Juhu!!! Es hat geklappt! [Blockierte Grafik: http://www.en.kolobok.us/smiles/standart/yahoo.gif]
C:\test\mplayer29851>mplayer -dumpstream -playlist http://wstreaming.zdf.de/zdf/veryhigh/091109_1350_hko.asx[COLOR='SeaGreen']Resolving wstreaming.zdf.de for AF_INET6...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[/COLOR][COLOR='Red']connection timeout[/COLOR][COLOR='SeaGreen']Resolving wstreaming.zdf.de for AF_INET...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[/COLOR]STREAM_ASF, URL: http://wstreaming.zdf.de/zdf/veryhigh/091109_1350_hko.asx[COLOR='SeaGreen']Resolving wstreaming.zdf.de for AF_INET6...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[/COLOR][COLOR='Red']connection timeout[/COLOR][COLOR='SeaGreen']Resolving wstreaming.zdf.de for AF_INET...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[/COLOR][COLOR='Red']size_confirm mismatch!: 22611 28271Error while parsing chunk headerFailed, exiting.[/COLOR]Resolving wstreaming.zdf.de for AF_INET6...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[COLOR='Red']connection timeout[/COLOR][COLOR='SeaGreen']Resolving wstreaming.zdf.de for AF_INET...Connecting to server wstreaming.zdf.de[91.197.28.140]: 80...[/COLOR]Cache size set to 320 KBytesMPlayer Sherpya-SVN-r29851-4.2.5 (C) 2000-2009 MPlayer TeamPlaying mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/11/091109_1350_hko_vh.wmv.STREAM_ASF, URL: mms://ondemand.msmedia.zdf.newmedia.nacamar.net/zdf/data/msmedia/zdf/09/11/091109_1350_hko_vh.wmv[COLOR='SeaGreen']Resolving ondemand.msmedia.zdf.newmedia.nacamar.net for AF_INET6...Connecting to server ondemand.msmedia.zdf.newmedia.nacamar.net[62.27.26.34]: 1755...[/COLOR][COLOR='Red']connection timeout[/COLOR][COLOR='SeaGreen']Resolving ondemand.msmedia.zdf.newmedia.nacamar.net for AF_INET...Connecting to server ondemand.msmedia.zdf.newmedia.nacamar.net[62.27.26.34]: 1755...[/COLOR]Connectedfile object, packet length = 8948 (8948)[COLOR='DimGray']unknown objectunknown object[/COLOR]stream object, stream ID: 1stream object, stream ID: 2[COLOR='DimGray']unknown objectunknown objectunknown object[/COLOR]data objectmmst packet_length = 8948Cache size set to 320 KBytesStream not seekable!Everything done. Thank you for downloading a media file containing proprietary and patented technology.Core dumped ;)Exiting... (End of file)
Das Video kann ich jetzt nach dem Umbenennen mit WMP oder meinem Lieblingsplayer KMPlayer abspielen. Selbst beim Vorspulen gibt es keine Blockbildung:
C:\test\mplayer29851\stream.dump heute 100sec.wmv
General
Complete name : C:\test\mplayer29851\stream.dump heute 100sec.wmv
Format : Windows Media
File size : 20.8 MiB
Duration : 1mn 52s
Overall bit rate mode : Constant
Overall bit rate : 1 546 Kbps
Maximum Overall bit rate : 1 606 Kbps
Performer : ZDF
Encoded date : UTC 2009-11-09 12:45:59.796
Copyright : (c) 2009 ZDF
Video #2
Format : VC-1
Format profile : MP
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9
Duration : 1mn 52s
Bit rate mode : Constant
Bit rate : 1 400 Kbps
Width : 688 pixels
Height : 384 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.212
Stream size : 18.8 MiB (91%)
Language : German
Audio #1
Format : WMA2
Codec ID : 161
Codec ID/Info : Windows Media Audio 2
Description of the codec : Windows Media Audio 9 - 192 kbps, 44 kHz, stereo 1-pass CBR
Duration : 1mn 52s
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 2.58 MiB (12%)
Language : German
Alles anzeigen
Sollte ich mal mit dieser Methode nicht weiterkommen, werde ich die zuletzt erwähnten Programme von Goldwingfahrer ausprobieren. Aber so gehts am einfachsten, trotz der Fehlermeldungen klappt alles. Ich habe jetzt den eigentlichen Film gestartet, das dauert jetzt.
Ich danke euch für die Mühe, die ihr auf euch genommen habt um mir zu helfen.
[Blockierte Grafik: http://www.en.kolobok.us/smiles/standart/drinks.gif]
