Hab ich grad eben gelesen.
Gabs noch nicht in den News, oder?
ZitatAlles anzeigen- Changed: First new destination size is now even better
- Changed: Rewrite of the resizer-engine
- Changed: Rewrite of the cropping part
- Changed: Rewrite of the letterboxing (and optimal positioning) part
- Changed: Rewrite of avisynth-scripting
- Changed: Film pixel are now entered by the borders
- Changed: ResampleAudio-Box is now a CCE-fix-box
- Changed: Enhanced Tab-order
- Changed: Resizing error-value is now in the quick-hint of the aspect-ratio
- Changed: Removed "Average cropping"
- Changed: Multiplexing <-> authoring dependencies
- Changed: Increased the maximums of film-minutes and disc-size
- Changed: Removed entering subtitle-BMP size in KB
- Changed: Look of preview window [Fit2Disc]
- Added: YUY2 colorspace conversion
- Added: Support for AviSynth v2.5x
- Added: Detection of avisynth & plugin-directories
- Added: Detection of mpeg2dec*.dll
- Added: Automatic setting of a plugin-directory if it doesn't exist
- Added: Support for much more source-types (via DirectShow)
- Added: 'No resizing' avisynth-option
- Added: Destination size- & border-visualisation
- Added: Autom. colorspace-fix for the Canopus DV-codec + MJPEG-codecs
- Added: Forcing codecs to decode to RGB24.
- Added: Up/Down-button for manually adjusting the bitrate by 100kbps
- Added: Aspect-Ratio '1:2 Monitor' for some capture-devices
- Added: Options to compress or stretch YUV-colorspace
- Added: Don't resize when source- & destination-sizes are the same
- Added: Only crop when necessary
- Added: Setting a default avisynth working directory
- Added: Manually load some plugins
- Added: Colorspace converting of MPEG sources
- Added: Force the codecs to other colorspaces than just RGB24
- Added: DVD+R and DVD+RW disc-sizes [Fit2Disc]
- Added: manual cropping in the preview-window [Fit2Disc]
- Added: Detection/Support of Mpegdecoder.dll [Fit2Disc]
- Added: DTS-bitrates & -overhead calculation [Fit2Disc]
- Added: preview of the temp. avs-file to load the preview [Fit2Disc]
- Added: Editing of the Denoiser-string [Fit2Disc]
- Added: Manual destination-resolutions [Fit2Disc]
- Added: DVD-multiplexing for MP2 with DVDMaestro & Scenarist [Fit2Disc]
- Added: Subtitle calculations for DVDMaestro & Scenarist [Fit2Disc]
- Added: Browse-button for counting subtitle BMPs in a directory [Fit2Disc]
- Added: Browse-button to enter Extra Data by directory-size [Fit2Disc]
- Added: Do some default-stuff (an avisynth-line) before video-loading [Fit2Disc]
- Added: Do some default-stuff (avisynth-lines) after video-loading [Fit2Disc]
- Fixed: First new destination size should now be better
- Fixed: Cropping values weren't always updated on aspect-ratio change
- Fixed: Aspect-Ratios for the 3/4-D1 formats
- Fixed: Don't crop lesser than div4 with interlaced-resizing
- Fixed: (macro)block calculation wasn't dependent on the (macro)block's vertical position
- Fixed: Under WinXP, the window moved down a pixel, on window-swiching
- Fixed: Cut, Copy and Paste didn't work with number-fields.
- Fixed: Manual setting of min- & max-datarates in the INI didn't work
- Fixed: Optimization is now dependent on interlaced resizing
- Fixed: Removed error-message on startup, when the source-file doesn't exist.
- Fixed: Denoise output wasn't done field-wise with interlaced material [Fit2Disc]
- Fixed: Preview didn't show videos with one frame [Fit2Disc]
- Fixed: DVD-subtitle overhead calculation should be more accurate now [Fit2Disc]
- Fixed: Delete codec-info when no AVI is loaded.
- Fixed: Better loading of AVIs in the preview-window [Fit2Disc]
- Fixed: AVIs with unknown audio didn't load correctly [Fit2Disc]
- Fixed: Exception on closing Fit2Disc [Fit2Disc]
