--tune animation passt mehr als einen Parameter an.
Schon klar, ich verstehe nur nicht die Regel, nach der das Level "geschätzt" wird. Nochmal zum Verständnis:
Zeichentrickfilm, --tune animation, -ref 4:
Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L4.0Format settings, CABAC : YesFormat settings, ReFrames : 4 framesDuration : 1h 15mnBit rate : 7 186 KbpsWidth : 1 920 pixelsHeight : 1 040 pixelsDisplay aspect ratio : 1.85:1Frame rate : 23.976 fpsColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveBits/(Pixel*Frame) : 0.150Writing library : x264 core 129 r2230 1cffe9fEncoding settings : cabac=1 / ref=4 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=48 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Zeichentrickfilm, --tune animation, -ref 5:
Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L5.0Format settings, CABAC : YesFormat settings, ReFrames : 5 framesDuration : 1h 15mnBit rate : 7 158 KbpsWidth : 1 920 pixelsHeight : 1 040 pixelsDisplay aspect ratio : 1.85:1Frame rate : 23.976 fpsColor space : YUVChroma subsampling : 4:2:0Bit depth : 8 bitsScan type : ProgressiveBits/(Pixel*Frame) : 0.150Writing library : x264 core 129 r2230 1cffe9fEncoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.40:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=48 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Es ist alles gleich bis auf die Anzahl der ReFrames. Der Unterschied bei der Bitrate ist vernachlässigbar. Daraus ziehe ich den Schluss, dass im Falle von "--tune animation" 4 ReFrames Level 4 bedeutet und 5 oder mehr ReFrames Level 5.
Realfilm, --tune film, -ref 5:
Format : AVC
Duration : 2h 10mn
Bit rate : 5 459 Kbps
Height : 800 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.148
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=48 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Alles anzeigen
Es unterscheiden sich aufgrund des Tunings diverse Parameter von dem Zeichentrickfilm, außerdem haben wir eine andere Auflösung und Bitrate. Dennoch ist es "High@L4.0". Logisch gefolgert ergibt sich:
Wenn --tune animation gesetzt ist, erhalten wir beim selben Film Level 4 mit 4 ReFrames und Level 5 ab 5 ReFrames.
Wenn --tune film gesetzt ist, erhalten wir Level 4 auch bei 5 ReFrames, aber welche der anderen Parameter verursachen das und warum? Bitrate und Auflösung scheiden aus, denn sonst wäre der Zeichentrickfilm mit 4 ReFrames ebenfalls Level 5.
