autoq
AutoQ is a Prediction-Tool for Cinema Craft Encoder.
So it is simple to get the right Q for encoding Your movie in only one VBR-Pass.
Changes
1.3.7 (20050219)[font=verdana, arial, helvetica]
[/font] [font=verdana, arial, helvetica]Added: Support for EclStart 0.4[/font]
1.3.6 (20050218)[font=verdana, arial, helvetica]
[/font] [font=verdana, arial, helvetica]Fixed: Fullencode-Mode (EclStart)[/font]
1.3.5 (20050218)[font=verdana, arial, helvetica]
[/font] [font=verdana, arial, helvetica]Fixed: CCE.set load is fixed[/font]
1.3.4 (20050218)[font=verdana, arial, helvetica]
[/font] [font=verdana, arial, helvetica]Added: Support for EclStart[/font]
1.3.3 (20050215)[font=verdana, arial, helvetica]
[/font] [font=verdana, arial, helvetica]Added: Support for CCE Trial 2.70.02.00
[Blockierte Grafik: http://www.brckomania.net/AUTOQ/img/autoq134.png]
http://www.autoq.tk/
eclstart
[/font][font=verdana, arial, helvetica] Releases:
0.4
Now You can use EclStart as EclCCE
0.3
Support for CCE Fullversion
0.2
Added switch -ecl and -shutdown
0.1
First Release, Support for CCE 2.70.02.00
[Blockierte Grafik: http://www.brckomania.net/EclStart/eclstart.png]
[/font]
