Problem behoben.
Ich habe die DVD mit DVD shrink re-authored und dann nochmal mit agk versucht und es ging, scheint also ein dvd struktur problem gewesen zu sein.
[19.12.2007 12:54:18] AutoGK 2.48b
[19.12.2007 12:54:18] OS:
[19.12.2007 12:54:18] Job started.
[19.12.2007 12:54:18] Input file: F:\VIDEO_TS\VTS_01_0.IFO
[19.12.2007 12:54:18] Output file: G:\Movies\XXXXX.avi
[19.12.2007 12:54:18] Output codec: XviD
[19.12.2007 12:54:18] Audio 1: Deutsch AC3 6ch
[19.12.2007 12:54:18] Subtitles: none
[19.12.2007 12:54:18] Format: AVI
[19.12.2007 12:54:18] Target size: 2040Mb
[19.12.2007 12:54:18] Audio 1 settings: VBR MP3 with average bitrate: 192Kbps
[19.12.2007 12:54:18] Started encoding.
[19.12.2007 12:54:18] Demuxing and indexing.
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_1.VOB
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_2.VOB
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_3.VOB
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_4.VOB
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_5.VOB
[19.12.2007 12:55:35] Processing file: F:\VIDEO_TS\VTS_01_6.VOB
[19.12.2007 12:55:35] Source resolution: 720x576
[19.12.2007 12:55:35] Found PAL source.
[19.12.2007 12:55:35] Source aspect ratio: 16:9
[19.12.2007 12:55:35] Analyzing source.
[19.12.2007 12:57:43] Source is considered to be progressive.
[19.12.2007 12:57:43] Output will contain 198532 frames
[19.12.2007 12:57:43] Decoding audio.
[19.12.2007 12:59:33] Normalizing audio.
[19.12.2007 12:59:52] Encoding audio.
[19.12.2007 13:06:48] Audio1 size: 178,530,624 bytes (170.26 Mb)
[19.12.2007 13:06:48] Overhead: 7,941,248 bytes (7.57 Mb)
[19.12.2007 13:06:48] Video size: 1,952,623,168 bytes (1862.17 Mb)
[19.12.2007 13:06:48] Running compressibility test.
[19.12.2007 13:08:25] Duration was: 1 minute, 37 seconds
[19.12.2007 13:08:25] Speed was: 101,94 fps.
[19.12.2007 13:08:26] Compressibility percentage is: 138,76
[19.12.2007 13:08:26] Switching b-frames off
[19.12.2007 13:08:26] Chosen resolution is: 720x320 ( AR: 2,25 )
[19.12.2007 13:08:26] Predicted comptest value is: 96,41%
[19.12.2007 13:08:26] Running first pass.
[19.12.2007 13:29:58] Duration was: 21 minutes 32 seconds
[19.12.2007 13:29:58] Speed was: 153,60 fps.
[19.12.2007 13:29:58] Expected quality of first pass size: 96,01%
[19.12.2007 13:29:58] Running second pass.
[19.12.2007 13:59:10] Duration was: 29 minutes 11 seconds
[19.12.2007 13:59:10] Speed was: 113,38 fps.
[19.12.2007 13:59:10] Job finished. Total time: 1 hour, 4 minutes 51 seconds
