hallo,
also windvr hab ich auch schon versucht. war bei der tv-karte dabei. aber gleiches ergebnis ! habe die mpg-datei jetzt mal in pavstrumento geladen und scan gemacht (richtig ? kenn das progi nicht). da kommen ein haufen meldungen, mit denen ich allerdings nichts anfangen kann, gut klingt es aber irgendwie nicht :
VIDEO: Resolution 720 x 576
(full D1)
Aspect ratio is 16:9
Frame rate 25.00 fps
Nominal bitrate 8000000 bps
first PTS: 00:00:00.220
AUDIO: MPEG-1, Layer 2
48.0 kHz, Stereo
Bitrate 224 kbps
Frame Length 24.0 ms (672 bytes)
No A/V delay. Go celebrate !
==SCANNING==
DEB> Using short video scan (manual override).
DEB> Syncing audio to first frame in time.
DEB> [Finding start of streams]
Funny. Video and Audio start synchronously.
DEB> SyncStart PTS is 00:00:00.220
DEB> TNK: A/V no integer lineup
No integer frame match for A/V.
ALERT> video frame missing at 00:09:01.840
DEB> Dropping GOP
DEB> A/V no integer lineup
Syncing: Cutting audio.
ALERT> Doubling of temporal offset 0
ALERT> Temporal structure wrong in GOP - dropping
DEB> Unable to set video frame to VBR
ALERT> video frame missing at 00:33:42.160
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 00:33:42.720
ALERT> Doubling of temporal offset 1
ALERT> video frame missing at 00:47:58.000
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 00:47:58.560
ALERT> video frame missing at 01:37:29.200
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 01:37:29.760
ALERT> video frame missing at 01:39:56.080
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 01:39:56.640
ALERT> video frame missing at 01:41:27.760
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 01:41:28.320
ALERT> video frame missing at 01:54:39.760
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 01:54:40.320
ALERT> video frame missing at 02:02:59.920
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 02:03:00.480
ALERT> video frame missing at 02:15:46.480
DEB> Dropping GOP
ALERT> PTS less than NofP (400 ms < 440 ms) at 02:15:47.040
Done.
Video bitrate: max 10197 , avg 3848 kbps
Video: 208633 pics 02:19:05.320
Audio: 347730 frames 02:19:05.520
wenn ich auf demux drücke,kommt folgende meldung :
(full D1)
48.0 kHz, Stereo
Bitrate 224 kbps
ALERT> Unable to open audio output
kann daraus jemand was ableiten bzgl. meines problems ??? wäre super !
der mpeg wurde übrigens mit virtualdub gecaptured und mit dem mainconcept encoder ins dvd format gebracht.
