@eDealer
ist der Absturz reproduzierbar bzw. gibt es eine Fehlermeldung?
@BaronVlad
benutzt du noch keine .NET Programme, werden doch immer mehr. Ich hab hier bestimmt schon 20 Programme, Tendenz steigend!
Beiträge von Dolemite
[font=verdana,arial,helvetica] [/font]http://www.planetdvb.net/dvx/fd/[font=verdana, arial, helvetica]Ich hoffe die neue Version macht keine Probleme, zu finden hier: [/font][font=verdana, arial, helvetica]http://www.planetdvb.net/dvx/fd/[/font]
4.02b
[font=verdana, arial, helvetica] the AviSynth filter definitions are now included to keep the AviSynth plugin dir clean, to not change anything outside the DVX dir, to have all things that are not third party to be included
changed the defaults for file associations mainly removed everything to not polute the system
updated program detection and recommendation to XviD 1.0.1 and BeSweet 1.5b28
added title option to mkvmerge
fixed bug with aspect ratio with mkvmerge
fixed bug with overhead with mkv and mp4
fixed a bug with named variables in the AviSynth source region
fixed bug where shutdown/standby didn't work
fixed bug where the processed jobs wasn't deleted from the joblist
job state (enabled/disabled) will no be saved
improved layout in the job window
improved enabled/disabled control states in the job dialog
added support for latest bsn in BeSweet GUI
the audio dialog has a new layout because the bsn GUI didn't fit in the old one
the AviSynth menu in the main dialog uses now different names as category name and as category region name because of problems with the translation. In the settings where the menu can be customized, the property grid used for this has now help text for all properties. The menu settings and the scripts of course had to be reseted.
improved assistent tips for mp4 and mkv
Polish translation updated by Pablak
I didn't announce the previous version here so here is the changelog for that:
4.0beta1
-----new features-----
GUI support for the new bsn switches, please suggest a default profile. The required libraries will be copied if possible
the colorspace for DVD2AVI can be specified
double click in the preview switches between fullscreen/normal view, the window can be moved with the left mouse as well
added the possibility to jump to the previous or next range start or end in the preview, Ctrl + Up/Down is range jump now and chapter jump is now Shift + Up/Down by default
the plugins settings display the plugin version and the description will now be displayed as well for plugins that are not loaded and it will be displayed if a plugin is loaded or not, old plugins will failed to load and have to be removed from the plugin dir if a error message pops up, recompiled plugins are included
new plugin called Windows Media Native, it creates native Windows Media WMV files, note: DVX can also create avi, mkv and ogm files with Windows Media 9 codec. The plugin requires Windows Media Encoder 9 to be installed. Cutting is not supported
the plugin editor uses now like the AviSynth editor the SharpDevelop text editor control so there is syntax highlighting
support for image based subtitles using vsrip and mkvmerge, support to set the aspect ratio flag with mkvmerge to avoid resizing, the order of the subtitles can be changed via context menu
added the possibility to encode with VirtualDub instead of VirtualDubMod, the DVX audio profiles are not compatible with VirtualDub but VirtualDub is very limited anyway. If mkvmerge is enabled the VirtualDub/Mod scripts audio processing/muxing scripts won't be processed. As usual the assistent should give a notice about incompatible settings
The AviSynth script editor has a new version of the text editor control with various changes like line numbers, selecting lines when the cursor is on the left side. It scrolls now with the mouse selection.
added additionally to shutdown a standby option
added advanced setting to restrain the standby or shutdown if a given program is running for instance a DVB application records a schedule
renamed BeSweet settings to "Command" and added the possibility to add multible lines which will then be processed as batch
added support for MP4 container using the 3ivx DirectShow filter
-----improved features-----
the paths to the programs can be changed even if the proper version is already selected
the advanced settings and advanced options have a translated and better interface
the assistent options have been moved from the advanced options to a own settings page
the demuxing settings for avi are separated from the demuxing settings for mpeg2
replaced the hybrid option with a fast deinterlace option in the main dialog
changing the size by selecting a compressibility percent value is now precise so the assistenr won't complain
opening a audio file with no audio settings won't calculate the size of the file any longer but there is a new profile for calculating the size only
the program verification before the encoding will only check programs that will be actually used in the process
-----fixed bugs-----
AviSynth profiles weren't saved
the preview/crop crashed on systems with 16 bit resolutions
radio check wasn't displayed for the codec menu items
DVX reseted decoder settings for XviD and DivX in previous versions because the codecs save the encoder and decoder settings in the same registry key and DVX saves and retrieves the entire registry key. Decoder settings will now be ignored for XviD and DivX
chapter data wasn't passed to VirtualDubMod for mkv files (it's recommend to use the mkvmerge plugin for mkv files)
warning about comma in filepath wasn't shown in all cases (not supported by the DVD2AVI CLI)
-----notes-----
internally wide parts were reimplemented to have a better foundation for future improvements, because of this program and project settings saved with prior versions can't be reused[/font] -
[font=verdana, arial, helvetica]Hallo zusammen,
von DVX gibt's mal wieder eine neue Version. Bei der Gelegenheit möcht ich auch gleich fragen ob jemand Lust hat bei der Hilfe zu helfen insbesondere bei der [/font][font=verdana, arial, helvetica]deutschen [/font][font=verdana, arial, helvetica]Übersetzung
3.56b
the AviSynth menu in the main dialog modifies only special regions in the AviSynth script. A region looks like this:
#Resize
code here generated by the menu
#End Resize
the benefit is the script can be modified manually and after that still be changed with the menu without loosing the manuall changes if they are outside of the menu regions. The other benefit is the filter order can be changed by moving the regions. Like in previous versions menu items can be changed with Ctrl+Leftclick, additionally it's now possible to edit the menu in the settings dialog including moving and renaming categories
protection about subtitle mixer preventing DVX to open files
-----fixed bugs------
[/font][font=verdana, arial, helvetica] subtitle language tags were broke because recent changes in VirtualDubMod[/font]
bitrate for VP 6
-----reseted settings-----
AviSynth menu in main dialog, AviSynth scripts in profiles/projects, codec settings
http://www.planetdvb.net/dvx[/font] -
Zitat von Selur
das es sich um ein Mircosoft Produkt handelt (ich weiß dies ist eine philosophisches Problem).ist zwar von Microsoft entwickelt, C# und die CLI sind aber ECMA standardisiert (was nicht ausschließt das Microsoft in ein paar Jahren Mono attackiert)
ich finds auch fragwürdig zu sagen ich nutze zwar Windows und Office welche mehrere hundert Euro kosten (egal ob bezahlt oder nicht) woduch Microsoft Produkte zum Standard geworden sind, aber .NET was immer umsonst sein wird beziehungweise Bestandteil von Windows wird möchte ich nicht haben. Man könnte ja auch komplett auf Linux umsteigen, ist halt doof das man da etwas mehr lernen muss, nicht die neuesten Spiele Spielen kann und keine komerziellen Produkte für lau nutzen kannZitat von Selur
Wie sieht's eigentlich mit den aktuellen Mono aus? Läuft DVX da drunter?
So würde zumindest der philosophische Aspekt gemindert.DVX verwendet sehr viele fortgeschrittene .NET Techniken wie compiler services, reflection, serialization, threading, interop services, design time features etc., bis das alles fehlerfrei implementiert ist kann noch etwas dauert. Mit den von DVX gesteuerten Programme sieht es nicht besser aus wenn man Mono unter Linux laufen hat was wohl der Normalfall ist, die lassen sich nur teilweise unter Wine betreiben, die ganzen Videosachen wie VFW und DirectShow gehen sowieso nicht sprich die wichtigsten Sachen. Ich fänds natürlich toll DVX unter Linux zu betreiben, da DVX jedoch mit rund zwanzig Programmen arbeitet ist das so gut wie nicht möglich.
Wie gesagt, ein .NET Programmierer versucht zuerst immer eine von der CLR verwaltete Lösung zu finden, je mehr Win32 Programme duch verwalteten Code ersetz werden können desto besser werden die Aussichten für eine Plattformunabhängigkeit -
Zitat von LigH
Bisher war ich ja auch eher gegen .NET - aber seit ich selber damit programmieren musste und nun relativ sicher weiß, was da so bei dessen Framework-Installation passiert, sehe ich als einzigen Kontrapunkt nur noch die Größe der Bibliotheken: Gegen die Installation von VB- und VC-Runtime-DLLs hat ja doch sonst auch niemand was, und wenn man nicht allzu sehr ins Detail geht, ist das .NET-Framework erst mal auch nicht viel mehr als eine Funktionssammlung, die von den Applikationen benutzt wird... Und wenn ich in Zukunft noch mal Arbeit kriegen will, dann werde ich mich auch mit dem SDK beschäftigen müssen (dann kann SharpDevelop höchst spannend werden).
für Modem Benutzer ist die Sache halt weniger toll, finde aber das es trotzdem ein Fortschritt ist im Vergleich zu VB6. Die meisten Autoren haben da die Laufzeit gleich in das Setup Paket miteingepackt, dazu noch paar Com Bibliotheken ohne die VB6 ja nicht funktioniert und schwups hat man schnucklige 3-5 MB beisammen wodurch die download Größe bis zu _fünfzig_ fach größer ist als mit .NET. Mit Delphi und C++ kommt man auch noch auf zweistellige Faktoren, besonders wenn man statisch verlinkt. Wenn man's richtig betrachtet müsten sich Modem Benützer eigentlich über die 20 MB freuen -
Zitat von scharfis_brain
akapuma, was machst DU, wenn Du deinen Encodeden Film zu einem Freund mitnimmst, und dieser keinen Player mit AR-Korrektur hat?
AUsserdem mache ich sehr gerne 1CD-Rips und bei denen ist eine sehr hohe Aufloesung oft toedlich...
704x288 sind aber sehr oft noch mit recht gutem ergebnis moeglich...
neben den technischen Problemen wie fehlende oder mangelde Unterstützung von Soft- und Hardware finde ich ist der Verzicht des resizen auch gegen die Idee von MPEG4, sprich Platz zu sparen -
ich will hier nicht wieder eine pro/kontra Diskussion von .net lostreten
sofern die Sache nicht Kindergarten Niveau hat hät ich kein Problem damit
aber könntest du das Programm nicht native kompilieren?
einen anständigen .NET Programmierer von der Idee zu überzeugen dürfte ein schwieriges Unterfangen werden. Eines der zehn .NET Gebote lautet unmanaged code nur wenn alles andere versagtZitat
Dieses .NET soll die Programmierung stark vereinfachen, so dass die letzte Antwort zutreffen wird
da bist du unbewußt ziemlich nah and der Problematik, die automatische Speicherwaltung welche die Programmierung vereinfacht ist eines der Hauptprobleme der nativen Kompilierung. Der Hauptgrund weshalb Microsoft derzeit keine native Codeausgabe unterstützt ist wohl das es einfach keinen Sinn macht die Vorteile von .NET nicht zu nutzen. Native Kompilierung gibt es derzeit nur als AOT Kompilierung was eher selten verwendet wird weil die JIT Kompilierung sehr schnell ist (vorausgesetzt der Programmierer weis was er tut). Technisch machbar ist für Microsoft so ziemlich alles, an den finanziellen Mitteln solls auch nicht liegen, die sind dickst dank der glücklichen MS Windows und MS Office Nutzer vorhanden. -
Hallo zusammmen,
über das Update Plugin steht eine neue Version zur Verfügung (Der Veröffentlichungszyklus wird voraussichtlich wieder auf ein bis zwei Wochen erhöht da keine großen Änderungen geplant sind)
3.51b
added option to create the target directory automatically
added option for applying changes at main dialog avs menu
either to the selected script or to both
added more values to the XviD B-Frames settings in
the common codec settings
improved dutch translation
improved assistent
improved the navigation for multible preview instances,
now not all instances get activated/focused all the time
not clicking the trackbar will affect all instances
now owner dialog of the preview is always the main dialog
now all locations from where the preview can be opened
will open multible instaces (changing settings won't
update the preview any longer)
fixed a bug were no image was displayed in the crop
dialog because of a threading problem
dialog because of a wrong filename
fixed starting of the decrypting automatically,
the option was inverted
fixed a bug were the credits script was corrupted
when opening a profiles while the credits script
is active -
Ob ich mich da wirklich einarbeiten sollte ?im Falle von DVX kann man kaum von Arbeit sprechen, ersten gibt es keinen Grund nicht die defaults zu nutzen und zweitens gibt es nur 6 Codec Einstellungen welche alle mit Tooltips erklärt sind, die restlichen Codec Einstellungen sind über die original Dialoge anpassbar welche nicht immer benutzerfreundlich sind, man kann hier unbesorgt die defaults verwenden
Schade, hatte gedacht Du hättest eventuell ne genauere Lösung.eine genaue Lösung ist wie gesagt kaum machbar weil es einfach zu viele Faktoren gibt. Da DVX im Moment das führende Program in dem Bereich ist stört es mich relativ wenig, wenn du mehr als plus minus ein MB hast dann poste einfach mal eine Logdatei
DVX eigent lich den Performance tip von DigitAl56K:nach meinen Test lohnt der slowest Mode und/oder 3 Durchgänge kaum und ist DivX XviD noch immer unterlegen. Solange keine Test auftauchen die das eindeutig wiederlegen wird sich in der Richtung nichts tun da die Geschichte relativ aufwendig währe und ich kein Bock darauf habe wenn es sowieso kaum was bringt und all davon abraten. Man kann für den ersten und zweiten Durchgang verschiedene Codec Einstellungen nutzen, drei verschiedene Codec Einstellungen lassen sich nicht nutzen!
Bringt das eigentlich was TV-Captures mit DivX zu encoden ? Das Material ist verauscht und interlaced. Kann man eine Qualität erwarten die auf dem TV ansehnlich ist ?vom erneuten Komprimieren wirds natürlich nicht besser, aber soviel schlechter wirds auch wieder nicht vorausgesetzt man bringt etwas Erfahrung bezüglich guter Einstellungen mit und es gibt auch saubere Quellen
Gruß Gunnar ... der noch nie DivX (zum Encoden) verwendet hat.halb so wild, wie schaut's mit XviD aus?
"Versionsgeschichte kann ich leider nur in englisch anbieten"
Schade, dabei wäre sie gerade in einem deutschen Board doch auf deutsch interessant.im Moment haben wir leider nur einen deutschen Übersetzter und der ist leider nicht besonders fleißig (die Rede ist hier von mir )
"credits for XviD will be encoded seperatly like DivX because XviD has problems here"
Das ist mir neu , bei mir hat das gerade gestern wieder wunderbar mit meiner neuen (nicht kopiergeschützten) Equilibrium DVD geklappt.im englischen Forum wird davon abgeraten, auch von XviD Entwickler, soviel ich weis kann es da zu Problemen mit der Dateigröße kommen
"improved the size selection in the calculator dialog, available are 650,700,800,650 x 2,700 x 2 and 800 x 2"
695 wäre eventuell noch hilfreich.wozu?
Haste eigentlich ne ordentliche Methode/Formel um den mkv und ogm Overhead genau zu berechenen ?kommt darauf was du als ordentlich betrachtest, im englischen Forum kannt du von Container Spezialisten wie Alex Noe lesen das eine exakte Berechnung größte Schwierigkeiten bereitet und selbst ein Matroska Entwickler zögert Wochen um ein Tool zur Berechnung bereitzustellen, was er bis heute glaub ich nicht geschafft hat. Ohne die Streams zu analysieren läuft so oder so schon garnichts. Meine Methode funktioniert so einfach wie genau für die üblichen Einstellungen. Spezielle Dinge wie Spuren ungleich Vorbis usw. wurden bisher noch nicht getestet, nutze ich selbst nicht und bin deshalb auf feedback in Form von Fehlerberichten angewiesen
das Video Overhead für MKV is in etwa 2 MB für 100 Minuten, Audio Overhead ist bei Vorbis kaum Vorhanden, das gleiche gilt für OGM nur ist da das Video Overhead deutlich höher
in DVX wie folgt umgesetzt
"added a DVD Decrypter section in the options"
Ob das okay geht mit gängigem Recht?würde mich auch mal interessieren, man kann DVX auf jeden Fall auch ohne DVD Decrypter downloaden und benutzen weils sich unabhängig vom SysPack alles auch manuell installieren läßt oder man kann im Update Plugin DVD Decrypter deaktivieren und somit den download verhindern, wie du dann deine DVD's rippst ist dann allerdings dein Problem, das dürfte ohne entsprechende Software problematisch werden
Zur Not könnte man diese Funktionen auch wieder entfernen, bin mir aber ziemlich sicher das dann sehr schnell ein Plugin auftauchen würde was genau dies wieder integrieren würdeZitat
"improved DivX codec defaults"
wie soll man den dies verstehen?die DVX codec defaults überschreiben lediglich das was in den original codec defaults ungünstig ist. Die kompletten codec Einstellungen hast du in DVX erst wenn du einmal den original Codec Dialog von DVX aus geöffnet hattest
in code form sehen die defaults wie folgt aus:
Dim divxCodec As Codec.VideoCodec = New Codec.VideoCodec("DivX", "Software\DivXNetworks\DivX4Windows", "divx", "0x78766964,0,10000,0", 9, 2, Root.CurrentUser)
divxCodec.SetStatic("Bidirectional Encoding", 1)
divxCodec.SetStatic("VBR Mode", CInt(DivXPasses.MultiFirst), List.First)
divxCodec.SetStatic("VBR Mode", CInt(DivXPasses.MultiNth), List.Second)
divxCodec.SetStatic("VBR Mode", CInt(DivXPasses.Quality), List.Credits Or List.CompTest)
divxCodec.SetStatic("use_mvfile", 1, List.First Or List.Second)
divxCodec.SetStatic("Max Keyframe Interval", 100)
divxCodec.SetStatic("Write log file", 1)
divxCodec.SetStatic("Disable feedback", 1)
divxCodec.SetStatic("Quality", 5)
divxCodec.SetStatic("Psychovisual Enhancement", 1)
divxCodec.SetStatic("5.0 Psychovisual Mode", 2)
divxCodec.SetStatic("VBR Quality v5", 250, List.Credits)
divxCodec.SetStatic("VBR Quality v5", 20, List.CompTest)
divxCodec.SetStatic("Disable Profile Page", 1, List.Credits Or List.CompTest)divxCodec.SetDynamic("Bitrate", "Return %video_bitrate% * 1000")
divxCodec.SetDynamic("Log File Name", "%source_dir%%target_name%_DivX.log")
divxCodec.SetDynamic("MV File Name", "%source_dir%%target_name%_DivXMV.bin")
divxCodec.SetDynamic("Nth Pass debug file name", "%source_dir%%target_name%_DivXNth.txt") -
Hallo zusammen,
nach einer längeren Pause ohne Updates haben wir heute eine neue DVX Version rausgebracht. Die meisten Neuerungen sind glaub ich im AviSynth Bereich deshalb poste ich einfach mal hier. Versionsgeschichte kann ich leider nur in englisch anbieten
3.5b
in the preview dialog, Ctrl + Up jumps to the
previous chapter, Ctrl + Down jumps to the next
chapter. To quickly search the credits start
press Ctrl + Right to jump to the end of the
movie and press Ctrl + Up to jump to the last
chapter where usually the credits start
replaced the tab controls in the settings and
options dialogs with a TreeView control
if DVX finds ac3 files it will preselect AC3
files instead of lst files
new dictionary based translation engine,
double entiries are not possible with
the new engine and missing and obsolete
entries are automatically detected by
parsing the DVX source code. Unicode support
for languages like arabic
translation editor simplified and added
some new features like search
improved english, german and french translation
improved tooltips
added toolbar button codec in main dialog
for opening the common codec settings
and drop down list for the individual
codec dialogs
fixed a bug in the bitrate recalculation after
the credits encoding. This bug was almost as old
as DVX, it produced undersize depending on the
size of the audio tracks, large audio tracks
produced large undersize
some calculations improved, the final size normally
shouldn't be more than +-1 MB out of size, my last
three encoding with different settings tested were
all between 0 - 0,7 oversize which is a acceptable
range. My tests included XviD and DivX from 0 to 1
B-Frame, avi, ogm, mkv, mp3 vbr, mp3 cbr and vorbis
at 90 kbit/s
fixed the proper display of the help which was
broke because of the preview dialog
the calculator will now be displayed at program
startup to avoid a bug I couldn't find
the log window will be displayed when the
joblist is used, I couldn't find a way to move
the program from the taskbar to the tray
using credits the parts will be encoded direct
in the proper container format instead of first
avi because recent VirtualDubMod versions
support appending ogm and mkv segments
using credits appending the parts and muxing
will be all together in one process
added colorspaces and return type of filters
to the AviSynth XML filter description editor
and added the possibility to move parameters
up and down and to edit items via context menu
updated AviSynth plugins and updated AviSynth
XML filter descriptions
moved the AviSynth filter/parameter dialog
and AviSynth profiles dialog to dockable tabed
windows.
Parameters are updated in the script automatically
when the menu is modified
Filters can be selected in a tree view control
and can be viewed by plugin, by category
and all via a context menu.
The description/help can be opened via mouse click
in the parameter menu.
added code completion in the AviSynth script
editor. The code completion appears by pressing
Ctrl + Space. It appears also typing a filter
followed by a dot added preview for the AviSynth
profiles
added images to the main menu items in the main
dialog and in the AviSynth script editor
updated to .NET 1.1 which is now required to run
DVX. It fixes some bugs and adds some new features.
Old profiles and settings can't be reused because
of the new .NET version
various performance tweaks (has nothing to do with
applications DVX controls), DVX is still far
from being optimized
added option to automate the comp test
and 800 x 2, the split and CD size options will
now be adjusted automatically
the automatic saving of the profile with the
start of an encode is now without _Encode suffix
for easier selection of the latest used profiles
if no source file is opened the open and save
dialogs will use the most frequently used
directory for opening and saving profiles
improved warn messages and error handling
simplified files options
removed the limitation in the AviSynth script
editor, it's now possible to use variables
in the first line and to use return
and added a option to demux all audio streams
and a option to specify the default target
directory
added Decrypt dialog with a option for demuxing,
it will preselect the drive with the most free
disk space or a user defined directory and
the name of the DVD as target directory and target
filename and will warn about low disk space
DVX enables the stream info and chapter info
options in DVD Decrypter before ripping
(did not work because of a bug)
improved helpfiles
added preview for the selected filter which will
preview the AviSynth script until the selected filter.
It supports multible instances of the preview and
the keys and buttons in the preview affects all
instances so images can be compared and examined easily
replaced DS.jar with X which is the successor of DS.jar
and improved support for ts files
many internals rewritten and many other small changes
and fixes
