Alles klar, werde ich gleich mal versuchen.
Danke !
Grüße
Tooltime
Beiträge von Tooltime
Hi!
Hier die log Datei:
ZitatWNASPI32.DLL 4.71.2.0
- 19.12.2003 00:55:05
- DVD to SVCD Conversion
- DVD2SVCD ver. 1.2.1 build 3
Initializing
- F:\DVD\Name\VTS_04_0.IFO
- F:\DVD\Name\VTS_04_1.vob
- F:\DVD\Name\VTS_04_2.vob
- F:\DVD\Name\VTS_04_3.vob
- F:\DVD\Name\VTS_04_4.vob
- F:\DVD\Name\VTS_04_5.vob
Initializing finished.
- 19.12.2003 00:55:09
- DVD2AVI
Creating DVD2AVI INI file:
- F:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.INI
Variable settings:
iDCT_Algorithm: 32-bit SSE MMX
Executing DVD2AVI.
Executing DVD2AVI. Commandline:
"F:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[E:\DVDs\SVCDName\DVD2AVI_Project_file] -IF=[F:\DVD\Name\VTS_04_1.vob,F:\DVD\Name\VTS_04_2.vob,F:\DVD\Name\VTS_04_3.vob,F:\DVD\Name\VTS_04_4.vob,F:\DVD\Name\VTS_04_5.vob]
Framerate: 25000
DVD2AVI processing done.
- 19.12.2003 00:58:06
- Free on drive E: 8965.53 mb
- AUDIO Extraction
Found AC3 stream id: 0x80
Filename: E:\DVDs\SVCDName\Extracted_audio_1.ac3
Audio1 delay: 0 ms
Framerate: 25000
Audio extraction finished.
- 19.12.2003 01:01:45
- Free on drive E: 8606.53 mb
- AUDIO conversion
Encoding Audio. Filename: E:\DVDs\SVCDName\Extracted_audio_1.ac3
Executing BeSweet. Commandline:
"F:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\DVDs\SVCDName\Extracted_audio_1.ac3" -output "E:\DVDs\SVCDNE~1\Encoded_audio_1.mp2" -logfile "E:\DVDs\SVCDNE~1\Encoded_audio_1.log" ) -azid( -L -3db -C 0db -S 0db -c normal -s surround -g max ) -shibatch( --rate 44100 ) -2lame( -e -b 128 -m s )
Audio conversion of E:\DVDs\SVCDName\Extracted_audio_1.ac3 finished.
Audio conversion finished.
- 19.12.2003 01:24:47
- Free on drive E: 8503.63 mb
- Converting Pictures
Converting: F:\Programme\DVD2SVCD\DefaultChangeCD.bmp
Finished converting pictures
- 19.12.2003 22:32:48
- Free on drive E: 7009.91 mb
- Video Encoding using TMPGEnc
- Encoding Test Clip E:\DVDs\SVCDName\AviSynth_Script_file_CQ_TEST.avs
Executing TMPGEnc. Commandline:
"F:\Programme\DVD2SVCD\TempGenc\TMPGEnc.exe" "E:\DVDs\SVCDName\TMPGEnc_Project_file.tpr" /Encode /Close
- 19.12.2003 22:50:56
Initializing
- 19.12.2003 22:51:09
- Free on drive E: 7008.97 mb
- Crash Recovery
- Restarting from: Video encoding
- 19.12.2003 22:51:10
Video Encoding finished.
Wanted: 1514939980 (1479434kb)
Predicted: 1573581119 (1536700kb) Using CQ Value: 80.00
Calculated next CQ Value: 78.25
Predicted: 1555513267 (1519056kb) Using CQ Value: 78.25
Calculated next CQ Value: 77.05
Predicted: 1543783437 (1507601kb) Using CQ Value: 77.05
Calculated next CQ Value: 76.20
Predicted: 1539936381 (1503844kb) Using CQ Value: 76.20
Calculated next CQ Value: 75.47
Predicted: 1534700886 (1498731kb) Using CQ Value: 75.47
Calculated next CQ Value: 74.90
Predicted: 1529189100 (1493349kb) Using CQ Value: 74.90
Calculated next CQ Value: 74.49
Predicted: 1525047858 (1489305kb) Using CQ Value: 74.49
Calculated final CQ Value: 74.20
- Encoding E:\DVDs\SVCDName\AviSynth_Script_file.avs
StreamSectors: 1657411728
AudioSectors: 108751580
VideoPAPO: 23989572
ScanOffsetBytes: 150732
SeqAligningBytes: 9579856
DVDBytes: 0
VideoEndHeader: 8
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 1.00
PureMPEGStream: 1514939980.00
Seconds: 6706.20
CalcMPEGStream: 1514939980.00
Frames: 167480
CDSize: 795.00
Number of CDs: 2
Cut point 790.00
Using CQ Value: 74.20
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("F:\PROGRA~1\DVD2SVCD\AVISYN~1\Mpeg2dec\mpeg2dec.dll")
mpeg2source("E:\DVDs\SVCDNE~1\DVD2AV~1.D2V")
BicubicResize(480,432,0.0,0.6)
AddBorders(0,72,0,72)
ConvertToRGB()
----AVS End----
- 20.12.2003 05:07:31
- Free on drive E: 5338.28 mb
- Converting Pictures from ES to PS
Saving bbMPEG settings: F:\Programme\DVD2SVCD\bbMPEG\default.ini
- 20.12.2003 05:07:34
- Free on drive E: 5337.97 mb
- 20.12.2003 05:07:36
- Free on drive E: 5337.66 mb
- 20.12.2003 05:07:39
- Free on drive E: 5337.34 mb
- Multiplexing and cutting
Offset in Seconds: 2
Executing bbMPEG.
Variable Settings:
Movie offset: 2 seconds
Cut point: 790 mb
Executing RunbbMPEG. Commandline:
"F:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "E:\DVDs\SVCDName\bbMPEG_Muxed_File.mpg"
Length of E:\DVDs\SVCDName\bbMPEG_Muxed_File00.mpg
3274 Seconds
Offset in Seconds: 3276
Executing bbMPEG.
Variable Settings:
Cut point: 790 mb
Multiplexing and cutting finished.
- 20.12.2003 05:19:34
- Free on drive E: 3741.72 mb
- Determining length of audio
Analyzing: E:\DVDs\SVCDName\bbMPEG_Muxed_File00.mpg
3276.669 seconds E:\DVDs\SVCDName\bbMPEG_Muxed_File00.mpg
Analyzing: E:\DVDs\SVCDName\bbMPEG_Muxed_File01.mpg
3422.746 seconds E:\DVDs\SVCDName\bbMPEG_Muxed_File01.mpg
Analyzing finished.
- 20.12.2003 05:20:49
- Free on drive E: 3740.91 mb
- Creating CD-Images using VCDXBuild
- No. of chapters to create: 54
CD image #1: CD_Image_File_CD1.bin
Executing VCDXBuild. Commandline:
"F:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="E:\DVDs\SVCDNE~1\CD_Image_File_CD1.cue" --bin-file="E:\DVDs\SVCDNE~1\CD_Image_File_CD1.bin" "E:\DVDs\SVCDNE~1\VCDXBU~1.XML"
- 20.12.2003 05:23:21
- Free on drive E: 2939.75 mb
- No. of chapters to create: 57
CD image #2: CD_Image_File_CD2.bin
"F:\Programme\DVD2SVCD\VCDImager\VCDXBuild.exe" --verbose --cue-file="E:\DVDs\SVCDNE~1\CD_Image_File_CD2.cue" --bin-file="E:\DVDs\SVCDNE~1\CD_Image_File_CD2.bin" "E:\DVDs\SVCDNE~1\VCDXBU~2.XML"
Image creation finished.
- 20.12.2003 05:26:05
- Free on drive E: 2122.88 mb
- Conversion done!
- 21.12.2003 17:30:38
Initializing
Initializing finished. -
Hallo zusammen!
Bei den letzten Filmen, die ich umgewandelt habe (DVD2SVCD Ver.: 1.2.1 b3) bekomme ich sowohl mit TEMPGenc als auch mit CCE Dateien/Images, die zu groß sind, obwohl ich bei "Bitrate" die korrekten Werte eingegeben habe. Meistens ist nur die letzte Datei/Image betroffen???
Was nun?
Grüße
Tooltime -
Bis jetzt liefen alle SVCD´s sowohl auf dem Rechner, als auch im Player. Die ganzen Dateien habe ich vor dem DVDx durchlauf leider gelöscht...
Hallo zusammen!
Habe versucht eine SVCD zu erzeugen. Habs mit DVD2SVCD -aktuelle Vers-(TEMPGenc und CCE) und DVDx -aktuelle Vers- versucht. Die fertige SVCD läuft aber nicht. Ich bekomme bei allen Versuchen den Fehler "Falscher Zeiger". Hatte ich noch nie..was kan ich tun???Grüße
Tooltime -
Hallo zusammen!
Habe gerade versucht eine SK von der Spiderman DVD auf die Platte zu rippen (mit DVD2SVCD und mit Smartripper). Bei beiden Versuchen hatte ich keinen Ton beim Anspielen der Dateien auf der Platte mittels PowerDVD.
Was nun???Grüße
Tooltime -
Danke für den Tip!
Habe aber gerade nochmal gerippt...
Viele Grüße
Tooltime
Ist wohl nix zu machen..muß ich noch mal rippen
Grüße
Tooltime
Hallo zusammen!
Ich möchte nur schnell eine IFO zu 4 vob´s erstellen und bekomme im IFO edit 0.95 diese Fehlermeldung
"Could not find any VOB unit in VOB File(s)"Was nun?
Pleas helpGrüße
Tooltime
