hier die log datei
WNASPI32.DLL 4.6.0.1021
- 21.08.2005 14:28:47
- AVI to SVCD Conversion
- AVI2DVD ver. 1.2.2 build 3
Initializing
- F:\Larva.German.2005.DVDRip.XviD-FRM.avi
Initializing finished.
- 21.08.2005 14:28:50
- Free on drive E: 5148.64 mb
- AUDIO Extraction
Audio extraction finished.
- 21.08.2005 14:29:32
- AUDIO conversion
- 21.08.2005 14:29:35
- AUDIO conversion
Converting MP2 to WAV. Filename: E:\DVD2SVCD arbeitsordner\Extracted_audio_1.mpa
Executing MADPlay (mp2 to wav). Commandline:
"C:\Programme\DVD2SVCD\MADPlay\madplay.exe" --quiet --output=wave:"E:\DVD2SVCD arbeitsordner\Encoded_audio_1.mpa.wav" "E:\DVD2SVCD arbeitsordner\Extracted_audio_1.mpa"
Conversion (mp2 to wav) of E:\DVD2SVCD arbeitsordner\Extracted_audio_1.mpa finished.
Encoding Audio. Filename: E:\DVD2SVCD arbeitsordner\Extracted_audio_1.mpa
Executing BeSweet. Commandline:
"C:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "E:\DVD2SVCD arbeitsordner\Encoded_audio_1.mpa.wav" -output "E:\DVD2SV~1\Encoded_audio_1.mpa" -payload -logfile "E:\DVD2SV~1\Encoded_audio_1.log" )
Audio conversion of E:\DVD2SVCD arbeitsordner\Extracted_audio_1.mpa finished.
Audio conversion finished.
- 21.08.2005 14:32:58
- Free on drive E: 4163.53 mb
- Video Encoding using Cinema Craft
Executing Cinema Craft Encoder.
StreamSectors: 4666096988
AudioSectors: 2324
VideoPAPO: 72280296
ScanOffsetBytes: 201750
SeqAligningBytes: 12822333
DVDBytes: 0
VideoEndHeader: 4
SubtitleSectors: 0
EmptySectors: 238.00
PictureSectors: 0.00
PureMPEGStream: 4580790280.67
Seconds: 5382.00
CalcMPEGStream: 4580790280.67
Frames: 134500
CDSize: 4464.00
Number of CDs: 1
Cut point 4460.00
Variable Settings:
Frames: 134500
Anti Noise Filter: Off
Passes: 3
Image Quality: 17
VAF file creation: On
Video Encoding Mode: One Pass VBR
Q. Factor: 60
Min. bitrate: 800
Max. bitrate: 6809
Aspect Ratio: 16:9 (borders added, encoded as 4:3)
---AVS Begin---
LoadPlugin("C:\PROGRA~1\DVD2SVCD\AVISYN~1.5PL\Mpeg2dec\MPEG2D~1.DLL")
AVISource("F:\LARVAG~1.AVI",audio=false)
ConvertToYUY2()
Import("C:\Programme\DVD2SVCD\Tylo\RoBaConditional.avs")
LanczosResize(720,404)
AddBorders(0,86,0,86)
Import("E:\DVD2SVCD arbeitsordner\ResampleAudio.avs")
ResampleAudio(44100)
----AVS End----
- 21.08.2005 16:50:12
Initializing
- 21.08.2005 16:50:13
- Free on drive E: 3200.95 mb
- Restarting from: Muxing and Cutting
- 21.08.2005 16:50:15
- Multiplexing Audio and Video
Executing MPlex. Commandline:
"C:\Programme\DVD2SVCD\DVDAuthor\mplex.exe" -f 8 -o "E:\DVD2SVCD arbeitsordner\MPlex_Muxed_File00.mpg" "E:\DVD2SVCD arbeitsordner\Encoded_Video_CCE_PAL.mpv" "E:\DVD2SVCD arbeitsordner\Encoded_audio_1.mpa"
- 21.08.2005 16:50:18
- Determining length of audio
Analyzing finished.
- 21.08.2005 16:50:23
- Authoring DVD
Executing DVDAuthor. Commandline:
"C:\Programme\DVD2SVCD\DVDAuthor\dvdauthor.exe" -x "E:\DVD2SVCD arbeitsordner\DVDAuthor.xml"- Free on drive E: 3200.95 mb
danach macht er nix mehr. hier noch das dvdauthor log
DVDAuthor::dvdauthor, version 0.6.10.
Build options: gnugetopt iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing E:\DVD2SVCD arbeitsordner\MPlex_Muxed_File00.mpg...
ERR: Error opening E:\DVD2SVCD arbeitsordner\MPlex_Muxed_File00.mpg: No such file or directory
die einstellung ist wie nach dem installieren. hab nur den default ordner umgestellt und dass ich avi nach dvd umwandeln will. roba einstellungen auch ganz normal, d.h. nichts verstellt
Roba.
cd size 4464 threshold Q: 36
sample % 1.0 Adjust %: 1.2
use cond. filter if configured aktiviert
limit% 2.5 <> 0.0 Q over: 40 use transcoder if oversized aktiviert.
hoffe das reicht erstmal
