Jo so sieht at aus! Es ist die 64Bit von Stax!
Habe dir mal ne PN geschickt!
Die technische Realität sieht nun mal anders aus!
_________ __ __________.__
/ _____// |______ ___ __\______ \__|_____
\_____ \\ __\__ \ \ \/ /| _/ \____ \
/ \| | / __ \_> < | | \ | |_> >
/_______ /|__| (____ /__/\_ \|____|_ /__| __/
\/ \/ \/ \/ |__|
Environment
StaxRip x64 : 1.3.3.9
OS : Windows 10 Enterprise
Language : German (Germany)
CPU : Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
GPU : Intel(R) HD Graphics 530
Source file MediaInfo
D:\Film\25fps.m2ts
General
Complete name : D:\Film\25fps.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 30.2 GiB
Duration : 2h 12mn
Overall bit rate mode : Variable
Overall bit rate : 32.6 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=1, N=12
Codec ID : 27
Duration : 2h 12mn
Bit rate mode : Variable
Bit rate : 31.3 Mbps
Maximum bit rate : 34.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.604
Stream size : 29.0 GiB (96%)
Process M2TS file using eac3to
"C:\Stax\Apps\eac3to\eac3to.exe" "D:\Film\25fps.m2ts" -progressnumbers
M2TS, 1 video track, 2:12:27, 25p
1: h264/AVC, 1080p25 (16:9)
Demux M2TS using eac3to 3.31 x86
C:\Stax\Apps\eac3to\eac3to.exe "D:\Film\25fps.m2ts" -progressnumbers
Start: 13:56:59
End: 13:57:00
Duration: 00:00:00
Script
LoadPlugin("C:\Stax\Apps\Plugins\avs\L-SMASH-Works\LSMASHSource.dll")
LWLibavVideoSource("D:\Film\25fps.m2ts", format = "YUV420P8")
Import("C:\25to50\25to50.avs")
Script Properties
source frame count : 198682
source frame rate : 25.000000
source duration : 02:12:27.2800000
target frame count : 397363
target frame rate : 50.000000
target duration : 02:12:27.2600000
Encoding using QSVEncC 2.44v2 x64
C:\Stax\Apps\QSVEncC\QSVEncC64.exe --codec hevc --quality best --level 4.1 --fallback-rc --fullrange --colormatrix bt709 --colorprim bt709 --transfer bt709 --vbr 20000 -i D:\Film\25fps_temp\25fps.avs -o D:\Film\25fps.hevc
B pyramid is not supported on current platform, disabled.
cop.AUDelimiter value changed off -> auto
cop3.DirectBiasAdjustment value changed off -> auto
cop3.GlobalMotionBiasAdjustment value changed off -> auto
QSVEncC (x64) 2.44 (r1011) by rigaya, Apr 3 2016 19:24:39 (VC 1900/Win/avx2)
OS Windows 10 (x64)
CPU Info Intel Core i5-6600K @ 3.50GHz [TB: 4.20GHz] (4C/4T) <Skylake>
GPU Info Intel HD Graphics 530 (24EU) 350-1300MHz [95W] (20.19.15.4424)
Media SDK QuickSyncVideo (hardware encoder) PG, 1st GPU, API v1.17
Async Depth 4 frames
Buffer Memory d3d9, 3 input buffer, 13 work buffer
Input Info Avisynth 2.60 (yv12)->nv12[AVX2], 1920x1080, 50/1 fps
Output HEVC main @ Level 4.1
1920x1080p 1:1 50.000fps (50/1fps)
Target usage 1 - best
Encode Mode Bitrate Mode - VBR
Bitrate 20000 kbps
Max Bitrate 20000 kbps
QP Limit min: none, max: none
Trellis Auto
Ref frames 4 frames
Bframes 3 frames, B-pyramid: off
Max GOP Length 500 frames
Scene Change off
Ext. Features PerMBRC
encoded 397363 frames, 46.68 fps, 19759.68 kbps, 18720.06 MB
encode time 2:21:52, CPULoad: 23.76
frame type IDR 1
frame type I 795, total size 173.56 MB
frame type B 396568, total size 18546.50 MB
Start: 14:00:06
End: 16:22:02
Duration: 02:21:56
Display More
StaxRip x64 funktioniert ... warum läuft es jetzt mit der beschriebenen Vorgehensweise?
Habe die"mvtools2.dll" in ein anderen Ordner und AvisynthMT zusätzlich installiert, ein AVS-Script (Textdatei) erstellt
...es läuft!
[FONT=&]Habe nun nochmals probiert manuell in Stax 1.3.9.9 einzubinden und es funktioniert.
Dazu parallel AvisynthMT installiert und das obige Script in Stax eingebaut.
MVTools als AVS-Script in einen anderen Ordner verlegt.
[/FONT] Das Ganze sieht nicht schlecht aus aber Feinjustierung ist noch nötig!
[FONT=&]Zwei Trailer mit Action Szenen als 25FPS und 50FPS bei Bedarf schicke ich es per PN![/FONT]
Habe mal mit Stax 1.2.2.0 das AVS-Script Manuell eingepflegt.
Hier mal zwei Datein:
Einmal Original und 50FPS
LoadPlugin("C:\25to50\mvtools2.dll")super=MSuper(pel=1, hpad=0, vpad=0)backward_1=MAnalyse(super, chroma=false, isb=true, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))forward_1=MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, blksizev=8, searchparam=0, search=3)forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, blksizev=8, searchparam=0, search=3)MBlockFps(super, backward_2, forward_2, num=FramerateNumerator(last)*2, den=FramerateDenominator(last)*1, mode=0)#GetMTMode(false) > 0 ? distributor() : lastSharpen(0.18)
1.Avisynth+ finde ich nicht als erste Wahl, eine Aufwertung zu Version 2.5.8 sprich MT 2.6 wäre besser.
In der alten Stax-Version hat es wunderbar geklappt.
2.Habe es vor einiger Zeit getestet und war begeistert vom Ergebnis.
Kamera-Schwenks waren flüssig und weich.
MadVR z.b. bietet es über die SmoothMotion-Funktion auch an allerdings im Ergebnis nicht so klasse wie MT.
3.Seifenoper auf keinen Fall, ich beschleunige von 23.976FPS auf 25FPS und dann interpoliere ich von 25 auf 50FPS.
[FONT=&]Dass das Material etwas großer ausfällt ist ja klar, wenn man mit AVC arbeitet.
Mit HEVC seht die Sache wieder völlig anders aus. Wie könnten wir es nun in Stax mit einbauen oder will man nicht? Bzw. wie könnte ich es in Stax einbauen?[/FONT]
QuoteIn AviSynth+ gibt es soviel ich weiß keine SetMTMode Funktion.
AviSynthMT 2.6 gibt es diese...ich habe davon eine 32bit Version
[Blocked Image: http://abload.de/img/1atjr2.png]
Wie müsste es stattdessen nun ausehen, damit ich von 25FPS auf 50FPS komme ohne
zu beschleunigen...sprich Interpolieren?
Kann man so eine Funktion übergaupt einbauen?
In der alten StaxVersion (32bit) hat es funktioniert!
So funktioniert es mit FFDShow:AVS-Sript
DirectShowSource("d:\test1.m2ts",framecount=549,audio=false)
SetMemoryMax(1280)
SetMTMode(5,4)
SetMTMode(2)
SetMTMode(1)
Sharpen(0.18)
#AssumeFPS(25)
#ChangeFPS(25)
#ConvertFPS(50)
#trim(106,31200)
#ConvertToYUY2()
Display More
Hallo!
[FONT="]Versuche wie ein Blöder Frame-Interpolation in Stax einzubauen, es gelingt mir aber nicht.
In der aktuellen Testversion ist unter AviSynth-Plugin MVTools vorhanden.
Möchte von 25FPS zu 50FPS aufwerten ohne Bild und Ton zu beschleunigen.
Das Script (Manuell)
[/FONT][FONT="]LoadPlugin("C:\Stax\Apps\Plugins\avs\mvtools2.dll")SetMTMode(2)super=MSuper(pel=1, hpad=0, vpad=0)backward_1=MAnalyse(super, chroma=false, isb=true, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))forward_1=MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, blksizev=8, searchparam=0, search=3)forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, blksizev=8, searchparam=0, search=3)MBlockFps(super, backward_2, forward_2, num=FramerateNumerator(last)*2, den=FramerateDenominator(last)*1, mode=0)SetMTMode(1)GetMTMode(false) > 0 ? distributor() : lastSharpen(0.18)
Profil
[/FONT][FONT="][Source]Automatic =MPEG2Source = SetMTmode(5,4) MPEG2Source("%source_file%")MPEG2SourceMT = SetMTmode(5,6) MPEG2Source("%source_file%")AVISource = AVISource(%source_files_comma%, audio=false)%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()AVISourceMT = SetMTmode(5,6) SetMemoryMax(512) AVISource(%source_files_comma%, audio=false)%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()DirectShowSource = DirectShowSource("%source_file%", audio=false, convertfps=true, fps=%source_framerate_mediainfo%)%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()AVCSource = AVCSource("%source_file%")%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()FFVideoSource = FFVideoSource("%source_file%",threads=1, cachefile="%working_dir%%source_name%.ffindex")%newline%AssumeFPS(%source_framerate_mediainfo%)%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()FFVideoSourceMT = SetMTmode(5,6) SetMemoryMax(512) FFVideoSource("%source_file%",threads=1, cachefile="%working_dir%%source_name%.ffindex")%newline%AssumeFPS(%source_framerate_mediainfo%)%newline%Crop(0,0, -Width % 8,-Height % 8)%newline%ConvertToYV12()DGSource = DGSource("%source_file%",deinterlace=0,resize_w=0,resize_h=0)Advanced | MPEG2Source Deblocked = MPEG2Source("%source_file%", CPU=6)Advanced | DGSource 720p = DGSource("%source_file%",deinterlace=0,resize_w=1280,resize_h=720)Advanced | DGSource 1024x576 = DGSource("%source_file%",deinterlace=0,resize_w=1024,resize_h=576)
Script
[/FONT][FONT="][FrameKonv.]
50p zu 25p = selecteven()
25p zu 50pv = Import("[/FONT][FONT="][FONT="]C:\Stax\Apps\Plugins\avs\mvtools2.dll[/FONT]")
Irgendwie klappt es nicht....:(
[/FONT]
