also, hier ist meine logfile:
WNASPI32.DLL 4.71.2.0
- 05.04.2004 01:04:36
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.1 build 3
Initializing
- E:\DVD2SVCD\Files\VTS_03_0.IFO
- E:\DVD2SVCD\Files\VTS_03_1.vob
- E:\DVD2SVCD\Files\VTS_03_2.vob
- E:\DVD2SVCD\Files\VTS_03_3.vob
- E:\DVD2SVCD\Files\VTS_03_4.vob
- E:\DVD2SVCD\Files\VTS_03_5.vob
Initializing finished.
- 05.04.2004 01:04:39
- DVD2AVI
Creating DVD2AVI INI file:
- C:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"C:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[E:\DVD2SVCD\Files\DVD2AVI_Project_file] -IF=[E:\DVD2SVCD\Files\VTS_03_1.vob,E:\DVD2SVCD\Files\VTS_03_2.vob,E:\DVD2SVCD\Files\VTS_03_3.vob,E:\DVD2SVCD\Files\VTS_03_4.vob,E:\DVD2SVCD\Files\VTS_03_5.vob]
Framerate: 25000
DVD2AVI processing done.
- 05.04.2004 01:07:11
- Free on drive E: 3190.71 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: E:\DVD2SVCD\Files\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Framerate: 25000
Audio extraction finished.
- 05.04.2004 01:10:09
- AUDIO conversion
Encoding Audio. Filename: E:\DVD2SVCD\Files\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"C:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\DVD2SVCD\Files\Extracted_audio_1.ac3" -output "E:\DVD2SVCD\Files\Encoded_audio_1.mp2" -logfile "E:\DVD2SVCD\Files\Encoded_audio_1.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround2 -f on -g max ) -2lame( -e -b 192 -m s )
Audio conversion of E:\DVD2SVCD\Files\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 05.04.2004 01:19:26
- Converting Pictures
Converting: E:\DVD2SVCD\Covers\the_gathering.jpg
Converting: C:\Programme\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 05.04.2004 01:19:35
- Free on drive E: 3189.46 mb
- Video Encoding using TMPGEnc
- Encoding E:\DVD2SVCD\Files\TitlePicture.bmp.avs
Executing TMPGEnc. Commandline:
"C:\Programme\Pegasys Inc\TMPGEnc Plus 2.5\TMPGEnc.exe" "E:\DVD2SVCD\Files\TMPGEnc_Project_file.tpr" /Encode /Close
Video Encoding finished.
- Encoding E:\DVD2SVCD\Files\ChangeCDPicture.bmp.avs
- Encoding Test Clip E:\DVD2SVCD\Files\AviSynth_Script_file_CQ_TEST.avs
Wanted: 1519113016 (1483509kb)
Predicted: 1367344157 (1335297kb) Using CQ Value: 80.00
Calculated next CQ Value: 84.10
Predicted: 1430777683 (1397244kb) Using CQ Value: 84.10
Calculated next CQ Value: 86.50
Predicted: 115667707 (112957kb) Using CQ Value: 86.50
Calculated next CQ Value: 100.00
Predicted: 529073089 (516673kb) Using CQ Value: 100.00
Calculated final CQ Value: 100.00
- Encoding E:\DVD2SVCD\Files\AviSynth_Script_file.avs
StreamSectors: 1665085576
AudioSectors: 122070424
VideoPAPO: 23902128
ScanOffsetBytes: 0
SeqAligningBytes: 0
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 600.00
PureMPEGStream: 1519113016.00
Seconds: 5018.36
CalcMPEGStream: 1519113016.00
Frames: 125284
CDSize: 800.00
Number of CDs: 2
Cut point 795.00
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL")
mpeg2source("E:\DVD2SVCD\Files\DVD2AV~2.D2V")
# -= AviSynth script by FitCD v1.1.2 =-
Subtitle("You need to select the AutoFitCD Detect Borders setup first!!", y=Height/2, text_color=$FF0000)
ConvertToRGB()
----AVS End----
- 05.04.2004 01:36:25
- Free on drive E: 3176.77 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: C:\Programme\DVD2SVCD\bbMPEG\default.ini
Executing RunbbMPEG. Commandline:
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\DVD2SVCD\Files\TitlePicture.bmp.mpg"
- 05.04.2004 01:36:29
- Free on drive E: 3176.74 mb
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\DVD2SVCD\Files\ChangeCDPicture.bmp.mpg"
- 05.04.2004 01:36:32
- Free on drive E: 3176.71 mb
- 05.04.2004 01:43:46
Initializing
- 05.04.2004 01:43:48
- Crash Recovery
- Restarting from: Muxing and Cutting
- 05.04.2004 01:43:50
- 05.04.2004 01:43:54
- Free on drive E: 3176.69 mb
- 05.04.2004 01:43:57
- Free on drive E: 3176.68 mb
- 05.04.2004 01:44:00
- Free on drive E: 3176.67 mb
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 795 mb
"C:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\DVD2SVCD\Files\bbMPEG_Muxed_File.mpg"
Length of E:\DVD2SVCD\Files\bbMPEG_Muxed_File00.mpg
5007 Seconds
Offset in Seconds: 5009
Executing bbMPEG.
Variable Settings:
Cut point: 795 mb
Multiplexing and cutting finished.
- 05.04.2004 09:28:40
- Free on drive E: 3058.21 mb
- Determining length of audio
Analyzing: E:\DVD2SVCD\Files\bbMPEG_Muxed_File00.mpg
5009.256 seconds E:\DVD2SVCD\Files\bbMPEG_Muxed_File00.mpg
Analyzing: E:\DVD2SVCD\Files\bbMPEG_Muxed_File01.mpg
EAccessViolation Access violation at address 004984F2 in module 'DVD2SVCD.exe'. Read of address 019FC000
- 05.04.2004 09:33:13
Initializing
- 05.04.2004 09:33:14
- Crash Recovery
- Restarting from: SVCD Authoring
- 05.04.2004 09:33:15
EAccessViolation Access violation at address 004984F2 in module 'DVD2SVCD.exe'. Read of address 0206C000
- 05.04.2004 13:31:00
Initializing
- 05.04.2004 13:31:01
- Free on drive E: 2833.01 mb
- Crash Recovery
- 05.04.2004 13:31:02
EAccessViolation Access violation at address 004984F2 in module 'DVD2SVCD.exe'. Read of address 01E6C000
