Hier die Daten aus GSpot
FILE_NAME ***.mpg
FILE_NAME_WITH_PATH C:\***\***.mpg
FILE_SIZE 1,686,333,440
CONT_AUDIO_STREAM_COUNT 1
CONT_BASETYPE MPEG (.MPG/.MPEG/.VOB)
CONT_BYTES_MISSING
CONT_INTERLEAVE_ALIGN
CONT_INTERLEAVE_PRELOAD
CONT_INTERLEAVE_TIME
CONT_SUBTYPE
CONT_TOTAL_BITRATE 10080
VIDEO_ASPECT_CONVERT_AVI1 Resize to 787 x 576 (Use +/- for other target sizes)
VIDEO_ASPECT_CONVERT_AVI2 Crop off any non-picture areas, if req'd
VIDEO_ASPECT_CONVERT_CVD1 Resize to 360 x 576 ( w:[1/2] h:[1/1] )
VIDEO_ASPECT_CONVERT_CVD2 Trim 4 from each side for 352 x 576
VIDEO_ASPECT_CONVERT_DVD1 No resize req'd
VIDEO_ASPECT_CONVERT_DVD2 No cropping req'd
VIDEO_ASPECT_CONVERT_SVCD1 Resize to 480 x 576 ( w:[2/3] h:[1/1] )
VIDEO_ASPECT_CONVERT_SVCD2 No cropping req'd
VIDEO_ASPECT_CONVERT_VCD1 Resize to 360 x 288 ( w:[1/2] h:[1/2] )
VIDEO_ASPECT_CONVERT_VCD2 Trim 4 from each side for 352 x 288
VIDEO_ASPECT_SOURCE_MATCH DVD
VIDEO_ASPECT_TYPE_NTSC
VIDEO_ASPECT_TYPE_PAL PAL
VIDEO_BITRATE 2380
VIDEO_CODEC_NAME MPEG-2
VIDEO_CODEC_STATUS Codec(s) are Installed
VIDEO_CODEC_TYPE MPEG2
VIDEO_DAR 1.778
VIDEO_DURATION 1:25:50
VIDEO_FIELDS_PER_SEC 50.000
VIDEO_FRAME_COUNT 128742
VIDEO_FRAMES_PER_SEC 25.000
VIDEO_H264
VIDEO_MPEG2 MPEG-2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L I/L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR 1.422
VIDEO_PICS_PER_SEC 25.000
VIDEO_QF 0.230
VIDEO_SAR 1.250
VIDEO_SIZE_X 720
VIDEO_SIZE_Y 576
AUDIO_BITRATE 192
AUDIO_BITRATE_TYPE CBR
AUDIO_CHANNEL_COUNT 2
AUDIO_CODEC MPEG-1 Layer 2
AUDIO_CODEC_STATUS Codec(s) are Installed
AUDIO_MPEG_STREAM_ID 0xc0
AUDIO_MPEG_SUBSTREAM_ID
AUDIO_SAMPLE_RATE 48000
Zum Vergleich die Daten bei einem Film ohne Probleme, wobei mir aber nichts auffällt:
FILE_NAME ***.mpg
FILE_SIZE 1,985,173,504
CONT_BYTES_MISSING
CONT_SUBTYPE
VIDEO_BITRATE 2242
VIDEO_DAR 1.778
VIDEO_DURATION 1:46:46
VIDEO_FRAME_COUNT 160134
VIDEO_H264
VIDEO_MPEG2 MPEG-2
VIDEO_MPEG2_3X2
VIDEO_MPEG2_BFF
VIDEO_MPEG2_I_L I/L
VIDEO_MPEG2_PPF
VIDEO_MPEG2_PROG
VIDEO_MPEG2_TFF TFF
VIDEO_MPEG4
VIDEO_MPEG4_BVOP
VIDEO_MPEG4_GMC
VIDEO_MPEG4_NVOP
VIDEO_MPEG4_QPEL
VIDEO_PAR 1.422
VIDEO_QF 0.216
VIDEO_SAR 1.250
VIDEO_SIZE_X 720
VIDEO_SIZE_Y 576
AUDIO_BITRATE 192
Ich hoffe dies hilft weiter bei der Analyse des Problems. Wie gesagt habe ich das Problem nur bei RTL-Sendungen, sonst hat mein DVD-Player bzw. mein Receiver kein Problem mit den Daten. Sendet RTL ihren DVB-T Stream anders als andere???
Aber schon mal Danke für die Mühen!
Mark78
