Gordian Knot ist in der Version 0.28.5 erschienen - keine beta !!!
Die Änderungen gleich hier unten. Viel Spass
Gucki
It's first non beta since 0.28 (no serious bugs were found in the last couple of weeks, so lets call it stable release )
What's new in GK 0.28.5 (since 0.28)
- Added paths settings for all programs used by GK
- Added support for VDubMod 1.5.x.x (now works only with it)
- Encode window only shows codec selected on bitrate tab
- Added DTS support via azidts
- Added any DVD2AVI project support (works with 1.76, 1.77, 1.83)
- added command line interface which automatically openes
video, audio and other files:
/video"videofile"
/audio1"audiofile"
/audio2"audiofile"
/files"otherfile1;otherfile2"
- added support for non-english characters in video/audio file names
- when using XviD + b-frames new extended comp test is performed (as in Jonny's Enc)
- added manual "auto-split" subs feature to split them after you have several avi files.
- Bob deinterlace method is replaced by smart bob (DGBob)
- queue windows changed a bit + button for loading *.log files is added
- Internalization added (huge special thanks to tHegLouCh): 12 languages included
- tons of cosmetic changes and bugfixes
Please install full rip-pack of 0.28.5 as it contains a lot of new versions of tools which are required for GK to run.
Only if you have 0.28.3 or later you can use update installer.
