Also ich persönlich fand Evil Dead 2 absolut Scheiße! Er hat wirklich nichts von der Finsternis und dem Splatter des ersten Teils! Wenn man ihn damals als 2ten Teil ersehnt hat, war es schon wirklich grauenhaft! Ist wie ein Disney-Aufguss der ersten Teils!
Armee der Finsternis ist da schon wieder was anderes, den fand ich auch gut!
Aber Geschmäcker sind eben verschieden!
Beiträge von Harry_P
Zitat von Harry_P
Hab das dazu im amerikanischen Pinnacle Board gefunden:
Data Execution Prevention Fix for Pinnacle InstantCopy
Description
No-execute and execute protection are all names for DEP. This process feature increasessecurity, but may cause problems with certain programs.
Directions
Several OSs have no-execute or execute protection. Microsoft has added this as well inSP2 with data execution prevention (DEP). This precents code execution in memory
regions already marked as storage. This is a powerful tool against buffer overrun
exploits.
If a program is failing and you want to disable DEP to see if that is the cause. Here
are the steps. (Just disable DEP for the program in question... don't disable it for
your whole system.)
1. Click Start
2. Select Control Panel
3. Select System
4. Click the Advanced tab
5. In the Performance region select Settings
6. Click the Data Execute tab in the dialog box that opens
7. Select Turn on DEP for all programs and services except for those I select
8. Click Add.
9. The open dialog box will open. Browse and select your application.
10. Click Open
11. Click Apply
12. Click Ok
13. RebootHere are the two application files for InstantCopy whick I found need to be fixed:
C:\Program Files\Pinnacle\InstantCDDVD\InstantCopy\ICopy.exe
C:\Program Files\Pinnacle\InstantCDDVD\InstantDrive\InstantDrive.exeAfter fixing the files you should reboot befor running InstantCopy.
Comment: It appears that Pinnacle will have to recompile these programs to clearly mark
the data and executable areas of memory. That would make this fix unnecessary.
Also das funzt leider nicht, jedenfalls bei mir! :redface:
Aber so:
einfach mit regedit hier:
HKEY_LOCAL_MACHINE\SOFTWARE\VOB\CDRAPP\Paths
skinfile in skinfile1 umbennenen!
Schön lauft es wieder! :ja: -
Description
Directions
exploits.
your whole system.)
1. Click Start
3. Select System
8. Click Add.
10. Click Open
11. Click Apply
12. Click Ok
Hab gestern bei Explosiv einen Bericht darüber gesehen. Dort wurde auch der Ersthelfer interviewt, ein älterer Herr der D.K. zuerst als junge Frau ansprach: "Junge Frau ist bei Ihnen alles okay?" Worauf D.K. wohl geantwortet hat: "Du Idiot ich bin doch der Kübel...." :ani_lol:
Ich hab jetzt noch Bauchschmerzen vom lachen! Das ist doch der Hammer!!! :ani_lol: -
Zitat von Iron
Harry_P schreibt mann könnte nur die ganze DVD reduzieren stimmt nicht das ging schon beim ersten teil man hakt einfach alles ab was man nicht haben will und es taucht auf der DVD auch nicht auf.
Sorry hatte vergessen das es mir nur um eine Komplettkopie geht! Und gerade da finde ich es sehr von Nachteil wie CloneDVD das wie beschrieben handhabt! :nein:
Zitat von Fr_An
Wenn die Alternative wirklich genial ist, dann kannst Du das Teil auch registrieren lassen.
Zitat: Die Sneak Preview läuft 30 Tage und kann nicht käuflich erworben werden.
Quelle: http://www.elby.ch/de/products/clone_dvd/index.html
Leichter gesagt als getan! :so-nicht: -
Es gibt jetzt eine geniale Altenative zum TitleSet Blanker, leider nur für 30 Tage, siehe hier: http://forum.gleitz.info/showthread.php?p=78005#post78005
CloneDVD2 mit Titelvorschau!!
Gruß Harry
Tja mein Testergebnis ist leider wie befürchtet!
Habe die Bildqualität von CloneDVD 2 mit IC8 und Shrink 3.1.5 verglichen, natürlich mit ein und derselben DVD!CloneDVD 2 ist klarer verlierer! Bringt keine guten Ergebnisse in Sachen Detailgenauigkeit und Schärfe! Was natürlich das große Manko ist und wo sich CloneDVD selber ein Bein stellt ist, das man nur die DVD komplett reduzieren kann. Es ist also nicht möglich wie bei den beiden Konkureten, z.B. die einzelne Titel z.B. Extras auf 40& zu stellen und sich so für den Hauptfilm z.B. 90% zu sichern! In meinem Test wurde die gesamte DVD um 68% reduziert, IC8 hatte 78% im Hauptfilm und Shrink 72% im Hauptfilm. Da ist es kein Wunder das da CloneDVD verliert! Da fass ich mir echt an den Kopf! :motz:
Shrink und IC8 liegen fast gleich auf, in Sachen Bild hat IC die Nase vorn aber was die Treffgenaugkeit eines Rohlings angeht natürlich nicht!!!
Was natürlich gar nicht so übel an CloneDVD2 ist, ist das ich jetzt 30 Tage eine vorzügliche TitleSet Blanker-Altenative habe mit schöner Titelvorschau! Es gibt nämlich die Funktion die Größe des Mediums selbst einzustellen von 100 bis 9999MB.
Harry -
Zitat von Frank.
Hi Sauge mir gerade mal die 30 Tage testversion herunter
und werde mal Testen ob die Bildqualität besser ist als mit IS8.
FrankWäre ja schon super wenn die Bildqualität genauso gut ist wie bei IC! CloneDVD trifft wenigstens immer die Größe!! Für mich wäre es dann Perfekt!
Bin jetzt auch mal am testen! -
Zitat von eDealer
Mach es doch mal ganz anders:
Kopiere nur die mit den PDI Tools extrahierten VOBs in ein neues Verzeichnis und erstelle mit IfoEdit die neuen Videomanager Dateien. Spätestens jetzt sollte es funktionieren, da IfoEdit im Shrink ja nicht die riesen Probleme hat?!
Sonst habe ich keine Idee mehr, da es ja bei mir funzt.eDealer
Du hast nicht zufällig ne Anleitung wie das gehen soll? -
Ach PDIXTACT heißt es! Das ist dann genau das Programm was ich von Anfang an benutzt habe!! Ich habe nämlich das PDITool genommen, das ist ja nur ne GUI für PDIXTRACT!
Also leider auch nicht des Rätsels Lösung!
Es sei den ich muß tatsächlich PDIXtract direkt starten ohne PDITOOL!? Hab es aber leider nicht geschafft alle .pdi damit zu extrahieren, verstehe die Comandozeile nich ganz! Bekomme immer nur das erste PDI entpackt.
Gruß Harry -
Zitat von Rudi Ratlos
Ich hab´s an anderer Stelle schon mal beschrieben! :ja:
Da ich noch einer von der "alten Garde" bin, arbeite ich auch noch, falls erforderlich, unter DOS. Für den obigen Fall lasse ist die von ICx erstellten *.pdi-Dateien mit den Progie "PDXTRACT" (unter DOS, oder in einem DOS-Fenster!) rückverwandeln.
In der Schublade, die ich diesem "PDXTRACT" zuweise, stehen, nach Fertigstellung, wieder die ganz normalen Dateien, wie sie im Ursprung auf der ausgelesenen DVD stehen, (nur eben geschrumpft!).
Diese Dateien lassen sich dann ohne Probleme wieder mit dem DVD-Shrink bearbeiten...! :cool:
Ich denke mal, DAS sollte auch bei EUCH klappen! :cool:
Gruß, Rudi RatlosAha!
Wo finde ich den dieses PDXTRACT? Habs mit keiner Suchmaschine im Netz gefunden!!
Gruß Harry -
Zitat von eDealer
Man könnte mit DVDfab mal die Video Manager Dateien erneuern?!
Oder mit IfoEdit create new Ifo's.Also nach dem erneuern der Video Manager Dateien mit DVDfab gibt es leider immernoch die gleiche Fehlermeldung! :mad:
Bei IfoEdit passiert irgendwie gar nichts wenn ich auf create new Ifo´s klicke!
Gruß Harry -
Auch bei Clone DVD krieg ich ne Fehlermeldung:
Beim öffnen der Video-Dateien ist ein Fehler aufgetreten
J:/Temp/VIDEO_TS
DVDManager 5 2 IFOFormat 22eDealer + Rudi Ratlos
Welche IC Version ind Shrink Versionen benutzt ihr den da zusammen? -
Zitat von eDealer
Nimm den H.S. Editor und extrahiere das PDI Image mit den PDITools in ein Folder. Dann die ifo in Shrink laden.
Nö, schön wärs gewesen, so klappt es bei mir auch nicht! :nein:
DVDShrink encountered an error and cannot continue
Failed to open file:J:\Temp\VTS_02_0.VOB"
Überlappender E/A-Vorgang wird bearbeitet
Das VOB-File läuft übrigens unter POWER DVD betrachtet einwandfrei!
Da läuft wohl irgendwas schief bei mir! -
Hi ferrismco!
Also, ich stelle immer so zwischen 4.38 und 4.42 Gb ein. Der Größen-Zeiger sollte gerade von grün nach rot gewechselt haben. Das heisst: Die Fehlermeldung kommt, dass der fertige Stream für ein Medium zu groß ist.
Lass dich davon nicht irritieren, sondern starte den IC trotzdem. Natürlich ist das Resultat etwas zu groß für einen 4,7Gb-Rohling. Aber, wenn IC durchgelaufen ist, machst du einfach das, was ich oben beschrieben habe. :cool:
Sollst sehen! Das klappt prima...., dauert eben halt nur ein wenig länger. Aber wenn man Zeit hat... :zunge:
Gruß, Rudi Ratlos@ Rudi Ratlos
Ist eine gute Idee die Sache nochmal durch Shrink laufen zu lassen! Leider bekomme ich immer eine Fehlermeldung bei Shrink, das die Datei Fehlerhaft ist! Wie machst du das genau?
Ich habe die pdi´s in iso gewandelt und dann die iso mit Daemon gemountet! Was anderes ist mir nicht eingefalle wie ich das dann sonst nochmal durch Shrink ziehen kann!
Also so hab ich es schon zich mal mit diversern Filmchen probiert und immer diese Fehlermeldung von Shrink erhalten! Egal ob vorher mit IC7 oder IC8 bearbeitet!Bin mal gespannt wie du das hinbekommst!
Gruß Harry -
Probiers mal mit ´nem Yakumo! Gibt es auch in deiner Preisklasse (ebay etc!)!
Hab den Yakumo delta und bin voll zufrieden! Geile Optik, schön klein (nicht wie Palm oder Sony!), schnell, stabil (trotz MS! )!
http://www.yakumo.de/produkte/index.php?pid=1&ag=PDAs -
Zitat von Bitspyer
Bei Indiana Jones ist es schon enttäuschend! Zumal es damals im Kino eine 5.1 Magnet-Tonspur gab.(Uralt Format, Dolby ähnlich, aber immerhin getrennte Kanäle!)
Bei Star Wars wäre ich echt sauer, wenn die alte Trilogie mit STEREO rauskommen würde. Immerhin war die SpecialEdition mitte der Neunziger komplett neu gemischt und auch in DD in den Kinos.@ Bitspyer
Also ich wär bei Star Wars nicht wirklich sauer wenn die alte Version anstatt der neu abgemischten Special Edition auf DVD rauskommt! Ist dir mal aufgefallen das die Schauspieler alle lispeln? Die haben überhaupt nicht gemerkt das sie mit den vielen Filtern und Effekten die Stimmen total versaut haben! :motz: Ich liebe die neuen/alten Szenen und reingezauberten Monster etc. aber ich kann es echt nicht ertragen wenn Obi Wan und alle nur lispeln! Das ist teilweise echt schlimm!!
Da kann man nur hoffen das die deutsche Spur irgendwann nochmal neu überarbeitet wird, aber da glaub ich nicht wirklich dran! :mad:
