So,
BSPlayer zeigt 25 FPS.
Ich hab den rat zu XviD befolgt und hab mir die 1.1.0 von Koepi gezogen.
Damit geht es jetzt klasse, ohne irgendwelche Ruckler. Ich werde jetzt wohl erstmal zu Xvid wechseln.
Also vielen Dank für die ganze Hilfe!
gruß prod
So,
gruß prod
Hier das GKnot Log und die Gspot Export Log
GSpot Export:File Size (in bytes): 1,123,115,008 --- Container Information --- Base Type (e.g "AVI"): AVI(.AVI) Subtype (e.g "OpenDML"): OpenDML (AVI v2.0), Interleave (in ms): Preload (in ms): Audio alignment("split across interleaves"): Total System Bitrate (kbps): 0 Bytes Missing (if any): 0 Number of Audio Streams: 0 --- Video Information --- Video Codec Type(e.g. "DIV3"): DX50/divx Video Codec Name(e.g. "DivX 3, Low-Motion"): DivX 5.0 Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are Installed Duration (hh:mm:ss): 01:41:31 Frame Count: 152274 Frame Width (pixels): 704 Frame Height (pixels): 288 Frame Aspect Ratio (e.g "1.3333"): Frame Aspect Ratio (e.g. "4:3"): Pixel Aspect Ratio ("SAR"): Display Aspect Ratio ("DAR"): 2.444 Frames Per Second: ***ERROR*** Video Bitrate (kbps): 1471 MPEG-4 ("MPEG-4" or ""): MPEG-4 B-VOP ("B-VOP" or ""): QPel ("QPel" or ""): GMC ("GMC" or ""): H264 ("H264" or ""): MPEG-2 ("MPEG-2" or ""): Interlaced ("I/L" or ""): Progressive ("Prog" or ""): Top Frame First ("TFF" or ""): Bottom Frame First ("BFF" or ""): 3:2 Pulldown ("3:2" or ""): Picture-per-field ("PPF" or ""): - Aspect Ratio Related: Broadcast standard: "PAL" (else blank) Broadcast standard: "NTSC" (else blank) src:"VCD", "SVCD", "CVD", or "DVD (else blank): Instructions to convert to VCD, first part: Instructions to convert to VCD, second part: Instructions to convert to SVCD, first part: Instructions to convert to SVCD, second part: Instructions to convert to CVD, first part: Instructions to convert to CVD, second part: Instructions to convert to DVD, first part: Instructions to convert to DVD, second part: Instructions to convert to AVI, first part: Instructions to convert to AVI, second part: --- Audio Information --- MPEG Stream ID (e.g. "0xbd"): MPEG VOB file Substream(e.g. "0x80"): Audio Codec (e.g. "AC3"): Audio Codec Status (e.g. "Codec Is Installed"): Audio Sample Rate (Hz): Audio Bitrate(kbps): Audio Bitrate Type ("CBR" or "VBR"): Audio Channel Count (e.g. "2" for stereo):
Gordian Knot Log:
Options:
Quality/DRF: 20
CreditsStart: 143866
UseEcf: 1
CreditsIVTC: 0
CreditsAppend: 1
DeleteInterm.: 1
EnforceBitrate: 0
AntiShit: 0
Split final file at CD size:700
Calculator:
VideoSize: 1093323 kbyte.
Audio1Size: 333098 kbyte.
Audio2Size: 0 kbyte.
Overhead: 7177 kbyte.
AviSize: 1433600 kbyte (1400 mbyte).
FilesSize: 0 kbyte.
TotalSize: 1433600 kbyte (1400 mbyte).
Interleaving: ac3
Bitrate: 1470 k(=1000)Bits/s
Frames: 152274
FPS: 25.000
Duration: 141:31
Quality: 0.290 bits/(pixel*frame).
CompCheck3: 0.000 bits/(pixel*frame).
CompCheck5: 0.342 bits/(pixel*frame).
Resolution: 704 x 288
Audio 1:
none.
Audio 2:
none.
13:35:52: Audio 1, calc: 333098 kb
13:35:52: Audio 1, disabled, no recalc. - you probably want to add this track later.
Alles anzeigen
Ja, dort hatte ich es eingestellt @ Monk
So, jetzt habe ich nochmal das HomeTheater Profile (B-Frames aus) gewählt und das Audio später in VDMod komplett disabled. ->
Viel weniger, dennoch sichtbare, Ruckler an den gleichen Stellen.
Wie kann ich denn "falsch" Muxen, außer einem unpassen Interleave Wert?
Gemuxed habe ich mit VirtualDubMod.
Divx Profil hatte ich zuerst HomeTheater und später auch ohne Profil mit BFrames und GMC, was der Gemini laut DivxTest CD beides kann.
Overhead heist den Interleave Wert zu verstellen oder was ist gemeint?
Ich hab diesen jetzt über VirtualDubMod auf 42 und das zweite mal auf 83 gestellt, beides mal Ruckler, bei 42 allerdings weniger.
noch mal zum Thema:
Können die Probleme auf dem DVD Standalone dadurch auftreten weil ich beim Compressibility Check bei 99% von der möglich Kompressionsrate gewählt habe?
Hi, also der Player kann Divx3 und 5 getestet mit der DivxTest CD.
Habe die AC3 nochmal mit BeSweet auf 224 kbit komprimiert, gleiches Problem.
Dann mit BeSweet MP3 erstellt, ebenfalls die Ruckler.
Quelle ist PAL, ich bin mir auch ziemlich sicher das ich PAL in GK ausgwählt habe. Deinterlacing war komplett aus.
Ich hab beides versucht und bei beiden Methoden waren die Ruckler immernoch da.
Außerdem hab ich die Auflösugn auf 640 runtergestellt, ohne Erfolg.
Die Ruckler sind reproduzierbar immer bei großen Kameraschwenks. Habe den Film 3 mal komplett mit GK verarbeitet, immer an den gleicheen Stellen die Ruckler.
Interleave (in ms): 40
Preload (in ms): 512
Audio alignment("split across interleaves"): Split
Number of Audio Streams: 1
Duration (hh:mm:ss): 00:42:26
Frame Count: 63640
Video Bitrate (kbps): 1851
B-VOP ("B-VOP" or ""): B-VOP
Audio Codec (e.g. "AC3"): 0x2000(AC3, Dolby Laboratories, Inc) AC3
Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
Audio Sample Rate (Hz): 48000
Audio Bitrate(kbps): 448
Audio Bitrate Type ("CBR" or "VBR"): CBR
Audio Channel Count (e.g. "2" for stereo): 5
Auf dem PC läuft er super.
Auf einem Standalone (Centum Gemnini 322) ruckelt es bei Kamerschwenks.
Ton und Bild haken. Hat der Centrum da ein Bitraten Problem, wenn ja, wo liegt die Grenze der erlaubten Bitrate ungefähr?
