Jetzt läuft alles durch.
Danke!
Danke!
wxWidgets wird jetzt gebaut. Ich bekomme aber noch folgenden Fehler:
compile ffmpeg 32bit
Klone nach 'ffmpeg-git'...
remote: Counting objects: 4849, done.
remote: Compressing objects: 100% (4002/4002), done.
remote: Total 4849 (delta 1221), reused 2015 (delta 722)
Empfange Objekte: 100% (4849/4849), 10.48 MiB | 430.00 KiB/s, Fertig.
Löse Unterschiede auf: 100% (1221/1221), Fertig.
Prüfe Konnektivität... Fertig.
Checke Dateien aus: 100% (4853/4853), Fertig.
ERROR: libx264 not found
If you think configure made a mistake, make sure you are using the latest
version from Git. If the latest version fails, report the problem to the
ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "config.log" produced by configure as this will help
solve the problem.
sed: kann config.h nicht lesen: No such file or directory
Makefile:2: config.mak: No such file or directory
Makefile:59: /common.mak: No such file or directory
Makefile:100: /libavutil/Makefile: No such file or directory
Makefile:100: /library.mak: No such file or directory
Makefile:102: /doc/Makefile: No such file or directory
Makefile:185: /tests/Makefile: No such file or directory
make: *** Keine Regel, um „/tests/Makefile“ zu erstellen. Schluss.
sed: kann /local32/lib/pkgconfig/libavcodec.pc nicht lesen: No such file or directory
sed: kann /local32/lib/pkgconfig/libavdevice.pc nicht lesen: No such file or directory
sed: kann /local32/lib/pkgconfig/libavfilter.pc nicht lesen: No such file or directory
sed: kann /local32/lib/pkgconfig/libavformat.pc nicht lesen: No such file or directory
sed: kann /local32/lib/pkgconfig/libswresample.pc nicht lesen: No such file or directory
build ffmpeg-git failed...
delete the source folder under '/build32' and start again,
or if you know there is no dependences hit enter for continue it
first close the batch window, then the shell window
Alles anzeigen
Das Löschen von dem Ordner (ffmpeg) hilft nicht.
Ja, jedes Mal. Auch auf 3 verschiedenen PC's alles neu gebaut... Immer wieder der gleiche Fehler. Angefangen hat es am 27.12. Vorher lief alles problemlos.
Ich bekomme aktuell immer folgenden Fehler:
mkdir -p /local32/lib
/usr/bin/install -c -m 644 /build32/wxWidgets-3.0.1/lib/libwxscintilla-3.0.a /local32/lib
/build32/wxWidgets-3.0.1/bk-deps i686-w64-mingw32-g++ -c -o baselib_datetime.o -D__WXMSW__ -DWXBUILDING -I/build32/wxWidgets-3.0.1/src/tiff/libtiff -I./src/tiff/libtiff -I./src/regex -DwxUSE_GUI=0 -DwxUSE_BASE=1 -Wall -Wundef -Wunused-parameter -Wno-ctor-dtor-privacy -Woverloaded-virtual -D_FILE_OFFSET_BITS=64 -I/build32/wxWidgets-3.0.1/lib/wx/include/msw-unicode-static-3.0 -I./include -I/local32/include -D_FORTIFY_SOURCE=2 -D__USE_MINGW_ANSI_STDIO=1 -fno-devirtualize -mthreads -fpermissive -O2 -fno-strict-aliasing -I/local32/include -mms-bitfields -mthreads -mtune=generic -pipe ./src/common/datetime.cpp
./src/common/datetime.cpp: In static member function 'static tm* wxDateTime::GetTmNow(tm*)':
./src/common/datetime.cpp:516:38: error: 'localtime_r' was not declared in this scope
return wxLocaltime_r(&t, tmstruct);
./src/common/datetime.cpp: In static member function 'static wxDateTime::Country wxDateTime::GetCountry()':
./src/common/datetime.cpp:809:52: error: 'localtime_r' was not declared in this scope
struct tm *tm = wxLocaltime_r(&t, &tmstruct);
./src/common/datetime.cpp: In member function 'long unsigned int wxDateTime::GetAsDOS() const':
./src/common/datetime.cpp:1359:52: error: 'localtime_r' was not declared in this scope
struct tm *tm = wxLocaltime_r(&ticks, &tmstruct);
./src/common/datetime.cpp: In member function 'wxDateTime::Tm wxDateTime::GetTm(const wxDateTime::TimeZone&) const':
./src/common/datetime.cpp:1403:48: error: 'localtime_r' was not declared in this scope
tm = wxLocaltime_r(&time, &tmstruct);
./src/common/datetime.cpp:1418:49: error: 'gmtime_r' was not declared in this scope
tm = wxGmtime_r(&time, &tmstruct);
./src/common/datetime.cpp: In member function 'int wxDateTime::IsDST(wxDateTime::Country) const':
./src/common/datetime.cpp:2063:49: error: 'localtime_r' was not declared in this scope
tm *tm = wxLocaltime_r(&timet, &tmstruct);
./src/common/datetime.cpp:517:1: warning: control reaches end of non-void function [-Wreturn-type]
Makefile:29217: die Regel für Ziel „baselib_datetime.o“ scheiterte
make: *** [baselib_datetime.o] Fehler 1
build wxWidgets-3.0.1 failed...
Alles anzeigen
Ich habe gerade alles neu gebaut -> Versionsnummer steht drin. Habe Win 8.1 64Bit.
Hallo jb_alvarado,
finde Dein Projekt super!
Wäre es möglich libdvdcss in der "non-free" Option wieder einzubauen? Die damit erstellten Builds sind nur für den privaten Gebrauch gedacht und verstoßen damit nicht gegen das Urheberrecht hier.
Ok, alles klar. Werde mich mal damit befassen.
Danke euch!!
Hab's hier nochmal hochgeladen:
http://ul.to/a0syafei
Ich dachte die Bewegung der linken Frau wäre ausreichend, während Sie auf die rechte Frau zugeht.
Ich hatte die einzelnen Folgen der Serie extrahiert, da ich die einzeln verarbeiten wollte. Es soll auch AviSynth Probleme geben, wenn mehrere Titel in einer PGS existieren.
SRestore!? Wie sollte der Script aussehen?
Danke für Deine Hilfe!
ich wollte folgendes Video deinterlacen:
http://netload.in/dateiXHwYPOwfza/1Test_interlaced.mkv.htm
Leider bekomme ich nicht raus, welche AviSynth Filter ich nehmen soll, damit es richtig funktioniert.
Es wäre super, wenn mir jemand mit einem Script helfen könnte.
Ich hole mir die neueren Builds (Windows) in letzter Zeit hier:
http://www.paehl.com/open_source/?C…PLAYER_MENCODER
Hatte damit bisher keine Probleme mit Hybrid.
Ich würde auch empfehlen auf die neue Version (1677) zu wechseln, da die 1666 fehlerhaft ist:
Bug: 8x8dct + CAVLC + deblock + slices + no sliced threads resulted in slightly incorrect deblock strength calculations.
Bug type: Decoder Desync
Introduced in: r1612
Fixed in: r1669
Bug: PCM blocks were encoded incorrectly. Broke lossless and/or insanely high bitrate encoding with subme >= 6.
Introduced in: r1666
Fixed in: r1675
Hi Selur,
hab' das gleiche Problem wie Fire. Könnte ich bitte auch die neue Version bekommen? Wenn man lange genug wartet, ist Hybrid wieder "ansprechbar", aber mit dem eingelesenen .264 Stream kann Hybrid nix anfangen. Es stehen im Infofenster auch keine Infos zu dem Stream.
Das hört sich nach schlaflosen Nächten an!:D
Könntest du bitte auch für HD-Encoding noch folgende Optionen einbauen:
--colorprim bt709
--transfer bt709
--colormatrix bt709
Evtl. als Default einstellbar für Auflösung >720?
Seit dem 19.03. keine neue Version rausgebracht?:D Sonst kam ich nichtmal mit dem Download hinterher.:ani_lol:
Im Ernst, muss viel an die neue x264 (1510) angepasst werden? Wollte die Tage mal ein paar Tests machen...
mister_no
Hab' noch das Problem, dass im Endfile kein Audio dabei ist, wenn ich AC3->AAC encode (source DVD). Audio ist enthalten, wenn ich das Original-AC3 übernehme.
Ach, ok! War nur verwirrt, da im ToolTip das mit "keep Queue stopped" so beschrieben war.
bin wieder da... und zurück zu den Problemen von gestern und heute:
1. Keine Fortschrittsanzeige unter Main (wolltest die evtl. rausnehmen...)
2. Unter 'Audio' wird neben der 'Audio track number' ein '?' und nicht die Sprache ('en'/'de') angezeigt. Das passiert bei allen DVD's, die ich hier habe.
3. Unter 'Main' wird nur der Button 'Add to queue' angezeigt. Ich vermisse den Button 'Start'. Hierzu müsste man die Option 'Keep queue stopped' rausnehmen. Finde aber nicht die Option. Wo ist die versteckt?
4. Fortschrittsanzeige unter "Jobs": Hier wird bei mir immer gerechnet: Gesamtframes / Encodingframes/s = Restzeit! Es wird der aktuelle Fortschritt nicht berücksichtigt.
Ich benutze DVD's als Source.
Brauchst Du noch Infos?
Wirst Du eine Option einbauen, dass man beim downmix den Subkanal ein- oder ausschliessen kann?
