Quantization->Custom qp file" kann man ein eigenes qp file verwenden.
    zu 2.:
    In Vapoursynth (Avisynth geht vergleichbar), könnte man sowas wie:
    1.
    black = core.std.BlankClip(clip)
    clip = core.std.Splice([
        clip[:10], # 0-9 normal
        black[10-20], # 1000-19 schwarz
        clip[20:59], # 20-49 normal
        black[50:100], # 50-99 schwarz
        clip[100:] # 100-ENDE normal
    simple und schnell, aber sowohl schwarze als auch normale Intervalle müssen angegeben werden
    oder
    2.
    etwas langsamer, aber nur schwarze Intervalle müssen angegeben. Jedoch mit expliziten Start-&EndFrame.
    in einer Custom Section verwenden.
    Custom Letterboxing könnte man analog machen, erscheint mir aber alles zu exotisch, als dass ich dafür extra UI-Elemente in Hybrid anlegen würde.
    mir ist aufgefallen, das kein MPEG2 für DVD-Video dabei ist.
    wobei, seit ich HD-Videos für hardwareplayer codiere, ich keine DVD mehr erstellt habe... ;)
    Ja, mpeg-2 als Output wird nicht unterstützt.
    Da ich kaum Ahnung habe, was ein guter freier MPEG-2 encoder ist, wie man ihn ordentlich einstellt und den ContainerOverhead von Audio&Video berechnen würde in unterschiedlichen Containern.
    der codecs wie der VVC codec, sind zwar vorhanden, aber nicht in der auswahl gelistet,
    hat das ein grund?
    Hatte mal angefangen dafür Code zu schreiben, ihn aber bis dato nicht aktiviert.
    Großteil liegt an:
    • den Vapoursynth Filtern (3,23GB) , insb.
      • RIFE mit 1,45GB.
      • DFTTest2 mit ca. 366MB
      • BilateralGPU ca. 93MB
      • TimeCube&Co ca. 465MB (da viele .cube files enthalten sind)
    • Encoder&Co ca. 1GB (da nicht gepackt; 200MB allein für NVEncC)
    • Avisynth 64bit ca. 324MB
    [Blocked Image: https://i.ibb.co/pr0XW1m6/grafik.png]
    Hybrid selber ist ca. 30MB groß und dazu kommen ca. 50MB an dlls.
    Und falls man dann die Add-ons noch installiert, wird es halt noch größer. :)
    Der Großteil geht halt vor allem für die GPU basierten Filter und ihre Abhängigkeiten drauf.
    => Problem ist halt zu entscheiden: Was sind 'die gänigsten tools' ?
    Ps.: Mein Hybrid-Ordner mit den AddOns und ein paar anderen Sachen (u.a. mehr modelle für vsgan&vsmlrt) ist entpackt ca. 80GB groß. :P
