ok
Ich hab dir mal alles Kopiert was er mir nach dem crash sagt
Environment
StaxRip version: 1.1.9.0
OS Name : Windows 7 Ultimate
OS Version : 6.1.7601.65536
OS Type : 64-bit
OS Culture : German (Germany)
.NET
v2.0.50727 : 2.0.50727.5420
v2.0.50727\1031 : 2.0.50727.5420
v2.0.50727\1035 : 2.0.50727.5420
v2.0.50727\1036 : 2.0.50727.5420
v2.0.50727\1040 : 2.0.50727.5420
v2.0.50727\1046 : 2.0.50727.5420
v2.0.50727\1053 : 2.0.50727.5420
v2.0.50727\3082 : 2.0.50727.5420
v3.0 : 3.0.30729.5420
v3.5 : 3.5.30729.5420
v3.5\1031 : 3.5.30729.5420
v3.5\1035 : 3.5.30729.5420
v3.5\1036 : 3.5.30729.5420
v3.5\1040 : 3.5.30729.5420
v3.5\1046 : 3.5.30729.5420
v3.5\1053 : 3.5.30729.5420
v3.5\3082 : 3.5.30729.5420
v4\Client : 4.5.52213
v4\Client\1031 : 4.5.52213
v4\Full : 4.5.52213
v4\Full\1031 : 4.5.52213
v4.0\Client : 4.0.0.0
Source file MediaInfo
C:\Users\haLLer\Desktop\Ohne Titel.avi
General
Complete name : C:\Users\haLLer\Desktop\Ohne Titel.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 6.25 MiB
Duration : 37s 0ms
Overall bit rate : 1 418 Kbps
Video
Format : VFW
Codec ID : DFSC
Codec ID/Info : DebugMode FrameServer VFW
Duration : 36s 995ms
Bit rate : 1 534 bps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.000
Stream size : 6.93 KiB (0%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 37s 0ms
Bit rate mode : Constant
Bit rate : 1 411.2 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Bit depth : 16 bits
Stream size : 6.22 MiB (100%)
Alignment : Aligned on interleaves
Interleave, duration : 1000 ms (23.97 video frames)
Interleave, preload duration : 37000 ms
Demux AVI using VirtualDubMod
Demuxer: Demux AVI
"C:\Users\haLLer\Desktop\StaxRip_1.1.9.0\Applications\VirtualDubMod\VirtualDubMod.exe" /s"C:\Users\haLLer\Desktop\Ohne Titel temp files\Ohne Titel_Demux.vcf" /x
Source Macros
Source Directory: C:\Users\haLLer\Desktop\
Source Directory Name: Desktop
Source Directory Parent: C:\Users\haLLer\
Source File Path: C:\Users\haLLer\Desktop\Ohne Titel.avi
Source Files Blank: "C:\Users\haLLer\Desktop\Ohne Titel.avi"
Source Files Comma: "C:\Users\haLLer\Desktop\Ohne Titel.avi"
Source Framerate: 23.98
Source Framerate MediaInfo: 23.976
Source Frames: 887
Source Image Height: 720
Source File Name: Ohne Titel
Source Seconds: 37
Source Image Width: 1280
AviSynth script failed to load
AVISource("C:\Users\haLLer\Desktop\Ohne Titel.avi", audio=false)
Crop(0,0, -Width % 8,-Height % 8)
ConvertToYV12()
Spline64Resize(3840,2160)
YV12 decompressor: Helix YV12 YUV Codec
AviSynth Plugins: DirectShowSource, TCPDeliver
Exception
System.Exception: Failed to decode YV12.
bei StaxRip.AVIFile.Open(String path) in D:\Projekte\StaxMedia\StaxRip\General\AVIFile.vb:Zeile 185.
bei StaxRip.AviSynthDocument.Synchronize() in D:\Projekte\StaxMedia\StaxRip\General\AviSynth.vb:Zeile 138.
bei StaxRip.AviSynthDocument.GetFramerate() in D:\Projekte\StaxMedia\StaxRip\General\AviSynth.vb:Zeile 187.
bei StaxRip.AviSynthDocument.GetSeconds() in D:\Projekte\StaxMedia\StaxRip\General\AviSynth.vb:Zeile 202.
bei StaxRip.MainForm.AviSynthListView_ScriptChanged() in D:\Projekte\StaxMedia\StaxRip\Forms\MainForm.vb:Zeile 5064.
bei StaxRip.AviSynthListView._Lambda$__12() in D:\Projekte\StaxMedia\StaxRip\Controls\AviSynthListView.vb:Zeile 319.
Alles anzeigen
Bei der VFW Konfig hab ich jetzt nur unter dem reiter Codecs -> unkompremiertes Video als option alle formate ausgewählt...das war zb vorher deaktiviert... hat aber leider nicht geholfen
