schade ... geht das denn bei wav-dateien? und wenn ja, wie?
Beiträge von picard
hallo,
ich möchte den eintrag für die samplerate in ogg-files ändern. diese soll nur "gepatcht" werden, nicht umgerechnet. da ogg open-source ist, habe ich auch einige informationen gefunden, die mir aber leider nicht viel weiter helfen
vielleicht kann mir ja jemand von euch nen tip geben:Zitat
The identification header is a short header of only a few fields used to declare the stream definitively as Vorbis,
and provide a few externally relevant pieces of information about the audio stream. The identification header is
coded as follows:
1) [vorbis_version] = read 32 bits as unsigned integer
2) [audio_channels] = read 8 bit integer as unsigned
3) [audio_sample_rate] = read 32 bits as unsigned integer
4) [bitrate_maximum] = read 32 bits as signed integer
5) [bitrate_nominal] = read 32 bits as signed integer
6) [bitrate_minimum] = read 32 bits as signed integer
7) [blocksize_0] = 2 exponent (read 4 bits as unsigned integer)
[blocksize_1] = 2 exponent (read 4 bits as unsigned integer)
9) [framing_flag] = read one bit
[vorbis_version] is to read ’0’ in order to be compatible with this document. Both [audio_channels]
and [audio_sample_rate] must read greater than zero. Allowed final blocksize values are 64, 128, 256, 512,
1024, 2048, 4096 and 8192 in Vorbis I. [blocksize_0] must be less than or equal to [blocksize_1]. The
framing bit must be nonzero. Failure to meet any of these conditions renders a stream undecodable.
The bitrate fields above are used only as hints. The nominal bitrate field especially may be considerably off in
purely VBR streams. The fields are meaningful only when greater than zero.ich habe schon versucht eine datei mit nem hex-editor zu öffnen, den eitrag 44100 (also ac44 in hex, ist die samplerate von dem file) habe ich auch ausgemacht, allerdings sind die paare vertauscht zu 44 ac. das ist aber wohl normal soweit ich weiß... nachdem ich an diese stelle 48000, also bb80 vertauscht zu 80 bb eingetragen habe, wurde das file als nicht mehr gültig erkannt...
... soweit mein problem
hallo leute,
soweit ich das sehe, kann besweet leider nicht faden ... ich hätte ne liste mp2's, bei denen ich jeweils die letzten 0,5s ausfaden lassen würde... ich weiß, ich kann die alle einzeln öffnen, aber dann würde ja alles neu kodiert werden...
gibts noch andere möglichkeiten?
ja, ich benutze xp, werde den patch mal probieren... danke für den link
keine ahnung was damit los ist, bbmpeg scheint noch recht viele bugs zu haben. in dem menü "start encoding" konnte ich dann die dateien wählen, aber selbst dabei schmiert er manchmal ab...
ich habe jetzt mit bbmpeg multipext ... (musste sowieso), da kann man die start/end sekunde angeben, hat auch funktioniert so...
sehr schön, hat geklappt so, schade nur das man bei bbmpeg nur ganze sekunden als begrenzung angeben kann...
ok danke, das ist doch mal ne klare antwort, wie ich sie mir gewünscht habe
dann werde ich mal bei 1500 bleiben und testen...
... ich wollte ja auch nicht wissen, ob die qualität noch ausreichend ist, sondern ob ein standard-dvd player ne dvd abspielen kann, auf der ein video mit 1500kbit ist. genauer gesagt wollte ich ürsprünglich wissen, welche bitrate mindestens vorhanden sein muss, damit sie von dvd-playern wiedergegeben werden kann...
im netz habe ich nämlich immer nur angaben zu maximalen datenraten gefunden...
das ist doch unlogisch, es sind keine informationen da, die es wert sind gespeichert zu werden, deshalb brauche ich nur wenig bitrate... das würde den gleichen sinn machen, ein unscharfes bild mit 1200dpi einzuscannen, es bringt einfach nichts, außer ne hohe datenmenge...
ist ja auch egal, ich habe doch nur ne einfache frage gestellt. eine ebenso einfache antwort hätte mir eigentlich genügt
also sind 1500kbit nun in ordnung oder nicht?
da mein quellmaterial schon geringe qualität hat, will ich es eigentlich nur in cbr codieren...
also könnte ich auch 1000kbit nehmen, wenn mir die qualität ausreicht?
hallo,
was ist die kleinstmögliche bitrate für mpeg1/2 die auf ner dvd erlaubt ist?
hallo leute,
nachdem ich ein backup meines systems wieder aufgespielt habe kann ich mit bbmpeg keine videodateien mehr öffnen. versuche ich eine m2v-datei zu öffnen, heißt es: could not open xyz.m2v
es ging doch eben noch (vor wiederherstellung meines systems)?! muss ich noch irgendwas anderes installieren?
weil ich damit nicht klarkomme
ich starte avi2mpg2.exe
klicke auf add bei der file list (links)
klicke auf start encoding
klicke auf settings
schalte encode video und encode audio ab, setzte die end second ->ok
bekomme die fehlermeldung, das die datei xyz.m1v nicht existiertich habe keine m1v datei, sondern ein mpg. außerdem schein bbmpeg auch die 2. tonspur nicht warzunehmen...
vielleicht kannst du mir ja mal nen tip geben?
hallo,
ich will ein svcd-file schneiden. ich lade es mit tmpg (mpeg-tools) unter merge&cut, gebe die endposition an (43:21,50) und lasse ihn machen... leider fehlt ab dieser position nur der ton, das video läuft weiter.
das mpeg hat mehrere tonspuren. ich weiß, das er nur eine übernimmt, die 2. wollte ich später hinzufügen... aber vielleicht hat es ja was damit zu tun? -
mpeg-audio-scissors kann auch keine mp2 :(. fehlermeldung: divisio by zero
mit mp3directcut habe ich es jetzt hinbekommen... danke
cool edit kann keine mp2-dateien lesen... *argh*
... kann doch nicht sein... ich will nur was abschneiden
also der musiCutter ist ja voll daneben... wie soll das denn gehen? ne kleine anleitung gibts auf der seite auch nicht
wie denn? ich meine mp2 audiodateien... ich wüsste nicht, wie das mit tmpg gehen soll...
habs mir gerade geladen... komme aber nicht so recht klar damit... ich will nicht neu codieren, k.a. wie man das einstellen soll.
wäre nett, wenn du mir ne kleine hilfestellung gibst
