Hi Leute,
also ich hab folgendes Problem: ich installiere udrec_suite mit ./configure –enable-bootstart=yes –prefix=/usr
die compilation funktioniert ohne Probleme wenn ich jedoch dann make eingeb bekomme ich folgendes angezeigt: make all-recursive
make[1]: Entering directory `/udrec_suite-0.3.2'
Making all in .
make[2]: Entering directory `/udrec_suite-0.3.2'
make[2]: Leaving directory `/udrec_suite-0.3.2'
Making all in scripts
make[2]: Entering directory `/udrec_suite-0.3.2/scripts'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/udrec_suite-0.3.2/scripts'
Making all in src
make[2]: Entering directory `/udrec_suite-0.3.2/src'
Making all in m2v_requantizer
make[3]: Entering directory `/udrec_suite-0.3.2/src/m2v_requantizer'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/udrec_suite-0.3.2/src/m2v_requantizer'
Making all in mkdvd
make[3]: Entering directory `/udrec_suite-0.3.2/src/mkdvd'
if g++ -DHAVE_CONFIG_H -I. -I. -I../.. -g -O2 -MT udrec.o -MD -MP -MF ".deps/udrec.Tpo" \
-c -o udrec.o `test -f 'udrec.cpp' echo './'`udrec.cpp; \
then mv -f ".deps/udrec.Tpo" ".deps/udrec.Po"; \
else rm -f ".deps/udrec.Tpo"; exit 1; \
fi
In file included from /usr/include/signal.h:307,
from udrec.cpp:27:
/usr/include/bits/sigcontext.h:28:29: asm/sigcontext.h: No such file or directory
In file included from /usr/include/netinet/in.h:212,
from /usr/include/netdb.h:28,
from udrec.cpp:28:
/usr/include/bits/socket.h:305:24: asm/socket.h: No such file or directory
In file included from /usr/include/errno.h:36,
from udrec.cpp:38:
/usr/include/bits/errno.h:25:26: linux/errno.h: No such file or directory
udrec.cpp: In function `void* UdpReceiver(void*)':
udrec.cpp:318: error: `EINTR' undeclared (first use this function)
udrec.cpp:318: error: (Each undeclared identifier is reported only once for
each function it appears in.)
udrec.cpp:349: warning: comparison is always false due to limited range of data
type
make[3]: *** [udrec.o] Error 1
make[3]: Leaving directory `/udrec_suite-0.3.2/src/mkdvd'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/udrec_suite-0.3.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/udrec_suite-0.3.2'
make: *** [all] Error 2
wenn ich nun make install eingebe bekomme ich dies:
Making install in .
make install-exec-hook
make[3]: Entering directory `/udrec_suite-0.3.2'
mkdir -p //usr/share/udrec_suite/movies/tmp
make[3]: Leaving directory `/udrec_suite-0.3.2'
make[2]: Nothing to be done for `install-data-am'.
Making install in scripts
make[1]: Entering directory `/udrec_suite-0.3.2/scripts'
/bin/sh ../mkinstalldirs /usr/bin
/usr/bin/install -c custom_udrec.sh /usr/bin/custom_udrec.sh
/usr/bin/install -c script.udrec /usr/bin/script.udrec
/usr/bin/install -c start_xvfb.sh /usr/bin/start_xvfb.sh
/usr/bin/install -c start_vlc.sh /usr/bin/start_vlc.sh
/usr/bin/install -c start_sserver.sh /usr/bin/start_sserver.sh
if [ -f //etc/udrec_suite/udrec_suite.conf ]; \
then \
echo "found old config file, copying to \".old\""; \
cp //etc/udrec_suite/udrec_suite.conf //etc/udrec_suite/udrec_suite.conf.old; \
fi
found old config file, copying to ".old"
make[3]: Entering directory `/udrec_suite-0.3.2/scripts'
mkdir -p //etc/rc`grep ':initdefault:' /etc/inittab | awk -F':' '{print $2}'`.d;\
cd //etc/rc`grep ':initdefault:' /etc/inittab | awk -F':' '{print $2}'`.d;\
if [ -h S99udrec_suite ]; then \
rm S99udrec_suite; \
fi; \
ln -s ../init.d/udrec_suite S99udrec_suite;
make[3]: Leaving directory `/udrec_suite-0.3.2/scripts'
/bin/sh ../mkinstalldirs /etc/init.d
/usr/bin/install -c udrec_suite /etc/init.d/udrec_suite
/bin/sh ../mkinstalldirs /etc/udrec_suite
/usr/bin/install -c -m 644 udrec_suite.conf /etc/udrec_suite/udrec_suite.conf
make[1]: Leaving directory `/udrec_suite-0.3.2/scripts'
Making install in src
make[1]: Entering directory `/udrec_suite-0.3.2/src'
Making install in m2v_requantizer
make[2]: Entering directory `/udrec_suite-0.3.2/src/m2v_requantizer'
/bin/sh ../../mkinstalldirs /usr/bin
/usr/bin/install -c requant /usr/bin/requant
make[3]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/udrec_suite-0.3.2/src/m2v_requantizer'
Making install in mkdvd
make[2]: Entering directory `/udrec_suite-0.3.2/src/mkdvd'
fi
from udrec.cpp:27:
from udrec.cpp:28:
from udrec.cpp:38:
type
make[2]: *** [udrec.o] Error 1
make[2]: Leaving directory `/udrec_suite-0.3.2/src/mkdvd'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/udrec_suite-0.3.2/src'
make: *** [install-recursive] Error 1
die Dateien sserver, udrec_suite, custom usw…. werden alle in die richtigen Verzeichnisse installiert jedoch unter usr/local/lib/jar/ ist kein „px.jar“ zu finden. Eben so wenig gibt es unter „var/log“ oder „var/lock“ ein udrec_suite.log. Installiert hab ich alles unter root. Wenn ich nun den pc neu starte, unter root einlocke und auf der dbox Aufnahme drücke bekomme ich dich Fehlermeldung keine Verbindung zum Streamingserver. Ich kann auch nicht unter /etc/init.d/ den udrec_suite mit „udrec_suite start“ starten unter root kommt da nur command not found und unter meinem Benutzername wenn ich mich einlocke und ihn manuell starten will springt der Cursor ohne Fehlermeldung in die andere Zeile. Wenn ich udrec_suite nur mit ./config installiere kann ich alles starten und auch aufnehmen. So das war jetzt viel zu lesen aber ich hoffe mit den Angaben könnt ihr was anfangen. Übrigens ich verwende udrec_suite-0.3.2 und suse linux 8.2 neutrino auf der dbox2 ist in der Version 1.7.1 installiert.
Vielen Dank für eure hilfe im voraus.
