Alles klar...vielen Dank! Weiß selber noch nicht richtig wie, aber ich hab es hin bekommen...
Beiträge von Norman2000
Habe die richtige AC3 spur schon einzeln vorliegen...ist auch klasse ton...aber selbst dann hab ich das gleiche Problem...weis echt nicht mehr weiter...
Commandline:
"e:\BeSweetv1.5b29\BeSweet.exe" -core( -input "e:\DVD\VIDEO_TS\VTS_09_1-02.ac3" -output "e:\DVD\VIDEO_TS\VTS_09_1-02.mp2" -logfilea "E:\BeSweetGUIv0.7b4\BeSweet.log" ) -azid( -c normal -g 0.95 -L -3db ) -toolame( -m s -b 192 -e ) -profile( ~~~~~ Default Profile ~~~~~ )Log:
BeSweet v1.5b29 by DSPguru.
Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu).
Using MP2enc.dll v1.129 (23/5/2002), Engine 1.129 <http://www.cdex.n3.net>.Logging start : 11/26/04 , 20:36:45.
e:\BeSweetv1.5b29\BeSweet.exe -core( -input e:\DVD\VIDEO_TS\VTS_09_1-02.ac3 -output e:\DVD\VIDEO_TS\VTS_09_1-02.mp2 -logfilea E:\BeSweetGUIv0.7b4\BeSweet.log ) -azid( -c normal -g 0.95 -L -3db ) -toolame( -m s -b 192 -e ) -profile( ~~~~~ Default Profile ~~~~~ )
[00:00:00:000] +------- BeSweet -----
[00:00:00:000] | Input : e:\DVD\VIDEO_TS\VTS_09_1-02.ac3
[00:00:00:000] | Output: e:\DVD\VIDEO_TS\VTS_09_1-02.mp2
[00:00:00:000] | Floating-Point Process: Yes
[00:00:00:000] +-------- AZID -------
[00:00:00:000] | Input Channels Mode: 2/0, Bitrate: 192kbps
[00:00:00:000] | Output Stereo mode: Dolby surround compatible
[00:00:00:000] | Total Gain: 6.780dB, Compression: Normal
[00:00:00:000] | LFE levels: To LR -3.0dB, To LFE 0.0dB
[00:00:00:000] | Center mix level: BSI
[00:00:00:000] | Surround mix level: BSI
[00:00:00:000] | Dialog normalization: No
[00:00:00:000] | Rear channels filtering: No
[00:00:00:000] | Source Sample-Rate: 48.0KHz
[00:00:00:000] +------- MP2ENC ------
[00:00:00:000] | Bitrate method : CBR
[00:00:00:000] | MP2 bitrate : 192
[00:00:00:000] | Channels Mode : Stereo
[00:00:00:000] | Error Protection: Yes
[00:00:00:000] +---------------------
[00:23:08:000] Conversion Completed !
[00:23:08:000] Actual Avg. Bitrate : 192kbps
[00:01:28:000] <-- Transcoding DurationLogging ends : 11/26/04 , 20:38:13.
Danke für die schnellen Antworten. Mit BeLight hab ich es fürs erste auch nicht hinbekommen. Hier aber meine Commandline von BeSweet:
"e:\BeSweetv1.5b29\BeSweet.exe" -core( -input "e:\DVD\VIDEO_TS\VTS_09_1.VOB" -output "e:\DVD\VIDEO_TS\VTS_09_1.mp2" -substream 0x83 -logfilea "E:\BeSweetGUIv0.7b4\BeSweet.log" ) -azid( -c normal -g 0.95 -L -3db ) -toolame( -m s -b 192 -e )
habe von einer DVD leider nur die vob-files und möchte diese bearbeiten.
Die vob's enthalten 4 Tonspuren, die man unter PowerDVD ach alle anwählen und hören kann. Wollte jetzt nur die deutsche Spur haben und habe Audio und Video mit den MPEG Tools von TMPEnc getrennt und dabei nur die deutsche Spur ausgelesen...leider ging das nur wieder ins AC3 Format. Dann wollte ich AC3 in MP2 mit BeSweet umwandeln (bei einer anderen DVD hatte es so funktioniert - wobei ich mich bei weitem nicht mit all den Funktionen von BeSweet auskenne) aber egal wie ich es anstelle ist nach der Umwandlung nur noch Rauschen da und bei voller Lautstärke kann man nur noch andeutungsweise den originalton raushören obwohl dei AC3 file erstklassigen sound hat.
Ich hoffe mir kann da jemand weiter helfen.
Vielen Dank! -
