Nächste Version ist raus: v0.38
Zitat von robot1Changelog:
- Bugfix: fixed a wrong parameter in OPV prediction for CCE SP2 (thanks to ercofra for pointing it out)
- Added *PROGRESSIVE statement in HC.ini for progressive sources (HC 0.22 compatible)
- Added *NOSMP statement in HC.ini if multiple processes used (the last segments are econded in multiprocess mode)
- Set to 15% the maximum Sample Size for prediction (1-3% suggested)If you use multiple processes, SMP mode in HC is used when
frames_current_segment > all_frames_to_encode/(nr_process-1)Usually the last 2-4 segments (according to the number of threads used) are encoded in SMP mode, but this should cover also strange cases (as a very long segment followed by many small segments)
Gibt's hier.
Cu Rippraff
