Also ich habe jetzt mal Projetx rüberlaufen lassen. Die Datei war ein 2- minütiges Captures direkt in Mpeg 2. hier log file:
Dienstag, 30. Mai 2006 11.22 Uhr CEST
ProjectX 0.90.4.00 (30.03.2006)
-> working with collection 0
-> save normal log file
-> write all video data
-> write all other data
-> patch c.d.flagged infos of pictures
-> add sequence end code
-> set resolution in SDE
-> PVA: strictly specs. for audio streams
-> VOB: determine diff. Cell timelines
-> TS: ignore scrambled packets
-> TS: enhanced search for open packets
-> TS: join file segments (of Dreambox®)
-> TS: generate PMT stream dependent
-> get only enclosed PES/TS packets
-> concatenate different recordings
-> ensure 1st PES-packet start with video
-> generate PCR/SCR from PTS
-> write output files to: 'H:\Fernsehen'
-> Input File 0: 'H:\Fernsehen\uvs060530-002.MPG' (100.122.624 bytes)
-> Filetype is MPEG-2 PS/SS (PES Container)
-> demux
-> VobID 1 CellID 1 @ 1024 (GOP#0 / Frame#0)
-> found PES-ID 0xE0 (MPEG Video) @ 2062
-> found PES-ID 0xC0 (MPEG Audio) @ 126990
-> video basics: 720*576 @ 25fps @ 0.6735 (4:3) @ 5000000bps, vbvBuffer 112
-> starting export of video data @ GOP# 0
-> next datas start with PTS: 00:00:01.396 / last actual PTS is 00:02:30.004
-> use new PTS-Offset: 00:02:47.808 for following data
-> actual written vframes: 3742
switch to file: H:\Fernsehen\uvs060530-004.MPG (79.620.096 bytes) @ 100122624
!> ID 0xC0 (sub 0x0) packet# 2077, big PTS difference: this 15122520, prev. 13500360
-> Video: fr/ ct/ 1p/ cg/ og/ dg -> 6716/ 0/ 560/ 560/ 0/ 0
-> Video length: 6716 frames @ 00:04:28.640
-> GOP summary: min. 20, max. 24 fields; contains interlaced frames
-> avg. nom. bitrate 4999337bps (min/max: 4072000/6014400)
-> set first sequenceheader bitrate to 6014400bps
---> new File: H:\Fernsehen\uvs060530-002.m2v
--> MPEG Audio (0xC0)
-> check CRC of AC-3 / MPEG-Audio L1,2
-> delete CRC in MPEG-Audio Layer1,2
-> add frames
Audio PTS: first packet 00:00:00.220, last packet 00:04:47.068
Video PTS: start 1.GOP 00:00:00.220, end last GOP 00:04:46.988
-> adjusting audio at video-timeline
-> src_audio: MPEG-1, Layer2, 48000Hz, stereo, 224kbps, CRC @ 00:00:00.000
!> missing syncword @ 4195297, @ 00:02:29.688
!> found syncword @ 4195537
!> 2 frame(s) (48ms) inserted @ 00:02:29.736
audio frames: wri/pre/skip/ins/add 11193/0/0/2/0 @ 00:04:28.632 done...
---> new File: 'H:\Fernsehen\uvs060530-002.mp2'
summary of created media files:
.Video (m2v): 6716 Frames 00:04:28.640 'H:\Fernsehen\uvs060530-002.m2v'
Audio 0 (mp2): 11193 Frames 00:04:28.632 0/0/2/0 'H:\Fernsehen\uvs060530-002.mp2'
=> 175.399.453 bytes written...
-> we have 4 warnings/errors.
Wie kann ich bzw. was muss ich denn eigentlich einstellen um die Fehler mit Projektx zu beheben? sorry für das doppelpost aber projektx hat im Gegensatz zu PVA ein paar Fehler gefunden.
